See <https://build.geoserver.org/job/geoserver-2.13.x/60/display/redirect>
[...truncated 11.21 MB...]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[copy] Copying 29 files to <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/src/main/webapp\]>
Apr 17, 2018 5:59:14 PM org.geoserver.importer.Importer copyFromFeatureReader
INFO: load to target took 30
[INFO] Webapp assembled in [283 msecs]
[INFO] Building war: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT.jar
Apr 17, 2018 5:59:15 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/target/gs-web-app-2.13-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.13-SNAPSHOT/gs-web-app-2.13-SNAPSHOT.war
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.13-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/target/classes>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.587 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Apr 17, 2018 5:59:17 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Apr 17, 2018 5:59:17 PM org.geoserver.importer.Importer createContextStore
INFO: Enabling import store: memory
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.398 sec
Results :
Tests run: 66, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/importer/rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.13-SNAPSHOT/gs-importer-rest-2.13-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.13-SNAPSHOT/gs-web-sec-cas-2.13-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.984 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.915 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.455 s]
[INFO] Main Module ........................................ SUCCESS [ 58.646 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.070 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:14 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 33.936 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 22.993 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.566 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.930 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.274 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.028 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:32 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:55 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 29.064 s]
[INFO] gs-rest ............................................ SUCCESS [ 15.754 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:27 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:14 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.004 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.802 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.335 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.066 s]
[INFO] Core UI Module ..................................... SUCCESS [01:05 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.619 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 57.814 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.023 s]
[INFO] Demos Module ....................................... SUCCESS [ 16.534 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.075 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.037 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:27 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:00 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 19.030 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.103 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.051 s]
[INFO] Printing Module .................................... SUCCESS [ 11.434 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.078 s]
[INFO] Community Space .................................... SUCCESS [ 0.035 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.035 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:40 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.833 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.464 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.787 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.940 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.383 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.214 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.210 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.355 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.208 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.318 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.817 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.266 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.031 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:05 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.986 s]
[INFO] Excel Output Format ................................ SUCCESS [ 11.801 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.463 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.461 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.542 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.063 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.658 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 25.375 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.439 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.937 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 21.244 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.419 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.350 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.024 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.266 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 16.650 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 37.541 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 17.141 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.055 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.690 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.786 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 33.203 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.301 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.087 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.601 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 8.279 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.045 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.351 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.674 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.340 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [ 45.618 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 43.977 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 12.977 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 13.036 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.566 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 14.986 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 41.711 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 13.535 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 13.059 s]
[INFO] BUILD FAILURE
[INFO] Total time: 17:27 min (Wall Clock)
[INFO] Finished at: 2018-04-17T17:59:18+00:00
[INFO] Final Memory: 145M/1174M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-netcdf-out: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.13.x/ws/src/extension/netcdf-out/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
