[Geoserver-devel] Build failed in Jenkins: geoserver-2.10.x-nightly #123
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/123/changes&gt;
Changes:
[jd] Add routes for indexing commands in geogig.
[tbarsballe] [GEOS-7873] Workaround for JSON array serialization of nulls
[...truncated 5940 lines...]
[INFO] Copying 0 resource
[INFO] Copying 23 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-resource ---
[INFO] Compiling 11 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-resource ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-resource ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-resource ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-resource ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-resource ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-resource ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-resource ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-web-resource ---
[INFO] Copying gwc-core-1.10-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/dependency/gwc-core-1.10-SNAPSHOT.jar&gt;
[INFO] Copying gt-api-16-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/dependency/gt-api-16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-resource ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/community/web-resource/target/gs-web-resource-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-resource/2.10-SNAPSHOT/gs-web-resource-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Application Schema Support 2.10-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-app-schema ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/extension/app-schema/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-app-schema ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-app-schema ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-app-schema ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/extension/app-schema/target/gs-app-schema-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-app-schema ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-app-schema ---
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-app-schema ---
[INFO] Copying gwc-core-1.10-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/extension/app-schema/target/dependency/gwc-core-1.10-SNAPSHOT.jar&gt;
[INFO] Copying gt-api-16-SNAPSHOT.jar to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/extension/app-schema/target/dependency/gt-api-16-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-app-schema ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/extension/app-schema/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema/2.10-SNAPSHOT/gs-app-schema-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/ws/src/extension/app-schema/target/gs-app-schema-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-app-schema/2.10-SNAPSHOT/gs-app-schema-2.10-SNAPSHOT-tests.jar
[INFO]
[INFO] Building Application Schema Integration Test 2.10-SNAPSHOT
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-jdbc/16-SNAPSHOT/gt-jdbc-16-20170203.122354-818-tests.jar
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.999 s]
[INFO] Core Platform Module ............................... SUCCESS [ 5.582 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.469 s]
[INFO] Main Module ........................................ SUCCESS [ 24.422 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.093 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 5.094 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.788 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.569 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 5.882 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 6.620 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 7.769 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 12.220 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 14.243 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 6.749 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 9.718 s]
[INFO] REST Support Module ................................ SUCCESS [ 4.689 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 9.679 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.042 s]
[INFO] Core UI Module ..................................... SUCCESS [ 12.081 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.023 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 3.801 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 6.597 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 7.526 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 3.923 s]
[INFO] Demos Module ....................................... SUCCESS [ 5.738 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 5.583 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.701 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 8.742 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 4.614 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 4.747 s]
[INFO] REST UI Module ..................................... SUCCESS [ 4.134 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 14.256 s]
[INFO] Community Space .................................... SUCCESS [ 2.931 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 21.117 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 5.065 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 3.446 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 6.618 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 2.390 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.044 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 10.181 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.127 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 5.743 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 4.826 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.742 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 13.747 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 3.236 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 5.322 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 5.219 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.715 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.561 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.698 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 4.997 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.485 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.046 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 4.915 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.228 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.153 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 4.682 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.432 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.047 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.842 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.847 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 15.889 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 5.781 s]
[INFO] Solr Module ........................................ SUCCESS [ 4.241 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.333 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 5.859 s]
[INFO] GeoFence Server .................................... SUCCESS [ 5.876 s]
[INFO] REST SLD service ................................... SUCCESS [ 5.629 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.534 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 4.902 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.163 s]
[INFO] Importer Core Module ............................... SUCCESS [ 8.729 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 5.908 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 4.070 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 4.643 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 1.980 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 4.405 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.036 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.861 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.060 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 4.887 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.772 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 4.338 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 4.993 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 4.374 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 8.489 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.058 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 5.690 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 4.797 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.332 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.021 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.266 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 4.203 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 4.558 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 4.567 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 4.366 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 2.915 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 7.179 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.020 s]
[INFO] Application Schema Integration Test ................ FAILURE [01:10 min]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:19 min
[INFO] Finished at: 2017-02-04T05:54:28+00:00
[INFO] Final Memory: 203M/480M
[ERROR] Failed to execute goal on project gs-app-schema-test: Could not resolve dependencies for project org.geoserver.extension:gs-app-schema-test:jar:2.10-SNAPSHOT: Could not transfer artifact org.geotools:gt-jdbc:jar:tests:16-20170203.122354-818 from/to boundless (https://repo.boundlessgeo.com/main/): Connect to repo.boundlessgeo.com:443 [repo.boundlessgeo.com/52.22.156.115] failed: Connection timed out -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-app-schema-test
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.10.x-nightly/124/&gt;
