See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/6/changes>
Changes:
[jd] Update geogig plugin to work with additional parameter options.
[...truncated 15487 lines...]
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.11-SNAPSHOT/gs-backup-restore-extension-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/extension/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.11-SNAPSHOT/gs-backup-restore-extension-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.11-SNAPSHOT/gs-backup-restore-extension-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.11-SNAPSHOT/gs-backup-restore-extension-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.11-SNAPSHOT/gs-backup-restore-extension-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer notification event system 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-notification ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-notification ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-notification ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-notification ---
[INFO] Copying 1 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-notification ---
[INFO] Compiling 11 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/web/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.11-SNAPSHOT/gs-backup-restore-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.11-SNAPSHOT/gs-backup-restore-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.11-SNAPSHOT/gs-backup-restore-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.11-SNAPSHOT/gs-backup-restore-web-2.11-SNAPSHOT-sources.jar
[INFO]
[INFO] Building OpenSearch for EO web UI 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-oseo ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-oseo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-oseo ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-oseo ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-notification ---
[INFO] Copying 0 resource
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-notification ---
[INFO] Compiling 9 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-notification ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target/gs-notification-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target/gs-notification-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target/gs-notification-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target/gs-notification-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target/gs-notification-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.11-SNAPSHOT/gs-notification-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.11-SNAPSHOT/gs-notification-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target/gs-notification-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.11-SNAPSHOT/gs-notification-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target/gs-notification-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.11-SNAPSHOT/gs-notification-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/notification/target/gs-notification-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.11-SNAPSHOT/gs-notification-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.11-SNAPSHOT/gs-web-oseo-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.11-SNAPSHOT/gs-web-oseo-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.11-SNAPSHOT/gs-web-oseo-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.11-SNAPSHOT/gs-web-oseo-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.11-SNAPSHOT/gs-web-oseo-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 8.326 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 27.332 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 10.760 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.321 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.478 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.332 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.400 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.818 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.946 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.730 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.522 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 8.822 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.315 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.538 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.201 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.341 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 10.896 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.150 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.541 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.504 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.332 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.566 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.693 s]
[INFO] DownloadProcess .................................... SUCCESS [ 9.714 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.791 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.019 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.643 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 13.602 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.787 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.699 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.988 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 8.169 s]
[INFO] GeoFence Server .................................... SUCCESS [ 7.000 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.948 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.098 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.555 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.052 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.522 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.713 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.341 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.016 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 14.193 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 4.065 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.614 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.823 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 19.390 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.059 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 10.716 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 7.146 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.589 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.442 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.243 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 42.456 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 6.193 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.618 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.364 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 4.696 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.358 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.310 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.438 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 4.648 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.647 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.027 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 6.932 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 4.867 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 6.595 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:51 min (Wall Clock)
[INFO] Finished at: 2017-03-23T22:23:42+00:00
[INFO] Final Memory: 142M/725M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-geogig: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportRepoCommandResource.java>:\[15,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportRepoCommandResource.java>:\[21,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportExistingRepo.java>:\[17,7\] error: constructor AbstractWebAPICommand in class AbstractWebAPICommand cannot be applied to given types;
[ERROR] actual and formal argument lists differ in length
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/ImportExistingRepo.java>:\[19,1\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[26,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[32,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.11.x/ws/src/community/geogig/src/main/java/org/geogig/geoserver/rest/InitCommandResource.java>:\[34,45\] error: no suitable method found for runCommand(Variant,Request,MediaType)
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
