[Geoserver-devel] Build failed in Jenkins: geoserver-2.14.x #227
See <https://build.geoserver.org/job/geoserver-2.14.x/227/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-9157] REST mosaic upload fails if using index store reference by
[Andrea Aime] [GEOS-9145] GetLegendGraphic in JPEG will fail if libjpeg-turbo is
[...truncated 14.86 MB...]
Mar 29, 2019 8:43:59 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
Mar 29, 2019 8:43:59 PM com.hazelcast.util.HealthMonitor
INFO: [127.0.0.1]:5011 [dev] [3.3.1] processors=4, physical.memory.total=15.7G, physical.memory.free=1.1G, swap.space.total=0, swap.space.free=0, heap.memory.used=85.6M, heap.memory.free=165.9M, heap.memory.total=251.5M, heap.memory.max=455.5M, heap.memory.used/total=34.05%, heap.memory.used/max=18.80%, minor.gc.count=6, minor.gc.time=89ms, major.gc.count=1, major.gc.time=50ms, load.process=6.00%, load.system=75.00%, load.systemAverage=363.00%, thread.count=48, thread.peakCount=124, event.q.size=0, executor.q.async.size=0, executor.q.client.size=0, executor.q.query.size=0, executor.q.scheduled.size=0, executor.q.io.size=0, executor.q.system.size=0, executor.q.operation.size=0, executor.q.priorityOperation.size=0, executor.q.response.size=0, operations.remote.size=0, operations.running.size=0, proxy.count=0, clientEndpoint.count=0, connection.active.count=0, connection.count=0
Mar 29, 2019 8:43:59 PM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 8 generic operation threads and 8 partition operation threads.
Mar 29, 2019 8:43:59 PM com.hazelcast.system
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Mar 29, 2019 8:43:59 PM com.hazelcast.cluster.ClusterService
Members [2] {
  Member [127.0.0.1]:5011 this
  Member [127.0.0.1]:5012
Members [2] {
  Member [127.0.0.1]:5012 this
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
Mar 29, 2019 8:44:00 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Mar 29, 2019 8:44:00 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Mar 29, 2019 8:44:00 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Mar 29, 2019 8:44:00 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Mar 29, 2019 8:44:00 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Mar 29, 2019 8:44:00 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 17 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 8 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.448 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-wps-cluster-hazelcast ---
[INFO] Processed 5 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.14-SNAPSHOT/gs-wps-cluster-hazelcast-2.14-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.514 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.233 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.224 s]
[INFO] Main Module ........................................ SUCCESS [01:05 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.071 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:16 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.372 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.929 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.315 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.785 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.786 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.722 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:36 min]
[INFO] Web Map Service Module ............................. FAILURE [01:00 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 15.972 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:30 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.977 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.787 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.057 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 11.308 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.101 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:36 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:05 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.083 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.531 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.062 s]
[INFO] Printing Module .................................... SUCCESS [ 13.876 s]
[INFO] Community Space .................................... SUCCESS [ 0.032 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.426 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.861 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.032 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.213 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.383 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.260 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.287 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.496 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.301 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.093 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.621 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.054 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:11 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.855 s]
[INFO] Excel Output Format ................................ SUCCESS [ 13.896 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.458 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.412 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.422 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 18.336 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.146 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 15.553 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.046 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.055 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.697 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.763 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.832 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.110 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.454 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.654 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.462 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.935 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.036 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.360 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.217 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.041 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.087 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.979 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 14.699 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.994 s]
[INFO] BUILD FAILURE
[INFO] Total time: 11:18 min (Wall Clock)
[INFO] Finished at: 2019-03-29T20:44:00+00:00
[INFO] Final Memory: 139M/1577M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <https://build.geoserver.org/job/geoserver-2.14.x/228/display/redirect&gt;
Mar 29, 2019 10:05:08 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Removing Member [127.0.0.1]:5009
Members [1] {
  Member [127.0.0.1]:5010 this
Mar 29, 2019 10:05:08 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Destroying node initializer.
Mar 29, 2019 10:05:08 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Hazelcast Shutdown is completed in 17 ms.
Mar 29, 2019 10:05:08 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTDOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTTING_DOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 7 ms.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
Mar 29, 2019 10:05:08 PM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 8 generic operation threads and 8 partition operation threads.
