[Geoserver-devel] Build failed in Jenkins: geoserver-2.12.x #37
See <https://build.geoserver.org/job/geoserver-2.12.x/37/display/redirect?page=changes&gt;
Changes:
[Alessio Fabiani] [GEOS-8336][GEOS-8337] - Monitoring Hibernate obsolete dependencies /
[Alessio Fabiani] - merge
[Alessio Fabiani] [GEOS-8321][2.12.x] Monitoring plugin Path Exception
[Alessio Fabiani] [GEOS-8332] - DataStoreFileController wrong management of FeatureTypes
[Alessio Fabiani] - typo on applicationContext.xml
[...truncated 17.30 MB...]
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF WFS output format and WPS PPIO
[INFO] DXF WPS PPIO
[INFO] Printing Module
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] Importer REST Api Module-ng
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GRIB Coverage Format
[INFO] NetCDF Coverage format
[INFO] WCS NetCDF output Module
[INFO] Vector Tiles
[INFO] Ysld GeoServer Plugin
[INFO]
[INFO] Building GeoServer 2.12-SNAPSHOT
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-api/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-api/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-api/18-SNAPSHOT/maven-metadata.xml (957 B at 4.3 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/library/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/library/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/library/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/library/18-SNAPSHOT/maven-metadata.xml (573 B at 26.6 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/modules/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/modules/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/modules/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/modules/18-SNAPSHOT/maven-metadata.xml (573 B at 40.0 KB/sec)
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/geotools/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/geotools/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/geotools/18-SNAPSHOT/maven-metadata.xml (574 B at 37.4 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-referencing/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-referencing/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/18-SNAPSHOT/maven-metadata.xml (2 KB at 104.4 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-metadata/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/18-SNAPSHOT/maven-metadata.xml (962 B at 85.4 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-opengis/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/18-SNAPSHOT/maven-metadata.xml (961 B at 78.2 KB/sec)
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-main/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-main/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-main/18-SNAPSHOT/maven-metadata.xml (2 KB at 81.5 KB/sec)
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ geoserver ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ geoserver ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ geoserver ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/geoserver/2.12-SNAPSHOT/geoserver-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/target/geoserver-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/geoserver/2.12-SNAPSHOT/geoserver-2.12-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver ---
[INFO] Downloading: ftp://maven.geo-solutions.it/org/geoserver/geoserver/2.12-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver:geoserver:2.12-SNAPSHOT/maven-metadata.xml from/to geosolutions (ftp://maven.geo-solutions.it/): Password not specified for repository geosolutions
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... FAILURE [ 4.364 s]
[INFO] Core Platform Module ............................... SKIPPED
[INFO] Open Web Service Module ............................ SKIPPED
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] SpatiaLite Extension ............................... SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] Aggregating Data Store ............................. SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer Scripting Extensions ..................... SKIPPED
[INFO] Core Scripting Extension ........................... SKIPPED
[INFO] Web UI Scripting Extension ......................... SKIPPED
[INFO] BeanShell Scripting Extension ...................... SKIPPED
[INFO] Groovy Scripting Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] Python Scripting Extension ......................... SKIPPED
[INFO] JavaScript Scripting Extension ..................... SKIPPED
[INFO] Ruby Scripting Extension ........................... SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] GeoServer Mapbox Styling ........................... SKIPPED
[INFO] GeoServer Status Monitoring Module ................. SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] S3 Geotiff Support ................................. SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 7.994 s
[INFO] Finished at: 2017-10-25T09:44:59+00:00
[INFO] Final Memory: 147M/709M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to retrieve remote metadata org.geoserver:geoserver:2.12-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:geoserver:2.12-SNAPSHOT/maven-metadata.xml from/to geosolutions (ftp://maven.geo-solutions.it/): Password not specified for repository geosolutions -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
Sorry, wrong commit!
Reverting!
