[Geoserver-devel] Build failed in Jenkins: geoserver-2.12.x #199
See <https://build.geoserver.org/job/geoserver-2.12.x/199/display/redirect&gt;
[...truncated 10.92 MB...]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [275 msecs]
[INFO] Building war: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/geoserver.war&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/web/app/target/geoserver.war&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/target/classes&gt;
Apr 21, 2018 3:45:24 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Apr 21, 2018 3:45:25 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 27
Apr 21, 2018 3:45:26 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 35
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
Apr 21, 2018 3:45:26 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 17.041 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Apr 21, 2018 3:45:27 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Apr 21, 2018 3:45:27 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.878 sec
Results :
Tests run: 60, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.12-SNAPSHOT/gs-importer-rest-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.12-SNAPSHOT/gs-importer-rest-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.12-SNAPSHOT/gs-importer-rest-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.12-SNAPSHOT/gs-importer-rest-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.12-SNAPSHOT/gs-importer-rest-2.12-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.731 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.746 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.904 s]
[INFO] Main Module ........................................ SUCCESS [01:47 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.068 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 36.283 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.586 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.284 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 20.436 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 23.062 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 35.673 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:19 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:53 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 28.804 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.452 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:42 min]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:24 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.065 s]
[INFO] Core UI Module ..................................... SUCCESS [01:00 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.722 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.116 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.698 s]
[INFO] Demos Module ....................................... SUCCESS [ 16.787 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.480 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.036 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:36 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:17 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 28.618 s]
[INFO] REST UI Module ..................................... SUCCESS [ 14.135 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.054 s]
[INFO] Printing Module .................................... SUCCESS [ 12.385 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.456 s]
[INFO] Community Space .................................... SUCCESS [ 0.024 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.024 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:24 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.705 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.148 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.769 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.971 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.397 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.227 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.220 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.222 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.465 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.295 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.959 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.009 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.018 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:05 min]
[INFO] Excel Output Format ................................ SUCCESS [ 11.840 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.500 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.932 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.486 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.699 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.359 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.654 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.029 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.209 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 7.570 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.040 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.823 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.049 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.992 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 18.629 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 32.020 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 17.844 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.070 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.811 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.306 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.576 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.632 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.032 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.626 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 14.994 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.370 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.757 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.051 s]
[INFO] Importer Core Module ............................... SUCCESS [ 33.479 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 44.035 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.793 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.926 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.330 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.970 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 30.923 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.929 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 13.911 s]
[INFO] BUILD FAILURE
[INFO] Total time: 16:52 min (Wall Clock)
[INFO] Finished at: 2018-04-21T15:45:28+00:00
[INFO] Final Memory: 142M/1078M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <https://build.geoserver.org/job/geoserver-2.12.x/200/display/redirect?page=changes&gt;
