[Geoserver-devel] Build failed in Jenkins: geoserver-2.14.x #265
See <http://build.geoserver.org/job/geoserver-2.14.x/265/display/redirect&gt;
Started by upstream project "geotools-20.x" build number 102
originally caused by:
Started by an SCM change
ln builds/lastSuccessfulBuild /var/lib/jenkins/jobs/geoserver-2.14.x/lastSuccessful failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-2.14.x/lastSuccessful
  at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
  at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
  at java.nio.file.Files.deleteIfExists(Files.java:1165)
  at hudson.Util.createSymlink(Util.java:1193)
  at hudson.model.Run.createSymlink(Run.java:1955)
  at hudson.model.Run.updateSymlinks(Run.java:1936)
  at hudson.model.Run.execute(Run.java:1814)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
  at hudson.model.ResourceController.execute(ResourceController.java:97)
  at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-2.14.x/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-2.14.x/lastStable
  at hudson.model.Run.updateSymlinks(Run.java:1937)
Building remotely on i-05928bcb8900bdb98 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-2.14.x/ws/&gt;
Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-05928bcb8900bdb98
    at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
    at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
    at hudson.remoting.Channel.call(Channel.java:957)
    at hudson.FilePath.act(FilePath.java:1069)
    at hudson.FilePath.act(FilePath.java:1058)
    at hudson.FilePath.mkdirs(FilePath.java:1243)
    at hudson.model.AbstractProject.checkout(AbstractProject.java:1202)
    at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
    at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
    at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
    at hudson.model.Run.execute(Run.java:1816)
java.nio.file.FileSystemException: <http://build.geoserver.org/job/geoserver-2.14.x/ws/&gt;: No space left on device
  at sun.nio.fs.UnixException.translateToIOException(UnixException.java:100)
  at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:111)
  at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:116)
  at sun.nio.fs.UnixFileSystemProvider.createDirectory(UnixFileSystemProvider.java:385)
  at java.nio.file.Files.createDirectory(Files.java:689)
  at java.nio.file.Files.createAndCheckIsDirectory(Files.java:796)
  at java.nio.file.Files.createDirectories(Files.java:782)
  at hudson.FilePath.mkdirs(FilePath.java:3229)
  at hudson.FilePath.access$1300(FilePath.java:210)
  at hudson.FilePath$Mkdirs.invoke(FilePath.java:1251)
  at hudson.FilePath$Mkdirs.invoke(FilePath.java:1247)
  at hudson.FilePath$FileCallableWrapper.call(FilePath.java:3042)
  at hudson.remoting.UserRequest.perform(UserRequest.java:212)
  at hudson.remoting.UserRequest.perform(UserRequest.java:54)
  at hudson.remoting.Request$2.run(Request.java:369)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
  at java.util.concurrent.FutureTask.run(FutureTask.java:264)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
  at java.lang.Thread.run(Thread.java:834)
See <http://build.geoserver.org/job/geoserver-2.14.x/266/display/redirect&gt;
[...truncated 2.23 MB...]