Mar 29, 2019 10:05:08 PM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
Mar 29, 2019 10:05:08 PM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
Members [2] {
Members [2] {
Mar 29, 2019 10:05:09 PM com.hazelcast.core.LifecycleService
Mar 29, 2019 10:05:09 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Mar 29, 2019 10:05:09 PM com.hazelcast.partition.InternalPartitionService
Mar 29, 2019 10:05:09 PM com.hazelcast.cluster.ClusterService
Members [1] {
Mar 29, 2019 10:05:09 PM com.hazelcast.initializer
Mar 29, 2019 10:05:09 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 14 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 6 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 20.034 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.681 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.255 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.065 s]
[INFO] Main Module ........................................ SUCCESS [01:04 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.085 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:15 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 37.038 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.233 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.439 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.447 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.051 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.852 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.660 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 17.146 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 17.808 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.112 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.053 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.116 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:32 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:06 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.367 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.672 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.052 s]
[INFO] Printing Module .................................... SUCCESS [ 14.974 s]
[INFO] Community Space .................................... SUCCESS [ 0.033 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.034 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.203 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.833 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.946 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.941 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.373 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.205 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.213 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.563 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.265 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.038 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.274 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.217 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] OGR WPS ............................................ SUCCESS [ 8.671 s]
[INFO] Excel Output Format ................................ SUCCESS [ 13.635 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.489 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.551 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.512 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.669 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 28.031 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 15.860 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.044 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.059 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.885 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.038 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.703 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.546 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.054 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.577 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.749 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 32.179 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.785 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.593 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.127 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.087 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.186 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.783 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.016 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.920 s]
[INFO] Total time: 11:23 min (Wall Clock)
[INFO] Finished at: 2019-03-29T22:05:09+00:00
[INFO] Final Memory: 139M/1585M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.14.x/229/display/redirect&gt;
[...truncated 14.87 MB...]
Apr 06, 2019 12:16:41 PM com.hazelcast.core.LifecycleService
Apr 06, 2019 12:16:41 PM com.hazelcast.util.HealthMonitor
INFO: [127.0.0.1]:5011 [dev] [3.3.1] processors=4, physical.memory.total=15.7G, physical.memory.free=735.3M, swap.space.total=0, swap.space.free=0, heap.memory.used=85.0M, heap.memory.free=169.5M, heap.memory.total=254.5M, heap.memory.max=455.5M, heap.memory.used/total=33.42%, heap.memory.used/max=18.67%, minor.gc.count=6, minor.gc.time=60ms, major.gc.count=1, major.gc.time=44ms, load.process=15.00%, load.system=98.00%, load.systemAverage=330.00%, thread.count=48, thread.peakCount=123, event.q.size=0, executor.q.async.size=0, executor.q.client.size=0, executor.q.query.size=0, executor.q.scheduled.size=0, executor.q.io.size=0, executor.q.system.size=0, executor.q.operation.size=0, executor.q.priorityOperation.size=0, executor.q.response.size=0, operations.remote.size=0, operations.running.size=0, proxy.count=0, clientEndpoint.count=0, connection.active.count=0, connection.count=0
Apr 06, 2019 12:16:41 PM com.hazelcast.spi.impl.BasicOperationScheduler
Apr 06, 2019 12:16:41 PM com.hazelcast.system
Apr 06, 2019 12:16:41 PM com.hazelcast.cluster.ClusterService
Members [2] {
Members [2] {
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Apr 06, 2019 12:16:42 PM com.hazelcast.core.LifecycleService
Apr 06, 2019 12:16:42 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Apr 06, 2019 12:16:42 PM com.hazelcast.partition.InternalPartitionService
Apr 06, 2019 12:16:47 PM com.hazelcast.core.LifecycleService
Apr 06, 2019 12:16:47 PM com.hazelcast.cluster.ClusterService
Members [1] {
Apr 06, 2019 12:16:47 PM com.hazelcast.initializer
Apr 06, 2019 12:16:47 PM com.hazelcast.instance.Node
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.966 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.529 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.214 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.067 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.060 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.607 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 21.883 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.423 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.913 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.428 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 50.163 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:39 min]
[INFO] Web Map Service Module ............................. FAILURE [01:02 min]
[INFO] gs-rest ............................................ SUCCESS [ 17.331 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 18.942 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 18.584 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.063 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.149 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.144 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:37 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:04 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.614 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.673 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.051 s]
[INFO] Printing Module .................................... SUCCESS [ 14.614 s]