On Wed, Oct 25, 2017 at 11:45 AM, <nstires@anonymised.com> wrote:
See <https://build.geoserver.org/job/geoserver-2.12.x/37/display/redirect?page=changes>
Changes:
[…truncated 17.30 MB…]
[INFO] DXF WPS PPIO
[INFO] Vector Tiles
[INFO]
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ geoserver —
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ geoserver —
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ geoserver —
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ geoserver —
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ geoserver —
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/geoserver/2.12-SNAPSHOT/geoserver-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/target/geoserver-2.12-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/geoserver/2.12-SNAPSHOT/geoserver-2.12-SNAPSHOT-tests.jar
[INFO]
[INFO] — maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver —
[INFO]
[INFO] GeoServer … FAILURE [ 4.364 s]
[INFO] Core Platform Module … SKIPPED
[INFO] Open Web Service Module … SKIPPED
[INFO] Main Module … SKIPPED
[INFO] GeoServer Security Modules … SKIPPED
[INFO] GeoServer JDBC Security Module … SKIPPED
[INFO] GeoServer LDAP Security Module … SKIPPED
[INFO] Web Coverage Service Module … SKIPPED
[INFO] Web Coverage Service 1.0 Module … SKIPPED
[INFO] Web Coverage Service 1.1 Module … SKIPPED
[INFO] Web Coverage Service 2.0 Module … SKIPPED
[INFO] Web Feature Service Module … SKIPPED
[INFO] Web Map Service Module … SKIPPED
[INFO] KML support for GeoServer … SKIPPED
[INFO] gs-rest … SKIPPED
[INFO] gs-restconfig … SKIPPED
[INFO] GeoWebCache (GWC) Module … SKIPPED
[INFO] GeoServer Web Modules … SKIPPED
[INFO] Core UI Module … SKIPPED
[INFO] WMS UI Module … SKIPPED
[INFO] GWC UI Module … SKIPPED
[INFO] WFS UI Module … SKIPPED
[INFO] Demos Module … SKIPPED
[INFO] WCS UI Module … SKIPPED
[INFO] Security UI Modules … SKIPPED
[INFO] Security UI Core Module … SKIPPED
[INFO] Security UI JDBC Module … SKIPPED
[INFO] Security UI LDAP Module … SKIPPED
[INFO] REST UI Module … SKIPPED
[INFO] GeoServer Web Application … SKIPPED
[INFO] Community Space … SKIPPED
[INFO] Authentication by unique url key … SKIPPED
[INFO] WorldWind Format Module … SKIPPED
[INFO] SpatiaLite Extension … SKIPPED
[INFO] GeoServer JDBC KV Catalog … SKIPPED
[INFO] Aggregating Data Store … SKIPPED
[INFO] GeoServer Extensions … SKIPPED
[INFO] Web Processing Service parent … SKIPPED
[INFO] Web Processing Service Module … SKIPPED
[INFO] GeoServer Scripting Extensions … SKIPPED
[INFO] Core Scripting Extension … SKIPPED
[INFO] Web UI Scripting Extension … SKIPPED
[INFO] BeanShell Scripting Extension … SKIPPED
[INFO] Groovy Scripting Extension … SKIPPED
[INFO] H2 DataStore Extension … SKIPPED
[INFO] Python Scripting Extension … SKIPPED
[INFO] JavaScript Scripting Extension … SKIPPED
[INFO] Ruby Scripting Extension … SKIPPED
[INFO] WMS-EO … SKIPPED
[INFO] ColorMap … SKIPPED
[INFO] GeoServer mbtiles Extension … SKIPPED
[INFO] GeoServer GeoPackage Extension … SKIPPED
[INFO] Dynamic WMS dimension value defaults … SKIPPED
[INFO] GPX PPIO for WPS … SKIPPED
[INFO] KML PPIO for WPS … SKIPPED
[INFO] DownloadProcess … SKIPPED
[INFO] GeoServer JMS based clustering modules … SKIPPED
[INFO] ActiveMQ … SKIPPED
[INFO] GeoServer JMS clustering Commons module … SKIPPED
[INFO] GeoServer JMS clustering module … SKIPPED
[INFO] GeoServer Hazelcast Clustering Module … SKIPPED
[INFO] Solr Module … SKIPPED
[INFO] GeoFence security integration … SKIPPED
[INFO] GeoFence Server … SKIPPED
[INFO] Parameters Extractor … SKIPPED
[INFO] GeoServer Data Importer … SKIPPED
[INFO] Importer Core Module … SKIPPED
[INFO] WPS cluster on jdbc datastores … SKIPPED
[INFO] ncWMS compatibility extension … SKIPPED
[INFO] GWC Distributed Caching Plugin … SKIPPED
[INFO] GeoWebCache S3 … SKIPPED
[INFO] OGR parent … SKIPPED
[INFO] OGR CORE … SKIPPED
[INFO] GDAL translate parent … SKIPPED
[INFO] GDAL translate WCS … SKIPPED
[INFO] GDAL translate WPS … SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store … SKIPPED
[INFO] GeoWebCache SQLite … SKIPPED
[INFO] GeoGig GeoServer integration … SKIPPED
[INFO] WMTS Multi Dimensional … SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module … SKIPPED
[INFO] GeoServer OneLogin Module … SKIPPED
[INFO] gs-notification-common … SKIPPED
[INFO] OWS Dispatcher Simulate Plugin … SKIPPED
[INFO] JDBC Metrics Plugin … SKIPPED
