[Geoserver-devel] Build failed in Jenkins: geoserver-2.14.x #126
See <https://build.geoserver.org/job/geoserver-2.14.x/126/display/redirect&gt;
[...truncated 1.11 MB...]
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.99 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[debug] Using AOSP style
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 25.913 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.14-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/classes&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.024 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.527 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.094 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.818 s]
[INFO] Main Module ........................................ SUCCESS [01:29 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.081 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:52 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:01 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 29.796 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.412 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 28.960 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 37.123 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:15 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:07 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:29 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 59.167 s]
[INFO] gs-rest ............................................ SUCCESS [ 24.427 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [03:22 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:27 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 31.563 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 31.226 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 23.538 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.116 s]
[INFO] Core UI Module ..................................... SUCCESS [01:34 min]
[INFO] WMS UI Module ...................................... SUCCESS [01:01 min]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 25.379 s]
[INFO] Demos Module ....................................... SUCCESS [ 33.790 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 24.114 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.082 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:42 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:50 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 32.142 s]
[INFO] REST UI Module ..................................... SUCCESS [ 20.478 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.083 s]
[INFO] Printing Module .................................... SUCCESS [ 26.703 s]
[INFO] Community Space .................................... SUCCESS [ 0.039 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.066 s]
[INFO] Application Schema Integration Test ................ SUCCESS [04:35 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 18.430 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 16.666 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 20.940 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.955 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.421 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.205 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.223 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 16.192 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.551 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.312 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.045 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.247 s]
[INFO] OGR WFS ............................................ SUCCESS [ 14.349 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.051 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:02 min]
[INFO] OGR WPS ............................................ SUCCESS [ 18.647 s]
[INFO] Excel Output Format ................................ SUCCESS [ 21.794 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.467 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.235 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.537 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 20.486 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 30.521 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 44.776 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 24.683 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.121 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.088 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.094 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 11.053 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.057 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 4.639 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 34.500 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 31.333 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.076 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 22.550 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 22.369 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:15 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 20.778 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.055 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 21.213 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 15.969 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.070 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 27.269 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 24.331 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 18.767 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.147 s]
[INFO] Importer Core Module ............................... SUCCESS [01:20 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:17 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 28.874 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 24.419 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.212 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 35.182 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:23 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 29.839 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.321 s]
[INFO] BUILD FAILURE
[INFO] Total time: 28:40 min (Wall Clock)
[INFO] Finished at: 2018-12-08T13:44:14+00:00
[INFO] Final Memory: 152M/1419M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <https://build.geoserver.org/job/geoserver-2.14.x/127/display/redirect&gt;
