See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/24/changes>
Changes:
[andrea.aime] [GEOS-7788] original BandNames from coverageViews are lost, being
[...truncated 17201 lines...]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/test-classes>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.5 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/surefire-reports>
T E S T S
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target>
Running org.geoserver.security.cas.CasAuthenticationTest
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT.pom
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.796 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.343 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 15.670 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.093 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.059 s]
[INFO] Main Module ........................................ SUCCESS [02:35 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.118 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 58.067 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:57 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.846 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 29.425 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 31.221 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.939 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:48 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:15 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.693 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:13 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.816 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:16 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.056 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.191 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.990 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.917 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.213 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.533 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.138 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:21 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:46 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:15 min]
[INFO] REST UI Module ..................................... SUCCESS [ 14.282 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.040 s]
[INFO] Printing Module .................................... SUCCESS [ 13.669 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.271 s]
[INFO] Community Space .................................... SUCCESS [ 0.132 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.040 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:47 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.410 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.197 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.307 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.883 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.509 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.260 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.256 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.758 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.541 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.317 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.039 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.884 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.925 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.039 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:39 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.525 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.105 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.601 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.205 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.601 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 16.309 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.186 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 28.625 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.741 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.423 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.103 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.477 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 10.502 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.062 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 8.966 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 6.254 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 6.992 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.061 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.016 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.921 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.113 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.963 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 12.632 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.416 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.748 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.054 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.930 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.966 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.032 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.271 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.734 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.727 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.078 s]
[INFO] Importer Core Module ............................... SUCCESS [ 48.842 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 45.081 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 24.007 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.705 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.598 s]
[INFO] NetCDF Coverage format ............................. FAILURE [ 21.767 s]
[INFO] BUILD FAILURE
[INFO] Total time: 21:40 min (Wall Clock)
[INFO] Finished at: 2016-10-26T16:15:11+00:00
[INFO] Final Memory: 115M/282M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-netcdf: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/netcdf/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf
