[Geoserver-devel] Build failed in Jenkins: geoserver-2.10.x #42
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/42/changes&gt;
Changes:
[afabiani] - Bunch of improvements for OAuth2 Community Module and Documentation:
[...truncated 15742 lines...]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jms-cluster-container ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jms-cluster-container ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jms-cluster-container ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/target/gs-jms-cluster-container-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-jms-cluster-container ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (821 B at 12.9 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.151229-1100.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.151229-1100.pom (2 KB at 15.7 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml (465 B at 8.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (842 B at 10.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml (418 B at 4.9 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.151229-1100-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.151229-1100-tests.jar (3 KB at 23.2 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (842 B at 8.0 KB/sec)
[INFO]
[INFO] Building ActiveMQ 2.10-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ activemqBroker ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ activemqBroker ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/src/main/java&gt;
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ activemqBroker ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ activemqBroker ---
[INFO] Copying 0 resource
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ activemqBroker ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ activemqBroker ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-war-plugin:2.2:war (default-war) @ activemqBroker ---
[INFO] Packaging webapp
[INFO] Assembling webapp [activemqBroker] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/src/main/webapp\]>
[INFO] Webapp assembled in [928 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT.war&gt;
[INFO] WEB-INF/web.xml already added, skipping
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ activemqBroker ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ activemqBroker ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ activemqBroker ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ activemqBroker ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT.war
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ activemqBroker ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 25.7 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.151301-1100.war
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.151301-1100.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.151301-1100.pom (8 KB at 33.5 KB/sec)
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.554 s]
[INFO] Core Platform Module ............................... SUCCESS [ 1.863 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.735 s]
[INFO] Main Module ........................................ SUCCESS [ 13.493 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.898 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.205 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.313 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.479 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.714 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 4.752 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.787 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 1.957 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 3.439 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.631 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.950 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.160 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 3.257 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.628 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.452 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.467 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.629 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.264 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.668 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.500 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.602 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 3.573 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 1.667 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.385 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.094 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 33.184 s]
[INFO] Community Space .................................... SUCCESS [ 1.627 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 8.305 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.230 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.352 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.771 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.216 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.611 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.612 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.329 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.187 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.144 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.092 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.231 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 23.503 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.095 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.301 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.830 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.762 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.018 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.007 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.598 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.405 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.431 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.950 s]
[INFO] REST plugin community module ....................... SUCCESS [ 6.272 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.384 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.431 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.530 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 6.209 s]
[INFO] ActiveMQ ........................................... FAILURE [ 49.050 s]
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 06:13 min
[INFO] Finished at: 2016-10-31T15:13:19+00:00
[INFO] Final Memory: 171M/480M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project activemqBroker: Failed to deploy artifacts: Could not transfer artifact org.geoserver.community:activemqBroker:war:2.10-20161031.151301-1100 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Failed to transfer file: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.151301-1100.war. Return code is: 413, ReasonPhrase: Request Entity Too Large. -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :activemqBroker
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/43/&gt;
[...truncated 15623 lines...]
[INFO]
[INFO]
[INFO]
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (821 B at 14.8 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.161120-1101.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.161120-1101.pom (2 KB at 14.7 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml (465 B at 8.6 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (842 B at 10.5 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.161120-1101-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.161120-1101-tests.jar (3 KB at 23.4 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Webapp assembled in [313 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.161135-1101.war
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.161135-1101.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.161135-1101.pom (8 KB at 34.0 KB/sec)
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.804 s]
[INFO] Core Platform Module ............................... SUCCESS [ 2.018 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.684 s]
[INFO] Main Module ........................................ SUCCESS [ 16.096 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.812 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.190 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.689 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.966 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.735 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.721 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.668 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 1.733 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 4.628 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 2.399 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.068 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.144 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 3.265 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.602 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.274 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.810 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.547 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.104 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.683 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.448 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.597 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.855 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 2.072 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.350 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.517 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 33.869 s]
[INFO] Community Space .................................... SUCCESS [ 1.758 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.324 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.169 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.034 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.955 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.656 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.710 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.546 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.502 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.650 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.716 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.840 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.009 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.826 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.066 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.746 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.427 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.630 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.717 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.135 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.270 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.485 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.306 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.312 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.717 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.430 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.095 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.776 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 6.193 s]
[INFO] ActiveMQ ........................................... FAILURE [ 32.849 s]
[INFO] Total time: 05:13 min
[INFO] Finished at: 2016-10-31T16:11:53+00:00
[INFO] Final Memory: 171M/432M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project activemqBroker: Failed to deploy artifacts: Could not transfer artifact org.geoserver.community:activemqBroker:war:2.10-20161031.161135-1101 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Failed to transfer file: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.161135-1101.war. Return code is: 413, ReasonPhrase: Request Entity Too Large. -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/44/changes&gt;
Changes:
[tbarsballe] [GEOS-7828] Show style page error messages after clicking submit
[...truncated 15703 lines...]
[INFO]
[INFO]
[INFO]
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (821 B at 14.6 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.170931-1102.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.170931-1102.pom (2 KB at 15.7 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.170931-1102-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.170931-1102-tests.jar (3 KB at 23.7 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Webapp assembled in [307 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.170948-1102.war
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.170948-1102.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.170948-1102.pom (8 KB at 34.0 KB/sec)
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.272 s]
[INFO] Core Platform Module ............................... SUCCESS [ 1.773 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.036 s]
[INFO] Main Module ........................................ SUCCESS [ 27.816 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.806 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.165 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.272 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.981 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.693 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.581 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.943 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 1.792 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 3.590 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.643 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.094 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.384 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 3.325 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.609 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.217 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.415 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.638 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.112 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.656 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.648 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.579 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.767 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 1.695 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.516 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.067 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 34.033 s]
[INFO] Community Space .................................... SUCCESS [ 0.648 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.323 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 5.917 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.023 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.775 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.555 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.878 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.565 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.485 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.652 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.850 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.662 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.902 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.599 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.072 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.555 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.284 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.582 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.323 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.538 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.206 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.121 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.283 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.909 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.554 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.393 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.048 s]
[INFO] DownloadProcess .................................... SUCCESS [ 7.001 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 6.232 s]
[INFO] ActiveMQ ........................................... FAILURE [ 33.273 s]
[INFO] Total time: 05:19 min
[INFO] Finished at: 2016-10-31T17:10:05+00:00
[INFO] Final Memory: 171M/436M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project activemqBroker: Failed to deploy artifacts: Could not transfer artifact org.geoserver.community:activemqBroker:war:2.10-20161031.170948-1102 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Failed to transfer file: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.170948-1102.war. Return code is: 413, ReasonPhrase: Request Entity Too Large. -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/45/&gt;
[...truncated 1786 lines...]
[INFO]
[INFO] Skipping Community Space
[INFO]
[INFO] Skipping OWS request flow controller
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping REST UI Module
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO]
[INFO] Skipping WCS UI Module
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO]
[INFO] Skipping Importer REST Api Module
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO]
[INFO] Skipping CSW UI Module
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.736 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.969 s]
[INFO] Open Web Service Module ............................ FAILURE [ 12.974 s]
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.045 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.056 s]
[INFO] Community Space .................................... SKIPPED
[INFO] Application Schema Support ......................... SUCCESS [ 0.035 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.151 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.458 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.457 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.409 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.396 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.282 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.033 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 1.057 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.631 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.096 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.038 s]
[INFO] Total time: 39.208 s (Wall Clock)
[INFO] Finished at: 2016-10-31T20:52:20+00:00
[INFO] Final Memory: 98M/408M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-ows: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/ows/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/46/&gt;
[...truncated 15626 lines...]
[INFO]
[INFO]
[INFO]
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.212752-1103.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.212752-1103.pom (2 KB at 15.7 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml (418 B at 4.6 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.212752-1103-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161031.212752-1103-tests.jar (3 KB at 19.7 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Webapp assembled in [315 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 25.3 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.212809-1103.war
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.212809-1103.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.212809-1103.pom (8 KB at 33.8 KB/sec)
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.947 s]
[INFO] Core Platform Module ............................... SUCCESS [ 1.750 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.188 s]
[INFO] Main Module ........................................ SUCCESS [ 13.998 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.860 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.830 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.281 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.987 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 2.043 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.627 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.652 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 1.776 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 3.391 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.673 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.254 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.134 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 3.051 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.608 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.980 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.455 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.516 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.095 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.642 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.486 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.773 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 1.755 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.339 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.058 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 34.043 s]
[INFO] Community Space .................................... SUCCESS [ 0.631 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 7.538 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.119 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.923 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.654 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.666 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.580 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.555 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.252 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.729 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 8.035 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.655 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.095 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 26.068 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.077 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 11.017 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.225 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.652 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.411 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.720 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.060 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.297 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.335 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.958 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.520 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.270 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.951 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.603 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 6.333 s]
[INFO] ActiveMQ ........................................... FAILURE [ 34.369 s]
[INFO] Total time: 05:28 min
[INFO] Finished at: 2016-10-31T21:28:27+00:00
[INFO] Final Memory: 170M/430M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project activemqBroker: Failed to deploy artifacts: Could not transfer artifact org.geoserver.community:activemqBroker:war:2.10-20161031.212809-1103 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Failed to transfer file: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161031.212809-1103.war. Return code is: 413, ReasonPhrase: Request Entity Too Large. -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/47/changes&gt;
Changes:
[tbarsballe] [GEOS-7830] Remove GWC from community pom
[...truncated 15639 lines...]
[INFO]
[INFO]
[INFO]
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161101.180246-1104.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161101.180246-1104.pom (2 KB at 16.0 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161101.180246-1104-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161101.180246-1104-tests.jar (3 KB at 23.9 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Webapp assembled in [366 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161101.180316-1104.war
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161101.180316-1104.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161101.180316-1104.pom (8 KB at 33.5 KB/sec)
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.796 s]
[INFO] Core Platform Module ............................... SUCCESS [ 1.954 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.338 s]
[INFO] Main Module ........................................ SUCCESS [ 12.832 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.847 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.706 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.302 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.025 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 4.382 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.613 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.753 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 1.786 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 3.692 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.682 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.376 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.255 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 2.815 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.636 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.287 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.450 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.953 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.092 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.633 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.483 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.608 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.785 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 3.252 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.638 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.139 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 42.521 s]
[INFO] Community Space .................................... SUCCESS [ 0.603 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.355 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.292 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.984 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.574 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.077 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.569 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 5.252 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.712 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.840 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.876 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.102 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 22.821 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.092 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.982 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.333 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.679 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.438 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.708 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.634 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.154 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.405 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.799 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.581 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.713 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.528 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.725 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.185 s]
[INFO] ActiveMQ ........................................... FAILURE [ 47.166 s]
[INFO] Total time: 06:04 min
[INFO] Finished at: 2016-11-01T18:03:33+00:00
[INFO] Final Memory: 170M/446M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project activemqBroker: Failed to deploy artifacts: Could not transfer artifact org.geoserver.community:activemqBroker:war:2.10-20161101.180316-1104 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Failed to transfer file: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161101.180316-1104.war. Return code is: 413, ReasonPhrase: Request Entity Too Large. -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/48/&gt;
[...truncated 15609 lines...]
