[Geoserver-devel] Build failed in Jenkins: geoserver-2.12.x #20
See <https://build.geoserver.org/job/geoserver-2.12.x/20/display/redirect?page=changes&gt;
Changes:
[tbarsballe] re-add gwc-s3 community module to the build
[...truncated 17.17 MB...]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-notification ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-notification ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-notification ---
[INFO] Copying 1 resource
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-notification ---
[INFO] Compiling 11 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-gdal-wps ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-gdal-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-gdal-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-gdal-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-gdal-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-gdal-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.12-SNAPSHOT/gs-gdal-wps-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.12-SNAPSHOT/gs-gdal-wps-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.12-SNAPSHOT/gs-gdal-wps-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.12-SNAPSHOT/gs-gdal-wps-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.12-SNAPSHOT/gs-gdal-wps-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO web UI 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-oseo ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-oseo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-oseo ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-oseo ---
[INFO] Compiling 3 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-notification ---
[INFO] Copying 0 resource
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-notification ---
[INFO] Compiling 9 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-notification ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO REST configuration API 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-oseo-rest ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest ---
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest ---
[INFO] Copying 28 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest ---
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.12-SNAPSHOT/gs-oseo-rest-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.12-SNAPSHOT/gs-oseo-rest-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.12-SNAPSHOT/gs-oseo-rest-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.12-SNAPSHOT/gs-oseo-rest-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.12-SNAPSHOT/gs-oseo-rest-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 5.697 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 12.975 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.075 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.078 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 9.405 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.673 s]
[INFO] WMS-EO ............................................. SUCCESS [ 8.225 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.012 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 11.399 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.824 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 1.884 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.077 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.382 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.747 s]
[INFO] DownloadProcess .................................... SUCCESS [ 7.152 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.292 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.452 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.251 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.044 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 8.108 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.581 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 8.027 s]
[INFO] GeoFence Server .................................... SUCCESS [ 9.026 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.698 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 9.574 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 6.081 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 6.332 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.660 s]
[INFO] GeoWebCache S3 ..................................... FAILURE [ 2.807 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.026 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.004 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.372 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.998 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 4.723 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 28.810 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 4.504 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 17.246 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 6.338 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.781 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.635 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.799 s]
[INFO] gs-notification-common ............................. SUCCESS [ 0.972 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.661 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 3.358 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 1.729 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.036 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 8.988 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 5.463 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 4.556 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 6.208 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 6.199 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 6.819 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.893 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 2.794 s]
[INFO] BUILD FAILURE
[INFO] Total time: 02:52 min (Wall Clock)
[INFO] Finished at: 2017-10-06T22:27:20+00:00
[INFO] Final Memory: 126M/928M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc-s3: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gwc-s3/src/main/java/org/geoserver/gwc/web/blob/S3BlobStoreType.java&gt;:\[17,35\] error: constructor S3BlobStoreConfig in class S3BlobStoreConfig cannot be applied to given types;
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc-s3
[locks-and-latches] Releasing all the locks
[locks-and-latches] All the locks released
Not sending mail to unregistered user tbarsballe@anonymised.com
Torben,
there is no Jenkins geowebcache-1.12.x on ares or apollo, so nothing to build GeoWebCache 1.12-SNAPSHOT artifacts containing the backport of GeoWebCache #546:
https://github.com/GeoWebCache/geowebcache/pull/546
geoserver-2.12.x fails because it is building against the stale artifacts built when geowebcache master was 2.12-SNAPSHOT.
Kind regards,
Ben.
Changes:
[...]> [ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-gwc-s3: Compilation failure
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Typo: should be: geoserver-2.12.x fails because it is building against the stale artifacts built when geowebcache master was 1.12-SNAPSHOT.
Director
New Zealand
FYI Torben has created the missing Jenkins job. It has completed and the geoserver-2.12.x job is now running.
Kind regards,
Director
New Zealand
See <https://build.geoserver.org/job/geoserver-2.12.x/21/display/redirect&gt;
Nick,
As build.geoserver.org ramps up to become the primary build server, it is probably a bad idea to have your own email configured as the source of the build server notifications.
Would you be able to change it to something like monitor@anonymised.com ?
