See <https://build.geoserver.org/job/geoserver-2.14.x/235/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-8450] DescribeCoverage should not fail on secured datasets with
[Andrea Aime] [GEOS-9153] WCS 2.0 scaling policies do not account for scaling factor
[Andrea Aime] [GEOS-9192] GeoServer UI let's you save duplicate grids names
[Andrea Aime] Fix for Solr circular Spring Bean reference exception
[...truncated 1.16 MB...]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.14-SNAPSHOT/gs-importer-rest-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.14-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/target/surefire-reports>
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.091 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.237 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[copy] Copying 29 files to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/target/geoserver\]>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] Processing war project
[INFO] Copying webapp resources [<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/src/main/webapp\]>
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO] Webapp assembled in [296 msecs]
[INFO] Building war: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-app ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/src/main/java’> does not exist, ignoring.
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/target/gs-web-app-2.14-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/web/app/target/geoserver.war> to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.14-SNAPSHOT/gs-web-app-2.14-SNAPSHOT.war
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.995 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.254 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.130 s]
[INFO] Main Module ........................................ SUCCESS [01:04 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.067 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:17 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 34.815 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.612 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.446 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 16.443 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.665 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 53.466 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:36 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:56 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 29.699 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.478 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [02:25 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:32 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 18.246 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 18.408 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 13.106 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.063 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 32.222 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 53.387 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.288 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.923 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.180 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.092 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:37 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:01 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.112 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.501 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.054 s]
[INFO] Printing Module .................................... SUCCESS [ 14.083 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 8.006 s]
[INFO] Community Space .................................... SUCCESS [ 0.033 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.032 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:44 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.396 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.808 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.829 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.942 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.400 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.218 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.223 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.869 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.342 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.323 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.057 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.189 s]
[INFO] OGR WFS ............................................ FAILURE [ 12.225 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.060 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:07 min]
[INFO] Excel Output Format ................................ SUCCESS [ 12.625 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.507 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.595 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.505 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 17.521 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 24.022 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 22.339 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 13.884 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.917 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.058 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 25.703 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.023 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.949 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.085 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.927 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 17.463 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 33.498 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 17.582 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.052 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.443 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 7.310 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 37.699 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 9.018 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.292 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.817 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.034 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 16.220 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.499 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 8.725 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.090 s]
[INFO] Importer Core Module ............................... SUCCESS [ 52.057 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 44.001 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 14.853 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 14.058 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 15.612 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.764 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 39.587 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.385 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 13.986 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.933 s]
[INFO] BUILD FAILURE
[INFO] Total time: 18:28 min (Wall Clock)
[INFO] Finished at: 2019-04-30T10:56:52+00:00
[INFO] Final Memory: 155M/1373M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-ogr-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/ogr/ogr-wfs/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ogr-wfs
