[Geoserver-devel] Build failed in Jenkins: geoserver-2.12.x #225
See <https://build.geoserver.org/job/geoserver-2.12.x/225/display/redirect?page=changes&gt;
Changes:
[github] [GEOS-8729] MongoDB extension descriptor missing in the main pom.xml
[Andrea Aime] [GEOS-8743] Move monitoring-hibernate extension down to community module
Started by an SCM change
Building remotely on apollo-slave-01 in workspace <https://build.geoserver.org/job/geoserver-2.12.x/ws/&gt;
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/2.12.x^{commit} # timeout=10
Checking out Revision f01acb69958a255fec74419c83dee75561c23cec (origin/2.12.x)
> git config core.sparsecheckout # timeout=10
> git checkout -f f01acb69958a255fec74419c83dee75561c23cec
> git rev-list c88f8604a7a1e390895c58d9a007d7ca1f840384 # timeout=10
[geoserver-2.12.x] $ mvn -f src/pom.xml -B -U -P allExtensions,printing,secJdbcJndiTest clean install -DconfigDirectory=../../../data -T2 -fae -DquietTests=false
[INFO] Scanning for projects...
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[FATAL] Non-parseable POM <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/pom.xml&gt;: unexpected character in markup < (position: END_TAG seen ...</descriptor>\n<<... @88:3) @ line 88, column 3
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: org.geoserver.extension:gs-ogr-wfs:jar:tests -> duplicate declaration of version ${gs.version} @ org.geoserver.extension:gs-ogr-wps:[unknown-version], <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/ogr/ogr-wps/pom.xml,&gt; line 62, column 21
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-wps-core:${gs.version}, <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-core/pom.xml,&gt; line 21, column 14
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-wps-cluster-hazelcast:${gs.version}, <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml,&gt; line 19, column 12
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-web-wps:${gs.version}, <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wps/web-wps/pom.xml,&gt; line 21, column 14
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: org.springframework:spring-test:jar -> version ${spring.version} vs (?) @ org.geoserver.extension:gs-monitor:[unknown-version], <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/monitor/pom.xml,&gt; line 66, column 15
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: org.geoserver:gs-wms:jar:tests -> duplicate declaration of version ${project.version} @ org.geoserver.extension:gs-vectortiles:[unknown-version], <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/vectortiles/pom.xml,&gt; line 59, column 17
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project (<https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/pom.xml)> has 1 error
[ERROR] Non-parseable POM <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/community/pom.xml&gt;: unexpected character in markup < (position: END_TAG seen ...</descriptor>\n<<... @88:3) @ line 88, column 3 -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/ModelParseException
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.12.x/226/display/redirect&gt;
Started by upstream project "geowebcache-1.12.x" build number 59
originally caused by:
> git rev-list f01acb69958a255fec74419c83dee75561c23cec # timeout=10
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.12.x/227/display/redirect?page=changes&gt;