Torben
On Fri, Oct 6, 2017 at 3:27 PM, <nstires@anonymised.com> wrote:
See <https://build.geoserver.org/job/geoserver-2.12.x/20/display/redirect?page=changes>
Changes:
[…truncated 17.17 MB…]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target>
[INFO]
[INFO] — cobertura-maven-plugin:2.6:clean (default) @ gs-notification —
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-notification —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-notification —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-notification —
[INFO] Compiling 11 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/classes>
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-gdal-wps —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-gdal-wps —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-gdal-wps —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-gdal-wps —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-gdal-wps —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-gdal-wps —
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.12-SNAPSHOT/gs-gdal-wps-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.12-SNAPSHOT/gs-gdal-wps-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.12-SNAPSHOT/gs-gdal-wps-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.12-SNAPSHOT/gs-gdal-wps-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.12-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.12-SNAPSHOT/gs-gdal-wps-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-web-oseo —
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target>
[INFO]
[INFO] — cobertura-maven-plugin:2.6:clean (default) @ gs-web-oseo —
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-web-oseo —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-web-oseo —
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-oseo —
[INFO] Compiling 3 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/classes>
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-notification —
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-notification —
[INFO] Compiling 9 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/test-classes>
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo —
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/src/test/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo —
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/test-classes>
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-notification —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-notification —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-notification —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-notification —
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-oseo-rest —
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target>
[INFO]
[INFO] — cobertura-maven-plugin:2.6:clean (default) @ gs-oseo-rest —
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-oseo-rest —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-oseo-rest —
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-oseo-rest —
[INFO] Compiling 13 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/classes>
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-oseo —
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-oseo-rest —
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-oseo-rest —
[INFO] Compiling 4 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/test-classes>
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-oseo-rest —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-oseo-rest —
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-oseo-rest —
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.12-SNAPSHOT/gs-oseo-rest-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.12-SNAPSHOT/gs-oseo-rest-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.12-SNAPSHOT/gs-oseo-rest-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.12-SNAPSHOT/gs-oseo-rest-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/oseo/oseo-rest/target/gs-oseo-rest-2.12-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/community/gs-oseo-rest/2.12-SNAPSHOT/gs-oseo-rest-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO] Community Space … SUCCESS [ 5.697 s]
[INFO] Authentication by unique url key … SUCCESS [ 12.975 s]
[INFO] WorldWind Format Module … SUCCESS [ 7.075 s]
[INFO] SpatiaLite Extension … SUCCESS [ 6.078 s]
[INFO] GeoServer JDBC KV Catalog … SUCCESS [ 9.405 s]
[INFO] Aggregating Data Store … SUCCESS [ 3.673 s]
[INFO] WMS-EO … SUCCESS [ 8.225 s]
[INFO] ColorMap … SUCCESS [ 5.012 s]
[INFO] GeoServer mbtiles Extension … SUCCESS [ 11.399 s]
[INFO] GeoServer GeoPackage Extension … SUCCESS [ 6.824 s]
[INFO] Dynamic WMS dimension value defaults … SUCCESS [ 6.077 s]
[INFO] GPX PPIO for WPS … SUCCESS [ 5.382 s]
[INFO] KML PPIO for WPS … SUCCESS [ 5.747 s]
[INFO] DownloadProcess … SUCCESS [ 7.152 s]
[INFO] GeoServer JMS based clustering modules … SUCCESS [ 0.292 s]
[INFO] ActiveMQ … SUCCESS [ 4.452 s]
[INFO] GeoServer JMS clustering Commons module … SUCCESS [ 2.251 s]
[INFO] GeoServer JMS clustering module … SUCCESS [ 12.044 s]
[INFO] GeoServer Hazelcast Clustering Module … SUCCESS [ 8.108 s]
[INFO] Solr Module … SUCCESS [ 5.581 s]
[INFO] GeoFence security integration … SUCCESS [ 8.027 s]
[INFO] GeoFence Server … SUCCESS [ 9.026 s]
[INFO] Parameters Extractor … SUCCESS [ 6.698 s]
[INFO] WPS cluster on jdbc datastores … SUCCESS [ 6.081 s]
[INFO] ncWMS compatibility extension … SUCCESS [ 6.332 s]
[INFO] GWC Distributed Caching Plugin … SUCCESS [ 2.660 s]
[INFO] GeoWebCache S3 … FAILURE [ 2.807 s]
[INFO] GDAL translate parent … SUCCESS [ 0.026 s]
[INFO] GDAL translate WCS … SUCCESS [ 6.004 s]
[INFO] GDAL translate WPS … SUCCESS [ 5.372 s]
[INFO] GeoServer JDBC Configuration Resource Store … SUCCESS [ 6.998 s]
[INFO] GeoWebCache SQLite … SUCCESS [ 4.723 s]
[INFO] GeoGig GeoServer integration … SUCCESS [ 28.810 s]
[INFO] WMTS Multi Dimensional … SUCCESS [ 4.504 s]
[INFO] GeoServer OAuth2 Connect Security Module … SUCCESS [ 17.246 s]
[INFO] GeoServer OneLogin Module … SUCCESS [ 3.799 s]
[INFO] gs-notification-common … SUCCESS [ 0.972 s]
[INFO] OWS Dispatcher Simulate Plugin … SUCCESS [ 3.358 s]
[INFO] JDBC Metrics Plugin … SUCCESS [ 1.729 s]
[INFO] OpenSearch EO parent … SUCCESS [ 0.036 s]
[INFO] OpenSearch for EO … SUCCESS [ 8.988 s]
[INFO] OpenSearch for EO web UI … SUCCESS [ 5.463 s]
[INFO] OpenSearch for EO REST configuration API … SUCCESS [ 4.556 s]
[INFO] GeoServer Mapbox Styling … SUCCESS [ 6.208 s]
[INFO] GeoServer Status Monitoring Module … SUCCESS [ 6.199 s]
[INFO] GeoServer Community Release Module … SKIPPED
[INFO] GeoServer Resource Browser … SUCCESS [ 6.819 s]
[INFO] GeoServer notification event system … SUCCESS [ 5.893 s]
[INFO] S3 Geotiff Support … SUCCESS [ 2.794 s]
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/gwc-s3/src/main/java/org/geoserver/gwc/web/blob/S3BlobStoreType.java>:[17,35] error: constructor S3BlobStoreConfig in class S3BlobStoreConfig cannot be applied to given types;
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-gwc-s3
Build step ‘Invoke top-level Maven targets’ marked build as failure
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
