See <https://build.geoserver.org/job/geoserver-2.12.x-nightly/13/display/redirect>
[...truncated 275.39 KB...]
[INFO] GeoServer Status Monitoring Module ................. SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] S3 Geotiff Support ................................. SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 04:04 min
[INFO] Finished at: 2017-10-09T14:02:08+00:00
[INFO] Final Memory: 170M/1077M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-authkey: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[11,34\] error: package org.geoserver.security.impl does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[12,40\] error: package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AbstractAuthenticationKeyMapper.java>:\[16,40\] error: package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyMapper.java>:\[12,34\] error: package org.geoserver.security.impl does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyMapper.java>:\[13,40\] error: package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[48,11\] error: cannot find symbol
[ERROR] class UserPropertyAuthenticationKeyMapper
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AbstractAuthenticationKeyMapper.java>:\[35,12\] error: cannot find symbol
[ERROR] class AbstractAuthenticationKeyMapper
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AbstractAuthenticationKeyMapper.java>:\[64,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AbstractAuthenticationKeyMapper.java>:\[68,35\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AbstractAuthenticationKeyMapper.java>:\[72,14\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AbstractAuthenticationKeyMapper.java>:\[143,73\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfigException.java>:\[9,40\] error: package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfigException.java>:\[17,60\] error: cannot find symbol
[ERROR] class FilterConfigException
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyMapper.java>:\[36,4\] error: cannot find symbol
[ERROR] interface AuthenticationKeyMapper
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyMapper.java>:\[59,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyMapper.java>:\[60,35\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyMapper.java>:\[82,73\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfig.java>:\[11,36\] error: package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfig.java>:\[12,36\] error: package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfig.java>:\[24,51\] error: cannot find symbol
[ERROR] class SecurityFilterConfig
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfig.java>:\[25,15\] error: cannot find symbol
[ERROR] class SecurityAuthFilterConfig
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/WebServiceAuthenticationKeyMapper.java>:\[22,34\] error: package org.geoserver.security.impl does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/WebServiceAuthenticationKeyMapper.java>:\[23,40\] error: package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/WebServiceAuthenticationKeyMapper.java>:\[173,11\] error: cannot find symbol
[ERROR] class WebServiceAuthenticationKeyMapper
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/WebServiceAuthenticationKeyMapper.java>:\[297,73\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfigValidator.java>:\[11,36\] error: package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfigValidator.java>:\[12,40\] error: package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfigValidator.java>:\[13,40\] error: package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfigValidator.java>:\[22,60\] error: cannot find symbol
[ERROR] class FilterConfigValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfigValidator.java>:\[24,50\] error: cannot find symbol
[ERROR] class AuthenticationKeyFilterConfigValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfigValidator.java>:\[29,37\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfigValidator.java>:\[30,19\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AuthenticationKeyFilterConfigValidator.java>:\[39,19\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleServiceConfig.java>:\[7,36\] error: package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleServiceConfig.java>:\[8,36\] error: package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleServiceConfig.java>:\[14,52\] error: cannot find symbol
[ERROR] class BaseSecurityNamedServiceConfig
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleServiceConfig.java>:\[15,19\] error: cannot find symbol
[ERROR] class SecurityRoleServiceConfig
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[26,35\] error: package org.geoserver.security.event does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[27,34\] error: package org.geoserver.security.impl does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[28,34\] error: package org.geoserver.security.impl does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[43,46\] error: cannot find symbol
[ERROR] class AbstractGeoServerSecurityService
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[44,19\] error: cannot find symbol
[ERROR] class GeoServerRoleService
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[100,18\] error: cannot find symbol
[ERROR] class GeoServerRestRoleService
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[106,36\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[111,37\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[134,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[141,43\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[148,45\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[156,50\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[161,49\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[169,21\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[215,67\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[215,24\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[232,21\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[244,21\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[288,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[293,39\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[293,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[298,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[354,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerRestRoleService.java>:\[395,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/PropertyAuthenticationKeyMapper.java>:\[19,34\] error: package org.geoserver.security.impl does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/PropertyAuthenticationKeyMapper.java>:\[44,4\] error: cannot find symbol
[ERROR] class PropertyAuthenticationKeyMapper
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/PropertyAuthenticationKeyMapper.java>:\[54,24\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[11,32\] error: package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[13,36\] error: package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[14,36\] error: package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[15,40\] error: package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[24,56\] error: cannot find symbol
[ERROR] class AbstractFilterProvider
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[26,26\] error: cannot find symbol
[ERROR] class GeoServerAuthenticationKeyProvider
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[34,27\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[39,48\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[39,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[45,12\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[44,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[50,50\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[50,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[56,60\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[56,11\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[62,27\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyProvider.java>:\[67,27\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyFilter.java>:\[25,36\] error: package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyFilter.java>:\[26,36\] error: package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyFilter.java>:\[27,36\] error: package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyFilter.java>:\[28,36\] error: package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyFilter.java>:\[29,34\] error: package org.geoserver.security.impl does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyFilter.java>:\[30,34\] error: package org.geoserver.security.impl does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyFilter.java>:\[52,55\] error: cannot find symbol
[ERROR] class GeoServerSecurityFilter
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyFilter.java>:\[53,15\] error: cannot find symbol
[ERROR] class AuthenticationCachingFilter
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyFilter.java>:\[53,44\] error: cannot find symbol
[ERROR] class GeoServerAuthenticationFilter
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/GeoServerAuthenticationKeyFilter.java>:\[64,37\] error: cannot find symbol
[ERROR] class GeoServerAuthenticationKeyFilter
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/AbstractAuthenticationKeyMapper.java>:\[73,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[51,18\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[58,17\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[66,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[72,16\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[81,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[86,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[88,13\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/community/authkey/src/main/java/org/geoserver/security/UserPropertyAuthenticationKeyMapper.java>:\[95,25\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-authkey
