See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/228/changes>
Changes:
[jd] Update geogig plugin to work with additional parameter options.
[...truncated 15226 lines...]
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-rest ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-jms-geoserver ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jms-geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Extensions 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-extension ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-extension ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-rest ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 6.937 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 13.231 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 5.814 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.607 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 11.775 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.892 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 4.748 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.907 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.361 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.303 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 26.101 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 8.845 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.463 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 6.840 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.950 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.771 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 9.275 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.023 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.294 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.503 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.048 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.967 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.496 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.197 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.869 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 5.069 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.388 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.769 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.952 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.504 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.256 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.828 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.917 s]
[INFO] REST SLD service ................................... SUCCESS [ 7.519 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.154 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.475 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.336 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.154 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.687 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.636 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.400 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.039 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 10.106 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.358 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.330 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.005 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 20.079 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.093 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 9.486 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.596 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.287 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.083 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.367 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 19.484 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.581 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.411 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.032 s]
[INFO] gs-notification-common ............................. SUCCESS [ 2.840 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 4.885 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.263 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 4.891 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:32 min (Wall Clock)
[INFO] Finished at: 2017-03-23T22:50:26+00:00
[INFO] Final Memory: 138M/678M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-geogig: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportRepoCommandResource.java>:\[15,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportRepoCommandResource.java>:\[21,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportExistingRepo.java>:\[17,7\] error: constructor AbstractWebAPICommand in class AbstractWebAPICommand cannot be applied to given types;
[ERROR] actual and formal argument lists differ in length
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportExistingRepo.java>:\[19,1\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[26,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[32,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[34,45\] error: no suitable method found for runCommand(Variant,Request,MediaType)
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
