See <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/14/changes>
Changes:
[nuno.oliveira] [GEOS-8385] Update MongoDB integration with App-Schema tests to use
[...truncated 123 lines...]
"datatype" : "array[null]",
"datatypeWithEnum" : "array[null]",
"name" : "dataStoreResponse",
"defaultValue" : "null",
"defaultValueWithParam" : " = data.dataStoreResponse;",
"baseType" : "array",
"containerType" : "array",
"example" : "null",
"jsonSchema" : "{\n \"type\" : \"array\"\n}",
"exclusiveMinimum" : false,
"exclusiveMaximum" : false,
"hasMore" : false,
"required" : false,
"secondaryParam" : false,
"hasMoreNonReadOnly" : false,
"isPrimitiveType" : false,
"isContainer" : true,
"isNotContainer" : false,
"isString" : false,
"isInteger" : false,
"isLong" : false,
"isFloat" : false,
"isDouble" : false,
"isByteArray" : false,
"isBinary" : false,
"isFile" : false,
"isBoolean" : false,
"isDate" : false,
"isDateTime" : false,
"isListContainer" : true,
"isMapContainer" : false,
"isEnum" : false,
"isReadOnly" : false,
"vendorExtensions" : { },
"hasValidation" : false,
"isInherited" : false,
"nameInCamelCase" : "DataStoreResponse"
[ERROR] unexpected missing property for name dataStoreResponse
[WARNING] skipping invalid array property {
"baseName" : "dataStoreResponse",
"getter" : "getDataStoreResponse",
"setter" : "setDataStoreResponse",
"example" : "null",
"hasMore" : false,
"required" : false,
"isString" : false,
"isLong" : false,
"isFloat" : false,
"isDouble" : false,
"isBinary" : false,
"isFile" : false,
"isDate" : false,
"isEnum" : false,
[WARNING] Type is NULL for Serializable Parameter: workspaceName
[WARNING] warning! Property type "null" not found for parameter "workspaceName", using String
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/datastores/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (featureTypes) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml>
[WARNING] generated unique operationId `getFeatureTypes_0`
[WARNING] generated unique operationId `putFeatureTypes_0`
[WARNING] generated unique operationId `postFeatureTypes_0`
[WARNING] generated unique operationId `deleteFeatureTypes_0`
[WARNING] generated unique operationId `getFeatureType_0`
[WARNING] generated unique operationId `putFeatureType_0`
[WARNING] generated unique operationId `postFeatureType_0`
[WARNING] generated unique operationId `deleteFeatureType_0`
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/featuretypes/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (fonts) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/fonts.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/fonts/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (layergroups) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/layergroups/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (layers) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/layers.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/layers/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (manifests) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/manifests.yaml>
[WARNING] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[WARNING] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/manifests/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (namespaces) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/namespaces/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (owsServices) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/owsservices/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (reload) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/reload.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/reload/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (security) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/security.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/security/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (settings) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/settings.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/settings/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (structuredCoverages) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/structuredcoverages/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (styles) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/styles.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/styles/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (template) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/templates.yaml>
[WARNING] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/templates/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmslayers) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/wmslayers/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmsstores) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/wmsstores/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmtslayers) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/wmtslayers/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmtsstores) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/wmtsstores/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (workspaces) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/workspaces/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (monitoring) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/monitoring/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/importer.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/importer/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-transforms) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/importerTransforms/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-tasks) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/importerTasks/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-data) @ gs-docs ---
[INFO] reading from <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/api/1.0.0/importerData.yaml>
[INFO] writing file <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/api/importerData/index.html>
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (compile) @ gs-docs ---
[INFO] Executing tasks
init:
[echo] Base directgory is <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en>
[echo] Build directory is <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target> and project version is 2.12-SNAPSHOT
docguide:
sphinx:
[echo] Running sphinx-build -D release=2.12-SNAPSHOT -W -b html -d "<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/docguide/doctrees"> . "<http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/target/docguide/html">
user:
sphinx-ignore-warnings:
[exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/production/container.rst>:67: WARNING: Explicit markup ends without a blank line; unexpected unindent.
[exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/rest/about.rst>:8: WARNING: Mismatch: both interpreted text role prefix and reference suffix.
[exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/points.rst>:101: WARNING: download file not readable: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/artifacts/point_simplepointwithstroke.ysld>
[exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst>:51: WARNING: Explicit markup ends without a blank line; unexpected unindent.
[exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst>:63: WARNING: download file not readable: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/artifacts/mbstyle_polygon_simplepolygon.json>
[exec] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst>:103: WARNING: download file not readable: <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/artifacts/mbstyle_polygon_simplepolygonwithstroke.json>
[exec] Exception occurred:
[exec] File "/usr/local/lib/python2.7/dist-packages/Sphinx-1.2b1-py2.7.egg/sphinx/builders/html.py", line 421, in get_doc_context
[exec] display_toc = (self.env.toc_num_entries[docname] > 1),
[exec] KeyError: u'community/nsg-profile/index'
[exec] The full traceback has been saved in /tmp/sphinx-err-nz8YWn.log, if you want to report the issue to the developers.
[exec] Please also report this if it was a user error, so that a better error message can be provided next time.
[exec] Either send bugs to the mailing list at <http://groups.google.com/group/sphinx-users/>,
[exec] or report them in the tracker at <http://bitbucket.org/birkenfeld/sphinx/issues/>\. Thanks!
[INFO] BUILD FAILURE
[INFO] Total time: 01:48 min
[INFO] Finished at: 2017-11-20T08:44:41+00:00
[INFO] Final Memory: 16M/276M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.3:run (compile) on project gs-docs: An Ant BuildException has occured: The following error occurred while executing this line:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/build.xml>:48: The following error occurred while executing this line:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-2.12.x-live-docs/ws/doc/en/build.xml>:100: exec returned: 1
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
