See <https://build.geoserver.org/job/geoserver-2.14.x/189/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-9022] geoserver Style page, after expand button, html brokes
[Andrea Aime] [GEOS-8970] WMS GetCapabilities throws ConcurrentModificationException
[...truncated 828.25 KB...]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/classes>
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 1.447 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.669 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-sec-cas ---
[debug] Using AOSP style
[INFO] Processed 14 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.14-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/test-classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/surefire-reports>
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.132 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.804 s]
[INFO] Core Platform Module ............................... SUCCESS [ 21.769 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 23.457 s]
[INFO] Main Module ........................................ SUCCESS [01:56 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.126 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:32 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:06 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 28.578 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 6.896 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.343 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 40.662 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:37 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:42 min]
[INFO] Web Map Service Module ............................. FAILURE [ 14.203 s]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 26.625 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [02:36 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 32.318 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 30.967 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.101 s]
[INFO] Core UI Module ..................................... SUCCESS [01:59 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 18.421 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.068 s]
[INFO] Security UI Core Module ............................ SUCCESS [03:00 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:47 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 33.557 s]
[INFO] REST UI Module ..................................... SUCCESS [ 19.874 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.062 s]
[INFO] Printing Module .................................... SUCCESS [ 20.932 s]
[INFO] Community Space .................................... SUCCESS [ 0.036 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.085 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.218 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 22.611 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 21.264 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.081 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.564 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.344 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.352 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 7.825 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.368 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.077 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.614 s]
[INFO] OGR WFS ............................................ SUCCESS [ 11.167 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.073 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:00 min]
[INFO] OGR WPS ............................................ SUCCESS [ 16.400 s]
[INFO] Excel Output Format ................................ SUCCESS [ 18.120 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.623 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.579 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.701 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 21.560 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 30.736 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 19.700 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.924 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.175 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.076 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 12.337 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.078 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 4.698 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 41.884 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.106 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.352 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 22.906 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:01 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 15.631 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.088 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 18.005 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 19.271 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.076 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 28.248 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 21.827 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 28.051 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.291 s]
[INFO] BUILD FAILURE
[INFO] Total time: 18:37 min (Wall Clock)
[INFO] Finished at: 2019-02-11T09:30:04+00:00
[INFO] Final Memory: 138M/1357M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-wms: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/wms/src/main/java/org/geoserver/wms/capabilities/DimensionHelper.java>:\[234,34\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
