[Geoserver-devel] Build failed in Jenkins: geoserver-2.10.x #213
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/213/changes&gt;
Changes:
[emerkle] Log errors creating GeoGig index
[...truncated 15304 lines...]
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-rest ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-jms-geoserver ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jms-geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Extensions 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-extension ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-extension ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-rest ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 7.012 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 12.694 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 8.222 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 7.471 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.854 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.482 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.781 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.535 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.726 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.348 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 25.353 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.525 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.879 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.220 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.396 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.429 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 11.907 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.501 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.351 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.304 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.908 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.787 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.304 s]
[INFO] DownloadProcess .................................... SUCCESS [ 7.208 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.877 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.899 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.733 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.114 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.700 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.805 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.142 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.960 s]
[INFO] GeoFence Server .................................... SUCCESS [ 8.173 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.400 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.064 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.948 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.206 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.822 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 6.128 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.601 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 6.611 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.050 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.619 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.201 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 5.952 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 7.660 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 23.471 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.062 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 10.284 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.257 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.001 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 2.964 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.518 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 19.353 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.717 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.671 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.396 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.371 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 3.010 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.156 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 4.714 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:42 min (Wall Clock)
[INFO] Finished at: 2017-03-16T19:48:27+00:00
[INFO] Final Memory: 141M/680M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geogig: Compilation failure
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/test/java/org/geogig/geoserver/GeoGigTestData.java&gt;:\[394,45\] error: incompatible types: SimpleFeatureType cannot be converted to RevFeatureType
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/214/changes&gt;
