Hudson
March 16, 2019, 1:52pm
1
See <https://build.geoserver.org/job/geoserver-2.14.x/209/display/redirect> ;
[...truncated 1.06 MB...]
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java ’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO]
[INFO] Building CSW UI Module 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-csw ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target> ;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-csw ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-csw ---
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-csw ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/classes> ;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-web ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/web/target/surefire-reports> ;
T E S T S
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/src/test/resources> ;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/test-classes> ;
Running org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/surefire-reports> ;
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.339 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-test-sources.jar
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.512 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[INFO] Processed 34 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/web/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/web/target/gs-importer-web-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.14-SNAPSHOT/gs-importer-web-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.791 s]
[INFO] Core Platform Module ............................... SUCCESS [ 19.324 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 26.803 s]
[INFO] Main Module ........................................ SUCCESS [01:47 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.174 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:57 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:02 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 39.070 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 7.483 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 34.084 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 41.795 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [01:21 min]
[INFO] Web Feature Service Module ......................... SUCCESS [03:06 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:39 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 51.275 s]
[INFO] gs-rest ............................................ SUCCESS [ 24.210 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [03:51 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:45 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 30.805 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 38.290 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 24.145 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.201 s]
[INFO] Core UI Module ..................................... SUCCESS [02:25 min]
[INFO] WMS UI Module ...................................... SUCCESS [01:03 min]
[INFO] GWC UI Module ...................................... SUCCESS [01:41 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 21.978 s]
[INFO] Demos Module ....................................... SUCCESS [ 37.136 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 22.694 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.194 s]
[INFO] Security UI Core Module ............................ SUCCESS [03:06 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:59 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 36.339 s]
[INFO] REST UI Module ..................................... SUCCESS [ 22.212 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.097 s]
[INFO] Printing Module .................................... SUCCESS [ 22.735 s]
[INFO] Community Space .................................... SUCCESS [ 0.082 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.099 s]
[INFO] Application Schema Integration Test ................ SUCCESS [04:33 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 20.414 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 21.808 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 23.259 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.483 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.549 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.388 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.369 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 14.717 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 8.714 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.350 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.047 s]
[INFO] OGR CORE ........................................... SUCCESS [ 4.206 s]
[INFO] OGR WFS ............................................ SUCCESS [ 18.871 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.063 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 23.980 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.582 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 5.501 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.589 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 24.201 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 27.241 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 4.539 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.099 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 46.985 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.127 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 13.000 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.079 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 5.395 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 34.357 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 31.490 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.111 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 19.261 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 16.733 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:04 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 18.972 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.041 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 21.333 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.044 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 16.074 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.083 s]
[INFO] Importer Core Module ............................... SUCCESS [01:22 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:16 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 27.515 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 28.766 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 28.142 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 24.405 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 25.487 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 29.913 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.453 s]
[INFO] BUILD FAILURE
[INFO] Total time: 29:33 min (Wall Clock)
[INFO] Finished at: 2019-03-16T13:52:30+00:00
[INFO] Final Memory: 146M/1296M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/wcs2_0/target/surefire-reports> ; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
Hudson
March 16, 2019, 3:24pm
2
See <https://build.geoserver.org/job/geoserver-2.14.x/210/display/redirect> ;
[...truncated 1.05 MB...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Mar 16, 2019 3:24:22 PM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
at org.geoserver.importer.Importer.addTasks(Importer.java:472)
at org.geoserver.importer.Importer.init(Importer.java:440)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:227)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:75)
at sun.reflect.GeneratedMethodAccessor286.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:97)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:160)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:127)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 25.475 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.285 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar> ;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar> ;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar> ;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar> ; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/pom.xml> ; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar> ; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar> ; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.494 s]
[INFO] Core Platform Module ............................... SUCCESS [ 20.792 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.889 s]
[INFO] Main Module ........................................ SUCCESS [01:41 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.142 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:40 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 53.879 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 33.847 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 6.799 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 31.565 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 39.836 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [01:05 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [04:19 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 54.008 s]
[INFO] gs-rest ............................................ SUCCESS [ 26.302 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [03:07 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:40 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 41.574 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 47.560 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 18.436 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.131 s]
[INFO] Core UI Module ..................................... SUCCESS [02:00 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 55.778 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:50 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 27.504 s]
[INFO] Demos Module ....................................... SUCCESS [ 30.924 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 28.455 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.048 s]
[INFO] Security UI Core Module ............................ SUCCESS [03:12 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:52 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 28.426 s]
[INFO] REST UI Module ..................................... SUCCESS [ 20.424 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.079 s]
[INFO] Printing Module .................................... SUCCESS [ 20.641 s]
[INFO] Community Space .................................... SUCCESS [ 0.058 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.086 s]
[INFO] Application Schema Integration Test ................ SUCCESS [04:58 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 23.265 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 18.019 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 18.830 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.119 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.487 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.285 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.325 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 13.896 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 6.452 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.333 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.046 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.513 s]
[INFO] OGR WFS ............................................ SUCCESS [ 19.339 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.044 s]
[INFO] Excel Output Format ................................ SUCCESS [ 28.363 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.545 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 4.182 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.547 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 22.252 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 28.794 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 4.240 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.081 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 53.632 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.050 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 13.750 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.102 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 4.384 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 37.426 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 39.748 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.107 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 17.927 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 18.422 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 56.192 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 21.860 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.042 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 24.103 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.045 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 15.167 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.068 s]
[INFO] Importer Core Module ............................... SUCCESS [01:32 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:15 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 26.516 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 26.442 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 23.609 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 41.114 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 32.537 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 31.245 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.076 s]
[INFO] Total time: 29:00 min (Wall Clock)
[INFO] Finished at: 2019-03-16T15:24:24+00:00
[INFO] Final Memory: 144M/1461M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
March 16, 2019, 5:46pm
3
