[Geoserver-devel] Build failed in Jenkins: geoserver-2.14.x #54
See <https://build.geoserver.org/job/geoserver-2.14.x/54/display/redirect&gt;
[...truncated 11.51 MB...]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.14-SNAPSHOT/gs-web-csw-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.14-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/target/gs-web-sec-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/src/test/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 0 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.14-SNAPSHOT/gs-web-sec-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/target/gs-web-sec-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.14-SNAPSHOT/gs-web-sec-2.14-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Oct 04, 2018 12:21:57 PM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.667 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.249 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-sec-cas ---
[INFO] Processed 14 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/cas/target/gs-sec-cas-2.14-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.14-SNAPSHOT/gs-sec-cas-2.14-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.14-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.14-SNAPSHOT/gs-web-sec-cas-2.14-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.662 s]
[INFO] Core Platform Module ............................... SUCCESS [ 45.886 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 29.250 s]
[INFO] Main Module ........................................ SUCCESS [02:08 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.144 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [02:22 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 58.084 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 43.213 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 6.022 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 40.922 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 47.165 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:21 min]
[INFO] Web Feature Service Module ......................... SUCCESS [04:20 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:36 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 56.777 s]
[INFO] gs-rest ............................................ SUCCESS [ 33.040 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [05:18 min]
[INFO] gs-restconfig ...................................... SUCCESS [02:35 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 33.039 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 36.947 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 24.748 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.131 s]
[INFO] Core UI Module ..................................... SUCCESS [03:43 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 58.043 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 20.728 s]
[INFO] Demos Module ....................................... SUCCESS [ 33.157 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 18.202 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.104 s]
[INFO] Security UI Core Module ............................ SUCCESS [03:51 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:24 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 24.299 s]
[INFO] REST UI Module ..................................... SUCCESS [ 20.806 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.150 s]
[INFO] Printing Module .................................... SUCCESS [ 22.631 s]
[INFO] Community Space .................................... SUCCESS [ 0.148 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.155 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:16 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 16.952 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 18.137 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 21.369 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.915 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.795 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.520 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.638 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 15.672 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 11.101 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.454 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.079 s]
[INFO] OGR CORE ........................................... SUCCESS [ 6.044 s]
[INFO] OGR WFS ............................................ SUCCESS [ 16.467 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.078 s]
[INFO] Web Processing Service Module ...................... SUCCESS [03:06 min]
[INFO] OGR WPS ............................................ SUCCESS [ 14.583 s]
[INFO] Excel Output Format ................................ SUCCESS [ 21.712 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.621 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 5.223 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.637 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 25.792 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 20.564 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.078 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 24.747 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.983 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.092 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.095 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.737 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.087 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.124 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 34.582 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 25.500 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.152 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 19.244 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 21.999 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 50.003 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.860 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.073 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 23.660 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 12.949 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.061 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 28.014 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.436 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 33.760 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.212 s]
[INFO] Importer Core Module ............................... SUCCESS [01:06 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 52.128 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.037 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 17.462 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 28.486 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [01:02 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:05 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 58.414 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.546 s]
[INFO] BUILD FAILURE
[INFO] Total time: 33:29 min (Wall Clock)
[INFO] Finished at: 2018-10-04T12:21:59+00:00
[INFO] Final Memory: 146M/1453M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.14.x/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <https://build.geoserver.org/job/geoserver-2.14.x/55/display/redirect&gt;