[INFO]
[INFO] Skipping GeoServer OAuth2 Connect Security Module - OpenId Connect
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/javassist/javassist/3.19.0-GA/javassist-3.19.0-GA.pom
[WARNING] Failed to write tracking file /home/ubuntu/.m2/repository/org/javassist/javassist/3.19.0-GA/javassist-3.19.0-GA.pom.lastUpdated
java.io.IOException: No space left on device
    at java.io.RandomAccessFile.writeBytes (Native Method)
    at java.io.RandomAccessFile.write (RandomAccessFile.java:512)
    at org.eclipse.aether.internal.impl.TrackingFileManager.update (TrackingFileManager.java:132)
    at org.eclipse.aether.internal.impl.DefaultUpdateCheckManager.write (DefaultUpdateCheckManager.java:588)
    at org.eclipse.aether.internal.impl.DefaultUpdateCheckManager.touchArtifact (DefaultUpdateCheckManager.java:524)
    at org.eclipse.aether.internal.impl.DefaultArtifactResolver.evaluateDownloads (DefaultArtifactResolver.java:614)
    at org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads (DefaultArtifactResolver.java:504)
    at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve (DefaultArtifactResolver.java:390)
    at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts (DefaultArtifactResolver.java:215)
    at org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact (DefaultArtifactResolver.java:192)
    at org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.loadPom (DefaultArtifactDescriptorReader.java:240)
    at org.apache.maven.repository.internal.DefaultArtifactDescriptorReader.readArtifactDescriptor (DefaultArtifactDescriptorReader.java:171)
    at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.resolveCachedArtifactDescriptor (DefaultDependencyCollector.java:530)
    at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.getArtifactDescriptorResult (DefaultDependencyCollector.java:515)
    at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.processDependency (DefaultDependencyCollector.java:403)
    at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.processDependency (DefaultDependencyCollector.java:356)
    at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.process (DefaultDependencyCollector.java:344)
    at org.eclipse.aether.internal.impl.collect.DefaultDependencyCollector.collectDependencies (DefaultDependencyCollector.java:247)
    at org.eclipse.aether.internal.impl.DefaultRepositorySystem.collectDependencies (DefaultRepositorySystem.java:269)
    at org.apache.maven.project.DefaultProjectDependenciesResolver.resolve (DefaultProjectDependenciesResolver.java:169)
    at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.getDependencies (LifecycleDependencyResolver.java:243)
    at org.apache.maven.lifecycle.internal.LifecycleDependencyResolver.resolveProjectDependencies (LifecycleDependencyResolver.java:147)
    at org.apache.maven.lifecycle.internal.MojoExecutor.ensureDependenciesAreResolved (MojoExecutor.java:248)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:202)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:156)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:148)
    at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:117)
    at org.apache.maven.lifecycle.internal.builder.multithreaded.MultiThreadedBuilder$1.call (MultiThreadedBuilder.java:200)
    at org.apache.maven.lifecycle.internal.builder.multithreaded.MultiThreadedBuilder$1.call (MultiThreadedBuilder.java:196)
    at java.util.concurrent.FutureTask.run (FutureTask.java:266)
    at java.util.concurrent.Executors$RunnableAdapter.call (Executors.java:511)
    at java.util.concurrent.ThreadPoolExecutor.runWorker (ThreadPoolExecutor.java:1149)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:624)
    at java.lang.Thread.run (Thread.java:748)
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/javassist/javassist/3.19.0-GA/javassist-3.19.0-GA.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/javassist/javassist/3.19.0-GA/javassist-3.19.0-GA.pom
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/quartz-scheduler/quartz/2.2.1/quartz-2.2.1.pom
[WARNING] Failed to create parent directories for tracking file /home/ubuntu/.m2/repository/org/quartz-scheduler/quartz/2.2.1/quartz-2.2.1.pom.lastUpdated
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/quartz-scheduler/quartz/2.2.1/quartz-2.2.1.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/quartz-scheduler/quartz/2.2.1/quartz-2.2.1.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/quartz-scheduler/quartz/2.2.1/quartz-2.2.1.pom
[INFO] Downloading from boundless: https://repo.boundlessgeo.com/main/org/slf4j/jcl-over-slf4j/1.6.4/jcl-over-slf4j-1.6.4.pom
[WARNING] Failed to create parent directories for tracking file /home/ubuntu/.m2/repository/org/slf4j/jcl-over-slf4j/1.6.4/jcl-over-slf4j-1.6.4.pom.lastUpdated
[INFO] Downloading from osgeo: http://download.osgeo.org/webdav/geotools/org/slf4j/jcl-over-slf4j/1.6.4/jcl-over-slf4j-1.6.4.pom
[INFO] Downloading from geosolutions: http://maven.geo-solutions.it/org/slf4j/jcl-over-slf4j/1.6.4/jcl-over-slf4j-1.6.4.pom
[INFO] Downloading from central: https://repo.maven.apache.org/maven2/org/slf4j/jcl-over-slf4j/1.6.4/jcl-over-slf4j-1.6.4.pom
[INFO]
[INFO] Skipping GeoServer Task Manager S3
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary for Community Space 2.14-SNAPSHOT:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 4.294 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 13.426 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 13.388 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 3.558 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 6.379 s]
