See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/51/>
[...truncated 10743 lines...]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/src/main/resources>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/src/main/java>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-app ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-app ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-app ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/test-classes>
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.81 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.352 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/surefire-reports>
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.091 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.231 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/src/main/webapp\]>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Webapp assembled in [536 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.war
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.671 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.026 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.597 s]
[INFO] Main Module ........................................ SUCCESS [02:38 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.150 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 58.033 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:52 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.526 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 27.492 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.991 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.068 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:16 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.175 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:14 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.859 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:17 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.100 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 30.850 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.850 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.601 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.204 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.769 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.237 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:19 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:46 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:11 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.840 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.077 s]
[INFO] Printing Module .................................... SUCCESS [ 13.982 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.232 s]
[INFO] Community Space .................................... SUCCESS [ 0.064 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.042 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.374 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.410 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.421 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.484 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.643 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.302 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.457 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.359 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.700 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.391 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.037 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.994 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.533 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.055 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:37 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.590 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.075 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.692 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.839 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.740 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.792 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 27.632 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 26.965 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.802 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.396 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.109 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.316 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.307 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.081 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.682 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.054 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.115 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.730 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.750 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.817 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.074 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.246 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.357 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.435 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.455 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.043 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.888 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.517 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.064 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.014 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.341 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.045 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.086 s]
[INFO] Importer Core Module ............................... SUCCESS [ 47.823 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 42.756 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.421 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.523 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 20.851 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.191 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.953 s]
[INFO] BUILD SUCCESS
[INFO] Total time: 21:26 min (Wall Clock)
[INFO] Finished at: 2016-11-02T17:32:31+00:00
[INFO] Final Memory: 115M/263M
[geoserver-2.10.x] $ mvn -f src/community/pom.xml -B -U-DskipTests -PcommunityRelease clean install -DconfigDirectory=../../../../data -T2 -fae
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
