See <https://build.geoserver.org/job/geoserver-2.12.x/102/display/redirect>
[...truncated 12.13 MB...]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-app ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-app ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-app ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [225 msecs]
[INFO] Building war: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-web-app ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/maven-metadata.xml (2 KB at 191.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-20171224.185627-1277.jar
Dec 24, 2017 6:58:56 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
INFO: I/O exception (java.net.SocketException) caught when processing request to {s}->https://repo.boundlessgeo.com:443: Broken pipe (Write failed)
INFO: Retrying request to {s}->https://repo.boundlessgeo.com:443
Dec 24, 2017 7:00:49 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
Dec 24, 2017 7:02:45 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-20171224.185627-1277.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-20171224.185627-1277.pom (46 KB at 583.7 KB/sec)
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.048 s]
[INFO] Core Platform Module ............................... SUCCESS [ 0.803 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 2.324 s]
[INFO] Main Module ........................................ SUCCESS [ 9.025 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.381 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 0.304 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 0.288 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.228 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 0.614 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 0.497 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 0.537 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 0.770 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 1.787 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 0.740 s]
[INFO] gs-rest ............................................ SUCCESS [ 0.304 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 1.290 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 5.002 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.089 s]
[INFO] Core UI Module ..................................... SUCCESS [ 1.393 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 0.584 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 0.348 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 0.214 s]
[INFO] Demos Module ....................................... SUCCESS [ 0.445 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 0.492 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.127 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 0.577 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 0.582 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 0.479 s]
[INFO] REST UI Module ..................................... SUCCESS [ 0.242 s]
[INFO] GeoServer Web Application .......................... FAILURE [08:12 min]
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] SpatiaLite Extension ............................... SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] Aggregating Data Store ............................. SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer Scripting Extensions ..................... SKIPPED
[INFO] Core Scripting Extension ........................... SKIPPED
[INFO] Web UI Scripting Extension ......................... SKIPPED
[INFO] BeanShell Scripting Extension ...................... SKIPPED
[INFO] Groovy Scripting Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] JavaScript Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension ........................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] GeoServer Mapbox Styling ........................... SKIPPED
[INFO] GeoServer Status Monitoring Module ................. SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] S3 Geotiff Support ................................. SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 08:51 min
[INFO] Finished at: 2017-12-24T19:04:36+00:00
[INFO] Final Memory: 171M/1046M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gs-web-app: Failed to deploy artifacts: Could not transfer artifact org.geoserver.web:gs-web-app:jar:2.12-20171224.185627-1277 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Broken pipe (Write failed) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-app