[INFO] WMS-EO ............................................. SUCCESS [ 4.162 s]
[INFO] ColorMap ........................................... SUCCESS [ 3.028 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 10.438 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 3.053 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 1.776 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 2.707 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 3.609 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 2.791 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.846 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.210 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 10.149 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 4.572 s]
[INFO] GeoServer JMS clustering module .................... FAILURE [ 0.057 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.875 s]
[INFO] Solr Module ........................................ SUCCESS [ 3.570 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 5.208 s]
[INFO] GeoFence Server .................................... SUCCESS [ 10.788 s]
[INFO] REST SLD service ................................... SUCCESS [ 7.509 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 3.644 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 22.557 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 2.561 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 2.775 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 1.418 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 2.744 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.011 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 2.607 s]
[INFO] GDAL translate WPS ................................. FAILURE [ 0.025 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 2.861 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 4.167 s]
[INFO] GeoGig GeoServer integration ....................... SUCCESS [01:42 min]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.565 s]
[INFO] GeoServer Config Backup And Restore Core Module .... FAILURE [ 12.699 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 3.325 s]
[INFO] GeoServer Security Community Modules ............... SUCCESS [ 0.014 s]
[INFO] GeoServer OAuth2 Connect Security Module - Core .... FAILURE [ 5.532 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - OpenId Connect SKIPPED
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 9.688 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.774 s]
[INFO] GeoServer notification event system extension for GeoNode FAILURE [ 0.024 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 2.357 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 1.165 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.012 s]
[INFO] OpenSearch for EO .................................. FAILURE [ 0.028 s]
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] GeoServer Mapbox Styling ........................... SUCCESS [ 2.652 s]
[INFO] GeoServer Status Monitoring Module ................. SUCCESS [ 6.097 s]
[INFO] NSG Profiles ....................................... SUCCESS [ 0.011 s]
[INFO] NSG WMTS 1.0 Profile ............................... FAILURE [ 0.029 s]
[INFO] NSG WFS 2.0 Profile ................................ FAILURE [ 0.503 s]
[INFO] NetCDF GHRSST encoder .............................. SUCCESS [ 4.413 s]
[INFO] WFS 3 prototype .................................... SUCCESS [ 11.296 s]
[INFO] S3 Geotiff Support ................................. SUCCESS [ 1.137 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 2.778 s]
[INFO] GeoServer Task Manager ............................. SUCCESS [ 3.530 s]
[INFO] GeoServer Task Manager Core ........................ FAILURE [ 0.450 s]
[INFO] GeoServer Task Manager S3 .......................... SKIPPED
[INFO] GeoServer Quality of Service GetCapabilities module SUCCESS [ 6.405 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 20.075 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:09 min (Wall Clock)
[INFO] Finished at: 2019-06-07T11:51:13Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-dependency-plugin:2.8:copy-dependencies (default) on project gs-backup-restore-core: Error copying artifact from /home/ubuntu/.m2/repository/org/geoserver/gs-wfs/2.14-SNAPSHOT/gs-wfs-2.14-SNAPSHOT.jar to <http://build.geoserver.org/job/geoserver-2.14.x/ws/src/community/backup-restore/core/target/lib/gs-wfs-2.14-SNAPSHOT.jar&gt;: No space left on device -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-resources-plugin:2.6:resources (default-resources) on project gs-notification-geonode: Cannot create resource output directory: <http://build.geoserver.org/job/geoserver-2.14.x/ws/src/community/notification-geonode/target/classes&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-resources-plugin:2.6:resources (default-resources) on project gs-oseo-core: Cannot create resource output directory: <http://build.geoserver.org/job/geoserver-2.14.x/ws/src/community/oseo/oseo-core/target/classes&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-resources-plugin:2.6:resources (default-resources) on project gs-nsg-wmts-profile: Cannot create resource output directory: <http://build.geoserver.org/job/geoserver-2.14.x/ws/src/community/nsg-profiles/nsg-wmts-profile/target/classes&gt; -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-sec-oauth2-core: Compilation failure