[INFO] OpenSearch EO parent … SKIPPED
[INFO] OpenSearch for EO … SKIPPED
[INFO] OpenSearch for EO web UI … SKIPPED
[INFO] OpenSearch for EO REST configuration API … SKIPPED
[INFO] GeoServer Mapbox Styling … SKIPPED
[INFO] GeoServer Status Monitoring Module … SKIPPED
[INFO] GeoServer Community Release Module … SKIPPED
[INFO] GeoServer Resource Browser … SKIPPED
[INFO] GeoServer notification event system … SKIPPED
[INFO] S3 Geotiff Support … SKIPPED
[INFO] Application Schema Support … SKIPPED
[INFO] Application Schema Integration Test … SKIPPED
[INFO] Sample DataAccess Integration Test … SKIPPED
[INFO] ArcSDE DataStore Extension … SKIPPED
[INFO] SQL Server DataStore Extension … SKIPPED
[INFO] Oracle DataStore Extension … SKIPPED
[INFO] MySQL DataStore Extension … SKIPPED
[INFO] DB2 DataStore Extension … SKIPPED
[INFO] ImageMap Output Format … SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension … SKIPPED
[INFO] JP2K Coverage Extension … SKIPPED
[INFO] OGR WFS … SKIPPED
[INFO] OGR WPS … SKIPPED
[INFO] Excel Output Format … SKIPPED
[INFO] Chart external graphics support … SKIPPED
[INFO] Feature Generalization Extension … SKIPPED
[INFO] Image Mosaic JDBC Extension … SKIPPED
[INFO] OWS request flow controller … SKIPPED
[INFO] Web process status sharing with Hazelcast … SKIPPED
[INFO] Web Processing Service GUI … SKIPPED
[INFO] GeoServer Layer Querying filter functions … SKIPPED
[INFO] Teradata DataStore Extension … SKIPPED
[INFO] GeoServer Monitor Extensions … SKIPPED
[INFO] Core Monitor Extension … SKIPPED
[INFO] Monitor Hibernate Extension … SKIPPED
[INFO] GeoServer Security Extension Modules … SKIPPED
[INFO] GeoServer CAS Security Module … SKIPPED
[INFO] GeoServer Security Extension Web Modules … SKIPPED
[INFO] GeoServer CAS Security Web Module … SKIPPED
[INFO] XLST based WFS output format … SKIPPED
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] GeoServer CSS Styling … SKIPPED
[INFO] Catalog Services for the Web parent … SKIPPED
[INFO] Catalog Services for the Web interfaces … SKIPPED
[INFO] Catalog Services for the Web core module … SKIPPED
[INFO] CSW UI Module … SKIPPED
[INFO] DXF WFS output format and WPS PPIO … SKIPPED
[INFO] DXF WFS output format … SKIPPED
[INFO] DXF WPS PPIO … SKIPPED
[INFO] Printing Module … SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SKIPPED
[INFO] GeoServer libjpeg-turbo Module … SKIPPED
[INFO] Importer REST Api Module-ng … SKIPPED
[INFO] Importer Berkley DB Persistence Module … SKIPPED
[INFO] Importer Web UI Module … SKIPPED
[INFO] GRIB Coverage Format … SKIPPED
[INFO] NetCDF Coverage format … SKIPPED
[INFO] WCS NetCDF output Module … SKIPPED
[INFO] Vector Tiles … SKIPPED
[INFO] Ysld GeoServer Plugin … SKIPPED
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to retrieve remote metadata org.geoserver:geoserver:2.12-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:geoserver:2.12-SNAPSHOT/maven-metadata.xml from/to geosolutions (ftp://maven.geo-solutions.it/): Password not specified for repository geosolutions → [Help 1]
[ERROR]
[ERROR]
Build step ‘Invoke top-level Maven targets’ marked build as failure
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
See <https://build.geoserver.org/job/geoserver-2.12.x/38/display/redirect?page=changes&gt;
Changes:
[Alessio Fabiani] Revert " - typo on applicationContext.xml"
[...truncated 17.34 MB...]
[INFO] DXF WPS PPIO
[INFO] Vector Tiles
[INFO]
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-api/18-SNAPSHOT/maven-metadata.xml (957 B at 5.1 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/library/18-SNAPSHOT/maven-metadata.xml (573 B at 40.0 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/modules/18-SNAPSHOT/maven-metadata.xml (573 B at 43.0 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/geotools/18-SNAPSHOT/maven-metadata.xml (574 B at 43.1 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/18-SNAPSHOT/maven-metadata.xml (2 KB at 71.8 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/18-SNAPSHOT/maven-metadata.xml (961 B at 72.2 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/main/org/geotools/gt-main/18-SNAPSHOT/maven-metadata.xml (2 KB at 87.8 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... FAILURE [ 4.951 s]
[INFO] Total time: 9.332 s
[INFO] Finished at: 2017-10-25T10:32:40+00:00
[INFO] Final Memory: 149M/696M
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.12.x/39/display/redirect&gt;