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161101.201534-1105.pom (2 KB at 15.5 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (842 B at 10.3 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161101.201534-1105-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161101.201534-1105-tests.jar (3 KB at 23.4 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Webapp assembled in [133 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161101.201547-1105.war
Nov 01, 2016 8:16:17 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
INFO: I/O exception (java.net.SocketException) caught when processing request to {s}->https://repo.boundlessgeo.com:443: Connection reset
INFO: Retrying request to {s}->https://repo.boundlessgeo.com:443
Nov 01, 2016 8:16:47 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
Nov 01, 2016 8:17:17 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161101.201547-1105.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161101.201547-1105.pom (8 KB at 34.1 KB/sec)
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 16.650 s]
[INFO] Core Platform Module ............................... SUCCESS [ 2.182 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.098 s]
[INFO] Main Module ........................................ SUCCESS [ 23.097 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.851 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.238 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.417 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.018 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.723 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.838 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.841 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 2.237 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 4.159 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.933 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 9.292 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.179 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 4.416 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.677 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.909 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.682 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.693 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.110 s]
[INFO] Demos Module ....................................... SUCCESS [ 2.017 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.628 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.607 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 2.121 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 1.668 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.393 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.075 s]
[INFO] GeoServer Web Application .......................... SUCCESS [01:27 min]
[INFO] Community Space .................................... SUCCESS [ 0.586 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.142 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.191 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.626 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.145 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.521 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.586 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.916 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.833 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.637 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.732 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.675 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.857 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.811 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.085 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.064 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.373 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.095 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.796 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.742 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.190 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.313 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.329 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.961 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.854 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.159 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.952 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.770 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.156 s]
[INFO] ActiveMQ ........................................... FAILURE [02:12 min]
[INFO] Total time: 08:00 min
[INFO] Finished at: 2016-11-01T20:17:47+00:00
[INFO] Final Memory: 169M/425M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project activemqBroker: Failed to deploy artifacts: Could not transfer artifact org.geoserver.community:activemqBroker:war:2.10-20161101.201547-1105 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Connection reset -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/49/&gt;
[...truncated 16554 lines...]
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161101.211537-1106.pom (2 KB at 14.7 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml (465 B at 8.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (842 B at 10.2 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml (418 B at 4.9 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161101.211537-1106-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20161101.211537-1106-tests.jar (3 KB at 22.9 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (842 B at 10.4 KB/sec)
[INFO]
[INFO] Building ActiveMQ 2.10-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ activemqBroker ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ activemqBroker ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/src/main/java&gt;
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ activemqBroker ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ activemqBroker ---
[INFO] Copying 0 resource
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ activemqBroker ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ activemqBroker ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-war-plugin:2.2:war (default-war) @ activemqBroker ---
[INFO] Packaging webapp
[INFO] Assembling webapp [activemqBroker] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/src/main/webapp\]>
[INFO] Webapp assembled in [132 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT.war&gt;
[INFO] WEB-INF/web.xml already added, skipping
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ activemqBroker ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ activemqBroker ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ activemqBroker ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ activemqBroker ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT.war
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ activemqBroker ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 24.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161101.211552-1106.war
Nov 01, 2016 9:16:22 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
Nov 01, 2016 9:16:52 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
Nov 01, 2016 9:17:22 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161101.211552-1106.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20161101.211552-1106.pom (8 KB at 16.0 KB/sec)
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.393 s]
[INFO] Core Platform Module ............................... SUCCESS [ 1.817 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.233 s]
[INFO] Main Module ........................................ SUCCESS [ 14.420 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.532 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.267 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.331 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.361 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.753 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.649 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 2.016 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 2.247 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 4.220 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.832 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.950 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.184 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 4.599 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.625 s]
[INFO] Core UI Module ..................................... SUCCESS [ 5.080 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.574 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.904 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.271 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.739 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.738 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.598 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.958 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 1.678 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.403 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.073 s]
[INFO] GeoServer Web Application .......................... SUCCESS [01:28 min]
[INFO] Community Space .................................... SUCCESS [ 0.598 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.150 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.366 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.675 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.597 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.366 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.593 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.552 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.726 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.653 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.679 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.983 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.858 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.283 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.843 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.611 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.593 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.926 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.689 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.280 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.938 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.521 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.905 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.721 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.061 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.148 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.711 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.542 s]
[INFO] ActiveMQ ........................................... FAILURE [02:14 min]
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 07:46 min
[INFO] Finished at: 2016-11-01T21:17:52+00:00
[INFO] Final Memory: 169M/432M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project activemqBroker: Failed to deploy artifacts: Could not transfer artifact org.geoserver.community:activemqBroker:war:2.10-20161101.211552-1106 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Connection reset -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :activemqBroker
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/50/&gt;