[ERROR] <http://build.geoserver.org/job/geoserver-2.14.x/ws/src/community/security/oauth2-core/src/main/java/org/geoserver/security/oauth2/OAuth2AccessTokenURLMangler.java&gt;:\[22,7\] error: error while writing OAuth2AccessTokenURLMangler: could not create parent directories
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-resources-plugin:2.6:resources (default-resources) on project gs-nsg-wfs-profile: <http://build.geoserver.org/job/geoserver-2.14.x/ws/src/community/nsg-profiles/nsg-wfs-profile/target/classes/org/geoserver/nsg/timeout/web/NSGTimeoutPanel.html&gt; (No such file or directory) -> [Help 1]
[ERROR] Failed to execute goal on project gs-jms-geoserver: Could not resolve dependencies for project org.geoserver.community:gs-jms-geoserver:jar:2.14-SNAPSHOT: Failed to collect dependencies at org.apache.activemq:activemq-client:jar:5.9.0: Failed to read artifact descriptor for org.apache.activemq:activemq-client:jar:5.9.0: Could not transfer artifact org.apache.activemq:activemq-client:pom:5.9.0 from/to apache (https://repository.apache.org/content/repositories/releases/): /home/ubuntu/.m2/repository/org/apache/activemq/activemq-client/5.9.0/activemq-client-5.9.0.pom.part.lock (No such file or directory) -> [Help 3]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-resources-plugin:2.6:resources (default-resources) on project gs-gdal-wps: Cannot create resource output directory: <http://build.geoserver.org/job/geoserver-2.14.x/ws/src/community/gdal/gdal-wps/target/classes&gt; -> [Help 1]
[ERROR] Failed to execute goal on project gs-taskmanager-core: Could not resolve dependencies for project org.geoserver.community:gs-taskmanager-core:jar:2.14-SNAPSHOT: Failed to collect dependencies at org.javassist:javassist:jar:3.19.0-GA: Failed to read artifact descriptor for org.javassist:javassist:jar:3.19.0-GA: Could not transfer artifact org.javassist:javassist:pom:3.19.0-GA from/to central (https://repo.maven.apache.org/maven2): GET request of: org/javassist/javassist/3.19.0-GA/javassist-3.19.0-GA.pom from central failed: No space left on device -> [Help 3]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR] [Help 3] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-backup-restore-core
See <http://build.geoserver.org/job/geoserver-2.14.x/267/display/redirect&gt;
Building remotely on i-0a782fd43b7fe5712 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-2.14.x/ws/&gt;
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <http://build.geoserver.org/job/geoserver-2.14.x/ws/&gt; # timeout=10
ERROR: Error cloning remote repo 'origin'
hudson.plugins.git.GitException: Could not init <http://build.geoserver.org/job/geoserver-2.14.x/ws/&gt;
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$5.execute(CliGitAPIImpl.java:813)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:605)
  at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
  at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
  Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-0a782fd43b7fe5712
    at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
    at sun.reflect.GeneratedMethodAccessor476.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
    at com.sun.proxy.$Proxy89.execute(Unknown Source)
    at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1152)
    at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1192)
    at hudson.scm.SCM.checkout(SCM.java:504)
    at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
Caused by: hudson.plugins.git.GitException: Command "git init <http://build.geoserver.org/job/geoserver-2.14.x/ws/&quot;&gt; returned status code 128:
stdout:
stderr: error: copy-fd: write returned: No space left on device
fatal: cannot copy '/usr/share/git-core/templates/hooks/applypatch-msg.sample' to '<http://build.geoserver.org/job/geoserver-2.14.x/ws/.git/hooks/applypatch-msg.sample’>: No space left on device
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2042)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2010)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2006)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1638)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$5.execute(CliGitAPIImpl.java:811)
  ... 11 more
See <http://build.geoserver.org/job/geoserver-2.14.x/268/display/redirect&gt;
> git rev-parse --is-inside-work-tree # timeout=10
ERROR: Workspace has a .git repository, but it appears to be corrupt.
hudson.plugins.git.GitException: Command "git rev-parse --is-inside-work-tree" returned status code 128:
stdout:
stderr: fatal: not a git repository (or any of the parent directories): .git
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1650)
  at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.hasGitRepo(CliGitAPIImpl.java:300)
  at hudson.plugins.git.GitAPI.hasGitRepo(GitAPI.java:232)
  at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  at java.base/java.lang.reflect.Method.invoke(Method.java:566)
  at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:929)
  at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:903)
  at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:855)
  at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
  at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
  at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
  at java.base/java.lang.Thread.run(Thread.java:834)
stdout:
  ... 11 more
See <http://build.geoserver.org/job/geoserver-2.14.x/269/display/redirect?page=changes&gt;