[INFO] Community Space .................................... SUCCESS [ 0.029 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.022 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.046 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.346 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.166 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.270 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.218 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.286 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.206 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.331 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.033 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.449 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.588 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.029 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:12 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.894 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.112 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.584 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.779 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 18.214 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.058 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 15.763 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.078 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.065 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.958 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.797 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 18.089 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.052 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.420 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.803 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 31.694 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.047 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.046 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.165 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.062 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.048 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 17.988 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.276 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.372 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.962 s]
[INFO] Total time: 11:29 min (Wall Clock)
[INFO] Finished at: 2019-04-06T12:16:47+00:00
[INFO] Final Memory: 137M/1503M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.14.x/230/display/redirect&gt;
Apr 06, 2019 1:50:02 PM com.hazelcast.core.LifecycleService
Apr 06, 2019 1:50:02 PM com.hazelcast.util.HealthMonitor
INFO: [127.0.0.1]:5011 [dev] [3.3.1] processors=4, physical.memory.total=15.7G, physical.memory.free=879.3M, swap.space.total=0, swap.space.free=0, heap.memory.used=85.8M, heap.memory.free=164.7M, heap.memory.total=250.5M, heap.memory.max=455.5M, heap.memory.used/total=34.26%, heap.memory.used/max=18.84%, minor.gc.count=6, minor.gc.time=59ms, major.gc.count=1, major.gc.time=38ms, load.process=26.00%, load.system=91.00%, load.systemAverage=282.00%, thread.count=47, thread.peakCount=122, event.q.size=0, executor.q.async.size=0, executor.q.client.size=0, executor.q.query.size=0, executor.q.scheduled.size=1, executor.q.io.size=0, executor.q.system.size=0, executor.q.operation.size=0, executor.q.priorityOperation.size=0, executor.q.response.size=0, operations.remote.size=0, operations.running.size=0, proxy.count=0, clientEndpoint.count=0, connection.active.count=0, connection.count=0
Apr 06, 2019 1:50:02 PM com.hazelcast.spi.impl.BasicOperationScheduler
Apr 06, 2019 1:50:02 PM com.hazelcast.system
Apr 06, 2019 1:50:02 PM com.hazelcast.cluster.ClusterService
Members [2] {
Members [2] {
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Apr 06, 2019 1:50:03 PM com.hazelcast.core.LifecycleService
Apr 06, 2019 1:50:03 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Apr 06, 2019 1:50:03 PM com.hazelcast.partition.InternalPartitionService
Apr 06, 2019 1:50:03 PM com.hazelcast.cluster.ClusterService
Members [1] {
Apr 06, 2019 1:50:03 PM com.hazelcast.initializer
Apr 06, 2019 1:50:03 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 15 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 9 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.928 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.433 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.391 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.951 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.093 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:18 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.324 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.648 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.560 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.574 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 19.513 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.700 s]
[INFO] Web Map Service Module ............................. FAILURE [01:01 min]
[INFO] gs-rest ............................................ SUCCESS [ 16.548 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:31 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 17.029 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 18.465 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.097 s]
[INFO] Core UI Module ..................................... SUCCESS [01:10 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.073 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.054 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:33 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.620 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.541 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.042 s]
[INFO] Printing Module .................................... SUCCESS [ 14.078 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.840 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.104 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 11.081 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.915 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.375 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.212 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.212 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.889 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.183 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.108 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.031 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:13 min]
[INFO] OGR WPS ............................................ SUCCESS [ 8.738 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.097 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.428 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.858 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.447 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 18.235 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.661 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 15.773 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.091 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.050 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 4.813 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.037 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.712 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.478 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.818 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.633 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 32.752 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.054 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.857 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.602 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.023 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.991 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.971 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.324 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.916 s]
[INFO] Total time: 11:19 min (Wall Clock)
[INFO] Finished at: 2019-04-06T13:50:03+00:00
[INFO] Final Memory: 138M/1504M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.14.x/231/display/redirect?page=changes&gt;
