[Geoserver-devel] Build failed in Jenkins: geoserver-2.12.x-live-docs #11
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/11/changes&gt;
Changes:
[andrea.aime] [GEOS-8187] Legend Preview not correctly interpreting SvgParameter
[andrea.aime] [GEOS-8290] Bug in GetLegendGraphic countMatched-feature when using
[andrea.aime] [GEOS-8344] Bug in GetLegendGraphic countMatched-feature when using
[andrea.aime] Allow multiple property placeholder configurers in GeoServer
[andrea.aime] Clarifications on SRS handling policies
[...truncated 123 lines...]
  "datatype" : "array[null]",
  "datatypeWithEnum" : "array[null]",
  "name" : "dataStoreResponse",
  "defaultValue" : "null",
  "defaultValueWithParam" : " = data.dataStoreResponse;",
  "baseType" : "array",
  "containerType" : "array",
  "example" : "null",
  "jsonSchema" : "{\n \"type\" : \"array\"\n}",
  "exclusiveMinimum" : false,
  "exclusiveMaximum" : false,
  "hasMore" : false,
  "required" : false,
  "secondaryParam" : false,
  "hasMoreNonReadOnly" : false,
  "isPrimitiveType" : false,
  "isContainer" : true,
  "isNotContainer" : false,
  "isString" : false,
  "isInteger" : false,
  "isLong" : false,
  "isFloat" : false,
  "isDouble" : false,
  "isByteArray" : false,
  "isBinary" : false,
  "isFile" : false,
  "isBoolean" : false,
  "isDate" : false,
  "isDateTime" : false,
  "isListContainer" : true,
  "isMapContainer" : false,
  "isEnum" : false,
  "isReadOnly" : false,
  "vendorExtensions" : { },
  "hasValidation" : false,
  "isInherited" : false,
  "nameInCamelCase" : "DataStoreResponse"
[ERROR] unexpected missing property for name dataStoreResponse
[WARNING] skipping invalid array property {
  "baseName" : "dataStoreResponse",
  "getter" : "getDataStoreResponse",
  "setter" : "setDataStoreResponse",
  "example" : "null",
  "hasMore" : false,
  "required" : false,
  "isString" : false,
  "isLong" : false,
  "isFloat" : false,
  "isDouble" : false,
  "isBinary" : false,
  "isFile" : false,
  "isDate" : false,
  "isEnum" : false,
[WARNING] Type is NULL for Serializable Parameter: workspaceName
[WARNING] warning! Property type "null" not found for parameter "workspaceName", using String
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/datastores/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (featureTypes) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml&gt;
[WARNING] generated unique operationId `getFeatureTypes_0`
[WARNING] generated unique operationId `putFeatureTypes_0`
[WARNING] generated unique operationId `postFeatureTypes_0`
[WARNING] generated unique operationId `deleteFeatureTypes_0`
[WARNING] generated unique operationId `getFeatureType_0`
[WARNING] generated unique operationId `putFeatureType_0`
[WARNING] generated unique operationId `postFeatureType_0`
[WARNING] generated unique operationId `deleteFeatureType_0`
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/featuretypes/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (fonts) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (layergroups) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (layers) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (manifests) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[WARNING] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[WARNING] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (namespaces) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (owsServices) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (reload) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (security) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/security/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (settings) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (structuredCoverages) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (styles) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (template) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[WARNING] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmslayers) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmsstores) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmtslayers) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmtsstores) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (workspaces) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (monitoring) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-transforms) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-tasks) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-data) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (compile) @ gs-docs ---
[INFO] Executing tasks
init:
     [echo] Base directgory is <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en&gt;
     [echo] Build directory is <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target&gt; and project version is 2.12-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.12-SNAPSHOT -W -b html -d "<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx-ignore-warnings:
     [exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/production/container.rst&gt;:67: WARNING: Explicit markup ends without a blank line; unexpected unindent.
     [exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/rest/about.rst&gt;:8: WARNING: Mismatch: both interpreted text role prefix and reference suffix.
     [exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/points.rst&gt;:101: WARNING: download file not readable: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/artifacts/point_simplepointwithstroke.ysld&gt;
     [exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst&gt;:51: WARNING: Explicit markup ends without a blank line; unexpected unindent.
     [exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst&gt;:63: WARNING: download file not readable: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/artifacts/mbstyle_polygon_simplepolygon.json&gt;
     [exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst&gt;:103: WARNING: download file not readable: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/artifacts/mbstyle_polygon_simplepolygonwithstroke.json&gt;
     [exec] Exception occurred:
     [exec] File "/usr/local/lib/python2.7/dist-packages/Sphinx-1.2b1-py2.7.egg/sphinx/builders/html.py", line 421, in get_doc_context
     [exec] display_toc = (self.env.toc_num_entries[docname] > 1),
     [exec] KeyError: u'community/nsg-profile/index'
     [exec] The full traceback has been saved in /tmp/sphinx-err-CnBeqa.log, if you want to report the issue to the developers.
     [exec] Please also report this if it was a user error, so that a better error message can be provided next time.
     [exec] Either send bugs to the mailing list at <http://groups.google.com/group/sphinx-users/&gt;,
     [exec] or report them in the tracker at <http://bitbucket.org/birkenfeld/sphinx/issues/&gt;\. Thanks!
[INFO] BUILD FAILURE
[INFO] Total time: 01:14 min
[INFO] Finished at: 2017-11-03T13:52:30+00:00
[INFO] Final Memory: 16M/279M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.3:run (compile) on project gs-docs: An Ant BuildException has occured: The following error occurred while executing this line:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/build.xml&gt;:100: exec returned: 1
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/12/changes&gt;
Changes:
[andrea.aime] [GEOS-8358] find in startup script may run for long time
[tbarsballe] [GEOS-6745] Copy style needs to copy content and format
[tbarsballe] [GEOS-8225] Allow workspace to be set on new styles if not admin
[tbarsballe] [GEOS-8242] Use seperate keys when caching different queries
[alessio.fabiani] [GEOS-8321] Monitoring plugin Path Exception
[alessio.fabiani] [Backport 2.12.x][GEOS-8338] Update Community Module 'sldExtension' to
[daniele.romagnoli] Small update to timeregex and custom format documentation
[alessio.fabiani] [Backport to 2.12.x][GEOS-8336][GEOS-8337] - Monitoring Hibernate
  "example" : "null",
  "hasMore" : false,
  "required" : false,
  "isString" : false,
  "isLong" : false,
  "isFloat" : false,
  "isDouble" : false,
  "isBinary" : false,
  "isFile" : false,
  "isDate" : false,
  "isEnum" : false,
  "example" : "null",
  "hasMore" : false,
  "required" : false,
  "isString" : false,
  "isLong" : false,
  "isFloat" : false,
  "isDouble" : false,
  "isBinary" : false,
  "isFile" : false,
  "isDate" : false,
  "isEnum" : false,
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
init:
docguide:
sphinx:
user:
     [exec] The full traceback has been saved in /tmp/sphinx-err-eYBwoD.log, if you want to report the issue to the developers.
[INFO] Total time: 01:23 min
[INFO] Finished at: 2017-11-17T10:06:27+00:00
[INFO] Final Memory: 13M/147M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/13/changes&gt;
