See <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/4/display/redirect?page=changes>
Changes:
[tixvieira] fix GEOS-8968 Geoserver printing plugin (print-lib) leaves opened files
[fernandomino7] GWC wmts getcapabilities EPSG:4326 Axis order fix
[tbarsballe] [GEOS-8869] Importer REST should not override default LayerInfo Rest
[Alessio Fabiani] [Community module - notifications] - Fix vulnerabilities on dependencies
[maurobartolomeoli] GEOS-8935: new formatting options for WFS coordinates in GML formats
[Daniele Romagnoli] [GEOS-8985]: Fixing GeoTransform Attribute's coefficients on NetCDF
[Alessio Fabiani] [Community wps-remote] Fix auto-publishing nativeCoverageName metadata
[Andrea Aime] Updating to imageio-ext 1.1.27
[Andrea Aime] [GEOS-8991] WCS 2.0 should return an InvalidSubsetting exception when
[github] [GEOS-8882][GEOS-8954][GEOS-8959] App-Schema and Solr advanced
[github] [GEOS-8986] Update documentation \ info related with measures (M)
Started by an SCM change
Building remotely on apollo-slave-01 in workspace <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/>
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/2.14.x^{commit} # timeout=10
Checking out Revision 6645e70d964500df2dce2b0e66e33c604897a50e (origin/2.14.x)
> git config core.sparsecheckout # timeout=10
> git checkout -f 6645e70d964500df2dce2b0e66e33c604897a50e
> git rev-list 9840ea2098f4cd4d279d6b6f47768efacf892b3a # timeout=10
[geoserver-2.14.x-live-docs] $ mvn -f doc/en/pom.xml compile
[INFO] Scanning for projects...
[INFO]
[INFO] Building GeoServer English Documentation 2.13-SNAPSHOT
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (coverages) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/coverages.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/coverages/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (coverageStores) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/coveragestores/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (datastores) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/datastores.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/datastores/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (featureTypes) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml>
[WARNING] generated unique operationId `getFeatureTypes_0`
[WARNING] generated unique operationId `putFeatureTypes_0`
[WARNING] generated unique operationId `postFeatureTypes_0`
[WARNING] generated unique operationId `deleteFeatureTypes_0`
[WARNING] generated unique operationId `getFeatureType_0`
[WARNING] generated unique operationId `putFeatureType_0`
[WARNING] generated unique operationId `postFeatureType_0`
[WARNING] generated unique operationId `deleteFeatureType_0`
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/featuretypes/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (fonts) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/fonts.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/fonts/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (layergroups) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/layergroups/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (layers) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/layers.yaml>
[WARNING] Type is NULL for Serializable Parameter: workspaceName
[WARNING] warning! Property type "null" not found for parameter "workspaceName", using String
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/layers/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (manifests) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/manifests.yaml>
[WARNING] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[WARNING] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/manifests/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (namespaces) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/namespaces/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (owsServices) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/owsservices/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (reload) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/reload.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/reload/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (security) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/security.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/security/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (settings) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/settings.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/settings/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (structuredCoverages) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/structuredcoverages/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (styles) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/styles.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/styles/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (template) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/templates.yaml>
[WARNING] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/templates/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmslayers) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/wmslayers/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmsstores) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/wmsstores/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmtslayers) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/wmtslayers/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (wmtsstores) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/wmtsstores/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (workspaces) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/workspaces/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (monitoring) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/monitoring/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/importer.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/importer/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-transforms) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/importerTransforms/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-tasks) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/importerTasks/index.html>
[INFO]
[INFO] --- swagger-codegen-maven-plugin:2.2.2:generate (importer-data) @ gs-docs ---
[INFO] reading from <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/api/1.0.0/importerData.yaml>
[INFO] writing file <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/api/importerData/index.html>
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (compile) @ gs-docs ---
[INFO] Executing tasks
init:
[echo] Base directgory is <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en>
[echo] Build directory is <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target> and project version is 2.13-SNAPSHOT
docguide:
sphinx:
[echo] Running sphinx-build -D release=2.13-SNAPSHOT -W -b html -d "<https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/docguide/doctrees"> . "<https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/target/docguide/html">
user:
sphinx-ignore-warnings:
[exec] <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/points.rst>:101: WARNING: download file not readable: <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/artifacts/point_simplepointwithstroke.ysld>
[exec] <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst>:51: WARNING: Explicit markup ends without a blank line; unexpected unindent.
[exec] <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst>:63: WARNING: download file not readable: <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/artifacts/mbstyle_polygon_simplepolygon.json>
[exec] <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst>:103: WARNING: download file not readable: <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/artifacts/mbstyle_polygon_simplepolygonwithstroke.json>
[exec] <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst>:94: WARNING: undefined label: mbstyle_cookbook_polygons_simplepolygon (if the link has no caption the label must precede a section header)
[exec] <https://build.geoserver.org/job/geoserver-2.14.x-live-docs/ws/doc/en/user/source/styling/mbstyle/cookbook/polygons.rst>:126: WARNING: undefined label: mbstyle_cookbook_polygons_simplepolygon (if the link has no caption the label must precede a section header)
developer:
full:
[INFO] Executed tasks
[INFO] BUILD SUCCESS
[INFO] Total time: 23.345 s
[INFO] Finished at: 2018-11-02T09:49:37+00:00
[INFO] Final Memory: 15M/294M
[geoserver-2.14.x-live-docs] $ /bin/sh -xe /tmp/jenkins1799826794743715745.sh
+ VER=origin/2.14.x
+ VER=2.14.x
+ BASE=/var/www/geoserver/2.14.x/doc/en
+ STAGE=target/2.14.x/en
+ REMOTE=root@anonymised.com:/var/www/docs.geoserver.org/htdocs
+ '[' -e /var/www/geoserver/2.14.x/doc/en ']'
+ cd doc/en
+ mkdir -p target/2.14.x/en
+ rm -rf /var/www/geoserver/2.14.x/doc/en/api
+ cp -r api /var/www/geoserver/2.14.x/doc/en/api
+ cp -r api target/2.14.x/en
+ rm -rf /var/www/geoserver/2.14.x/doc/en/user
+ rm -rf target/2.14.x/en/user
+ cp -r target/user/html /var/www/geoserver/2.14.x/doc/en/user
+ cp -r target/user/html target/2.14.x/en/user
+ cp -r target/api /var/www/geoserver/2.14.x/doc/en/user/api
+ cp -r target/api target/2.14.x/en/user/api
+ rm -rf /var/www/geoserver/2.14.x/doc/en/developer
+ rm -rf target/2.14.x/en/developer
+ cp -r target/developer/html /var/www/geoserver/2.14.x/doc/en/developer
+ cp -r target/developer/html target/2.14.x/en/developer
+ rm -rf /var/www/geoserver/2.14.x/doc/en/docguide
+ rm -rf target/2.14.x/en/docguide
+ cp -r target/docguide/html /var/www/geoserver/2.14.x/doc/en/docguide
+ cp -r target/docguide/html target/2.14.x/en/docguide
+ rsync -av -e 'ssh -p 7777' target/2.14.x/en root@anonymised.com:/var/www/docs.geoserver.org/htdocs/2.14.x
ssh: connect to host docs.geoserver.org port 7777: Network is unreachable
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(600) [sender=3.0.6]
Build step 'Execute shell' marked build as failure
