[Geoserver-devel] Build failed in Jenkins: geoserver-2.10.x #66
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/66/&gt;
[...truncated 14828 lines...]
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-rest ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-rest ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-jms-geoserver ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-jms-geoserver ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.10-SNAPSHOT/gs-backup-restore-rest-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Extensions 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-extension ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-extension ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-jms-geoserver ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jms-geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.10-SNAPSHOT/gs-jms-geoserver-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.10-SNAPSHOT/gs-backup-restore-extension-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.10-SNAPSHOT/gs-backup-restore-web-2.10-SNAPSHOT-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 7.216 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 13.007 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.548 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.944 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.043 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.790 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 3.243 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.250 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.058 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.779 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 28.612 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 14.559 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.173 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 5.461 s]
[INFO] WMS-EO ............................................. SUCCESS [ 8.036 s]
[INFO] ColorMap ........................................... SUCCESS [ 7.467 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 9.680 s]
[INFO] GeoServer GeoPackage Extension ..................... FAILURE [ 5.706 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.327 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.542 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.737 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.651 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.124 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.170 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.831 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.316 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.902 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.150 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.552 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.258 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.922 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.256 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.675 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.993 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.787 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.386 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 7.923 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.196 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.664 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.784 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.897 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.026 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 11.136 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.068 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.329 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.085 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.000 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 12.871 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.074 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 6.871 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.144 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.215 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.175 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 6.807 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 19.193 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.493 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.027 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.048 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 5.771 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:55 min (Wall Clock)
[INFO] Finished at: 2016-11-07T15:26:13+00:00
[INFO] Final Memory: 135M/422M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geopkg: Compilation failure
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/ws/src/community/geopkg/src/test/java/org/geoserver/geopkg/GeoPackageGetMapOutputFormatTest.java&gt;:\[64,25\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geopkg
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/67/changes&gt;
Changes:
[afabiani] - Backup & Restore Plugin Assembly Dependencies
[...truncated 14936 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Community Space .................................... SUCCESS [ 10.147 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 15.248 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.406 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.572 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.446 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.109 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.645 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.255 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.424 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.813 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.385 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.619 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.361 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.899 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.575 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.336 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 9.229 s]
[INFO] GeoServer GeoPackage Extension ..................... FAILURE [ 5.699 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.297 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.859 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.060 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.491 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.196 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.981 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.816 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 6.194 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.685 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 11.975 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.760 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.505 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.780 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 8.870 s]
[INFO] GeoFence Server .................................... SUCCESS [ 8.596 s]
[INFO] REST SLD service ................................... SUCCESS [ 7.410 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.702 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.698 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 7.773 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.960 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.605 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.555 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.322 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.018 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.324 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.137 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 4.820 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.060 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 4.424 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 13.588 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.047 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 7.214 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.724 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.619 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.138 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 6.476 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 24.030 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.507 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.116 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.061 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 7.168 s]
[INFO] Total time: 03:13 min (Wall Clock)
[INFO] Finished at: 2016-11-07T19:35:49+00:00
[INFO] Final Memory: 134M/435M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/68/changes&gt;
Changes:
[...truncated 14912 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Community Space .................................... SUCCESS [ 7.645 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 14.986 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.243 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.651 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.139 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.246 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 3.470 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.908 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.047 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.981 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 24.145 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.768 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.644 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.998 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.908 s]
[INFO] ColorMap ........................................... SUCCESS [ 7.590 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 10.415 s]
[INFO] GeoServer GeoPackage Extension ..................... FAILURE [ 5.748 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.418 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.480 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.003 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.608 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.349 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.109 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.078 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.167 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.291 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.450 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.779 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.709 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.095 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.235 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.305 s]
[INFO] REST SLD service ................................... SUCCESS [ 7.421 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.719 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.175 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.289 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.215 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.458 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.848 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.531 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.041 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 11.033 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 6.106 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.417 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.143 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.218 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 13.285 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.080 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 7.248 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.578 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.472 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.424 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 8.647 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 21.199 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.370 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.362 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.403 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 6.065 s]
[INFO] Total time: 03:59 min (Wall Clock)
[INFO] Finished at: 2016-11-08T11:48:35+00:00
[INFO] Final Memory: 134M/369M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x/69/changes&gt;
