[Geoserver-devel] Build failed in Jenkins: geoserver-2.10.x #255
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/255/changes&gt;
Changes:
[andrea.aime] [GEOS-8089] Integrated GWC does not work with layer and layer group
[...truncated 11907 lines...]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.792 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.352 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/target/gs-web-sec-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.10-SNAPSHOT/gs-web-sec-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/classes&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.867 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.10-SNAPSHOT/gs-web-csw-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.516 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.466 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.119 s]
[INFO] Main Module ........................................ SUCCESS [02:32 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.062 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 59.715 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:26 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.298 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.023 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.837 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 50.893 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:40 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:29 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.453 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 14.544 s]
[INFO] REST Support Module ................................ SUCCESS [ 16.456 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:21 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.089 s]
[INFO] Core UI Module ..................................... SUCCESS [01:22 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.039 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.262 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.519 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 12.854 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.627 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.272 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.067 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:20 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:44 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:13 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.493 s]
[INFO] Printing Module .................................... SUCCESS [ 13.857 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:50 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.208 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.278 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 13.796 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.076 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.452 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.250 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.278 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.449 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.935 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.261 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.399 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.589 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:29 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.341 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.204 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.509 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.495 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.487 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.920 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.977 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.773 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.099 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.065 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.090 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.024 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.054 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.861 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.046 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.260 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 22.275 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.044 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.627 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.184 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.094 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.313 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.047 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.300 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.191 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.051 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 21.008 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.245 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.352 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.057 s]
[INFO] Importer Core Module ............................... SUCCESS [ 46.153 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 40.823 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 22.571 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.425 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.397 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 22.238 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.917 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 20:29 min (Wall Clock)
[INFO] Finished at: 2017-04-13T13:22:05+00:00
[INFO] Final Memory: 126M/546M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-gwc: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/gwc/src/test/java/org/geoserver/gwc/GWCIntegrationTest.java&gt;:\[1007,37\] error: cannot find symbol
[ERROR] class GWCIntegrationTest
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/gwc/src/test/java/org/geoserver/gwc/GWCIntegrationTest.java&gt;:\[1011,16\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/256/changes&gt;
Changes:
[afabiani] Fix for GEOS-8055: backup plugin: styles.dat.1 has invalid xml
[...truncated 11961 lines...]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/importer/web/target/gs-importer-web-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.10-SNAPSHOT/gs-importer-web-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/test-classes&gt;
[INFO]
T E S T S
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.788 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.321 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.821 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.822 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.978 s]
[INFO] Main Module ........................................ SUCCESS [02:28 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.063 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:01 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:20 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.459 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.760 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.378 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 52.620 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:39 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:28 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.375 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 13.826 s]
[INFO] REST Support Module ................................ SUCCESS [ 16.272 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:29 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.038 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.036 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.692 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 37.650 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.578 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.659 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.379 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.045 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:29 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:12 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.253 s]
[INFO] Printing Module .................................... SUCCESS [ 14.146 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.402 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.125 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.998 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.187 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.525 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.263 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.276 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.656 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.631 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.022 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.119 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.492 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:32 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.429 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.791 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.532 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.264 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.505 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.661 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.115 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.698 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.152 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.047 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 14.993 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.803 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.048 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.436 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.049 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.331 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.357 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.072 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.827 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.023 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.606 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.458 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.031 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.670 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.346 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.027 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.905 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.524 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 16.918 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.060 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.923 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 41.481 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.997 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.478 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.101 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 25.474 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.246 s]
[INFO] Finished at: 2017-04-13T14:36:48+00:00
[INFO] Final Memory: 126M/481M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/257/changes&gt;
