[Geoserver-devel] Build failed in Jenkins: geoserver-2.12.x-nightly #16
See <https://build.geoserver.org/job/geoserver-2.12.x-nightly/16/display/redirect?page=changes&gt;
Changes:
[Gabriel Roldan] Adapt to geogig 1.2.x package refactoring of remoting commands
[...truncated 825.45 KB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/jp2k/target/gs-jp2k-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jp2k ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jp2k ---
[INFO]
[INFO] --- maven-dependency-plugin:2.8:copy-dependencies (copy-dependencies) @ gs-jp2k ---
[INFO] Copying gt-api-18-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/jp2k/target/dependency/gt-api-18-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.12-SNAPSHOT.jar to <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/jp2k/target/dependency/gwc-core-1.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jp2k ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/jp2k/target/gs-jp2k-2.12-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-jp2k/2.12-SNAPSHOT/gs-jp2k-2.12-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/jp2k/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-jp2k/2.12-SNAPSHOT/gs-jp2k-2.12-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/jp2k/target/gs-jp2k-2.12-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-jp2k/2.12-SNAPSHOT/gs-jp2k-2.12-SNAPSHOT-tests.jar
[INFO]
[INFO] Building OGR WFS 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-ogr-wfs ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-ogr-wfs ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-ogr-wfs ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-ogr-wfs ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-ogr-wfs ---
[INFO] Compiling 6 source files to <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[31,29\] error: package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[32,29\] error: package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[159,44\] error: cannot find symbol
[ERROR] class Ogr2OgrOutputFormat
<https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[159,72\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[180,29\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[190,56\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[206,54\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[264,8\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[264,50\] error: cannot find symbol
<https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[59,7\] error: cannot access ServiceException
[INFO] 10 errors
[INFO]
[INFO] Skipping GeoServer
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 17.069 s]
[INFO] Core Platform Module ............................... SUCCESS [ 4.222 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.370 s]
[INFO] Main Module ........................................ SUCCESS [ 31.334 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.045 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 3.601 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 3.555 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.910 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 4.514 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 4.650 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 5.221 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 8.808 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 11.525 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 5.236 s]
[INFO] gs-rest ............................................ SUCCESS [ 3.555 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 7.649 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:25 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.018 s]
[INFO] Core UI Module ..................................... SUCCESS [ 9.588 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 4.814 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 5.974 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 3.013 s]
[INFO] Demos Module ....................................... SUCCESS [ 5.136 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 3.697 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.031 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 6.806 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 3.531 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 3.549 s]
[INFO] REST UI Module ..................................... SUCCESS [ 2.773 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 4.950 s]
[INFO] Community Space .................................... SUCCESS [ 0.190 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 4.044 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 3.433 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 9.718 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 4.726 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 5.982 s]
[INFO] WMS-EO ............................................. SUCCESS [ 4.147 s]
[INFO] ColorMap ........................................... SUCCESS [ 3.563 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.017 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.017 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 15.310 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 7.150 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 3.968 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 6.649 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.597 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 6.709 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 34.792 s]
[INFO] DownloadProcess .................................... SUCCESS [ 7.010 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.354 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.632 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.971 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 10.122 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.881 s]
[INFO] Solr Module ........................................ SUCCESS [ 9.315 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 6.392 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.071 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 9.084 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.066 s]
[INFO] Importer Core Module ............................... SUCCESS [ 52.869 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 4.279 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 14.297 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 15.591 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 9.885 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 12.803 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.013 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.433 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.016 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 2.950 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 2.812 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 4.225 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 13.909 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [ 16.545 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 4.081 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 3.026 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 3.242 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 3.202 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 3.208 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 3.357 s]
[INFO] gs-notification-common ............................. SUCCESS [ 0.934 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 1.445 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 3.203 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 1.816 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.013 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 4.896 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 3.056 s]
[INFO] OpenSearch for EO REST configuration API ........... SUCCESS [ 4.332 s]
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 11.068 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 3.334 s]
[INFO] GeoServer Community Release Module ................. SUCCESS [ 0.365 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 3.723 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 3.322 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 7.423 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.029 s]
[INFO] Application Schema Integration Test ................ SUCCESS [ 9.209 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.529 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.807 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 2.787 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.033 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.019 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 6.892 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 5.689 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.492 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.100 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 4.524 s]
[INFO] OGR WFS ............................................ FAILURE [ 3.034 s]
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 12:01 min
[INFO] Finished at: 2017-10-12T14:10:04+00:00
[INFO] Final Memory: 198M/1171M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-ogr-wfs: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[159,72\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[180,29\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[190,56\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[206,54\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[264,8\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[264,50\] error: cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.12.x-nightly/ws/src/extension/ogr/ogr-wfs/src/main/java/org/geoserver/wfs/response/Ogr2OgrOutputFormat.java&gt;:\[59,7\] error: cannot access ServiceException
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ogr-wfs
See <https://build.geoserver.org/job/geoserver-2.12.x-nightly/17/display/redirect&gt;
