[Geoserver-devel] Build failed in Jenkins: geoserver-2.12.x #182
See <https://build.geoserver.org/job/geoserver-2.12.x/182/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-8352] Number of decimals ignored for GML 3.2 output (#2792)
[...truncated 4.23 MB...]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wcs2_0-eo-core ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.12-SNAPSHOT/gs-wcs2_0-eo-core-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/core/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.12-SNAPSHOT/gs-wcs2_0-eo-core-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.12-SNAPSHOT/gs-wcs2_0-eo-core-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.12-SNAPSHOT/gs-wcs2_0-eo-core-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.12-SNAPSHOT/gs-wcs2_0-eo-core-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Coverage Service 2.0 Earth Observation GUI extension 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-wcs2_0-eo ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wcs2_0-eo ---
[INFO] Copying 3 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs2_0-eo ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wcs2_0-eo ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wcs2_0.eo.web.WCSEOAdminPanelTest
Mar 12, 2018 1:59:22 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerConfigurationLock', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ResourcePool', but ApplicationContext is unset.
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
Mar 12, 2018 1:59:22 PM org.geotools.image.ImageWorker <clinit>
INFO: Warp/affine reduction enabled: true
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Mar 12, 2018 1:59:23 PM org.geoserver.platform.GeoServerExtensions checkContext
Mar 12, 2018 1:59:24 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.811 sec
Running org.geoserver.wcs2_0.eo.web.WCSEOLayerConfigTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.892 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.170 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.511 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.708 s]
[INFO] Main Module ........................................ SUCCESS [01:48 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.066 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.066 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 21.016 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.553 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 19.974 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 22.765 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 40.492 s]
[INFO] Web Feature Service Module ......................... FAILURE [01:20 min]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 15.600 s]
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.101 s]
[INFO] Core UI Module ..................................... SUCCESS [01:01 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.053 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.040 s]
[INFO] Printing Module .................................... SUCCESS [ 12.551 s]
[INFO] Community Space .................................... SUCCESS [ 0.022 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.925 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.905 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.386 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.222 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.208 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.466 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.447 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.033 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.576 s]
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.475 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.267 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.441 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.286 s]
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.359 s]
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.051 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 9.713 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.909 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 32.710 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.523 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.027 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 16.283 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 8.916 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 16.699 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 06:09 min (Wall Clock)
[INFO] Finished at: 2018-03-12T13:59:27+00:00
[INFO] Final Memory: 120M/1020M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <https://build.geoserver.org/job/geoserver-2.12.x/183/display/redirect&gt;
