[Geoserver-devel] Build failed in Jenkins: geoserver-2.12.x #77
See <https://build.geoserver.org/job/geoserver-2.12.x/77/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-7961] WFS service sometimes fails due to encode filter NPEx
[...truncated 3.34 MB...]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wcs2_0-eo-core ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.12-SNAPSHOT/gs-wcs2_0-eo-core-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/core/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.12-SNAPSHOT/gs-wcs2_0-eo-core-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.12-SNAPSHOT/gs-wcs2_0-eo-core-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.12-SNAPSHOT/gs-wcs2_0-eo-core-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/core/target/gs-wcs2_0-eo-core-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wcs2_0-eo-core/2.12-SNAPSHOT/gs-wcs2_0-eo-core-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Web Coverage Service 2.0 Earth Observation GUI extension 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-wcs2_0-eo ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-wcs2_0-eo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wcs2_0-eo ---
[INFO] Copying 3 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wcs2_0-eo ---
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-wcs2_0-eo ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wcs2_0-eo ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wcs2_0.eo.web.WCSEOAdminPanelTest
Dec 09, 2017 10:27:34 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerConfigurationLock', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ResourcePool', but ApplicationContext is unset.
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
Dec 09, 2017 10:27:34 AM org.geotools.image.ImageWorker <clinit>
INFO: Warp/affine reduction enabled: true
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Dec 09, 2017 10:27:35 AM org.geoserver.platform.GeoServerExtensions checkContext
Dec 09, 2017 10:27:36 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.773 sec
Running org.geoserver.wcs2_0.eo.web.WCSEOLayerConfigTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.827 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.885 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.262 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.408 s]
[INFO] Main Module ........................................ SUCCESS [01:51 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.054 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 33.090 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 23.062 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.819 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 17.350 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 24.261 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 39.048 s]
[INFO] Web Feature Service Module ......................... FAILURE [ 14.098 s]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 17.278 s]
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.066 s]
[INFO] Core UI Module ..................................... SUCCESS [01:02 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.050 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.054 s]
[INFO] Printing Module .................................... SUCCESS [ 11.486 s]
[INFO] Community Space .................................... SUCCESS [ 0.033 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.071 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.275 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.944 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.425 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.231 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.204 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.163 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.304 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.047 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.752 s]
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.042 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.433 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.723 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.679 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.143 s]
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.679 s]
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.046 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.700 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 9.574 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 33.845 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.676 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.033 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.016 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 14.926 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 8.733 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 16.445 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 05:40 min (Wall Clock)
[INFO] Finished at: 2017-12-09T10:27:39+00:00
[INFO] Final Memory: 119M/1036M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-wfs: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x/ws/src/wfs/src/test/java/org/geoserver/wfs/v1_1/GetFeatureTest.java&gt;:\[708,57\] error: incompatible types: int cannot be converted to List<Exception>
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <https://build.geoserver.org/job/geoserver-2.12.x/78/display/redirect&gt;
[...truncated 3.35 MB...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Dec 09, 2017 11:10:46 AM org.geoserver.platform.GeoServerExtensions checkContext
Dec 09, 2017 11:10:47 AM org.geotools.image.ImageWorker <clinit>
Dec 09, 2017 11:10:47 AM org.geoserver.platform.GeoServerExtensions checkContext
Dec 09, 2017 11:10:48 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.694 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.167 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.741 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.764 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.145 s]
[INFO] Main Module ........................................ SUCCESS [02:02 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.072 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.084 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 28.192 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.287 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.619 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.893 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.497 s]
[INFO] Web Feature Service Module ......................... FAILURE [ 17.491 s]
[INFO] gs-rest ............................................ SUCCESS [ 21.323 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.094 s]
[INFO] Core UI Module ..................................... SUCCESS [01:17 min]
[INFO] Security UI Modules ................................ SUCCESS [ 0.054 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.052 s]
[INFO] Printing Module .................................... SUCCESS [ 15.694 s]
[INFO] Community Space .................................... SUCCESS [ 0.102 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 15.043 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.071 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.407 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.220 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.275 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.732 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.345 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.078 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.710 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.082 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.502 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.381 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.594 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.518 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.142 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.083 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.396 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.202 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.173 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 13.321 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.074 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.043 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 17.362 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.810 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 20.012 s]
[INFO] Total time: 06:42 min (Wall Clock)
[INFO] Finished at: 2017-12-09T11:10:53+00:00
[INFO] Final Memory: 119M/1012M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.12.x/79/display/redirect?page=changes&gt;
