See <https://build.geoserver.org/job/geoserver-2.11.x/184/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-7961] WFS service sometimes fails due to encode filter NPEx
[...truncated 523.05 KB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/csw/web-csw/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.66 sec
Running org.geoserver.wcs2_0.eo.DescribeOECoverageSetTest
ERROR: 'Invalid dimension name abc, the only valid values by WCS EO spec are Long, Lat and phenomenonTime'
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.306 sec
Running org.geoserver.wcs2_0.eo.GetCapabilitiesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.552 sec
Running org.geoserver.wcs2_0.eo.GetCoverageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.51 sec
Running org.geoserver.wcs2_0.eo.GranuleCoverageExtensionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.267 sec
Results :
Tests run: 31, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wcs2_0-eo-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wcs2_0-eo-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wcs2_0-eo-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wcs2_0-eo-core ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wcs2_0-eo-core ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.11-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.11-SNAPSHOT/gs-wcs2_0-eo-core-2.11-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/core/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.11-SNAPSHOT/gs-wcs2_0-eo-core-2.11-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.11-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.11-SNAPSHOT/gs-wcs2_0-eo-core-2.11-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.11-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.11-SNAPSHOT/gs-wcs2_0-eo-core-2.11-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.11-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.11-SNAPSHOT/gs-wcs2_0-eo-core-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Coverage Service 2.0 Earth Observation GUI extension 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-wcs2_0-eo ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wcs2_0-eo ---
[INFO] Copying 3 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs2_0-eo ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wcs2_0-eo ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/surefire-reports>
T E S T S
Running org.geoserver.wcs2_0.eo.web.WCSEOAdminPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.19 sec
Running org.geoserver.wcs2_0.eo.web.WCSEOLayerConfigTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.325 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.11-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.11-SNAPSHOT/gs-web-wcs2_0-eo-2.11-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.11-SNAPSHOT/gs-web-wcs2_0-eo-2.11-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.11-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.11-SNAPSHOT/gs-web-wcs2_0-eo-2.11-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.11-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.11-SNAPSHOT/gs-web-wcs2_0-eo-2.11-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.11-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.11-SNAPSHOT/gs-web-wcs2_0-eo-2.11-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.117 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.597 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.738 s]
[INFO] Main Module ........................................ SUCCESS [02:15 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.114 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.828 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 28.600 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.256 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 22.810 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 31.187 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.382 s]
[INFO] Web Feature Service Module ......................... FAILURE [ 16.693 s]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SUCCESS [ 24.174 s]
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.069 s]
[INFO] Core UI Module ..................................... SUCCESS [01:19 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.057 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.068 s]
[INFO] Printing Module .................................... SUCCESS [ 14.362 s]
[INFO] Community Space .................................... SUCCESS [ 0.037 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.029 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.608 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.905 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.474 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.231 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.197 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.205 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.286 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.033 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.592 s]
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.041 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.471 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.215 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.550 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.615 s]
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.313 s]
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.053 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.606 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 12.061 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.519 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 13.760 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.049 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.028 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 17.328 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.137 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.047 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 06:51 min (Wall Clock)
[INFO] Finished at: 2017-12-09T10:58:17+00:00
[INFO] Final Memory: 117M/1004M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wfs: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-2.11.x/ws/src/wfs/src/test/java/org/geoserver/wfs/v1_1/GetFeatureTest.java>:\[708,57\] error: incompatible types: int cannot be converted to List<Exception>
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
