See <http://build.geoserver.org/job/geoserver-2.14.x-nightly/289/display/redirect>
Started by timer
ln builds/lastSuccessfulBuild /var/lib/jenkins/jobs/geoserver-2.14.x-nightly/lastSuccessful failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-2.14.x-nightly/lastSuccessful
at sun.nio.fs.UnixFileSystemProvider.implDelete(UnixFileSystemProvider.java:242)
at sun.nio.fs.AbstractFileSystemProvider.deleteIfExists(AbstractFileSystemProvider.java:108)
at java.nio.file.Files.deleteIfExists(Files.java:1165)
at hudson.Util.createSymlink(Util.java:1193)
at hudson.model.Run.createSymlink(Run.java:1955)
at hudson.model.Run.updateSymlinks(Run.java:1936)
at hudson.model.Run.execute(Run.java:1814)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
ln builds/lastStableBuild /var/lib/jenkins/jobs/geoserver-2.14.x-nightly/lastStable failed
java.nio.file.DirectoryNotEmptyException: /var/lib/jenkins/jobs/geoserver-2.14.x-nightly/lastStable
at hudson.model.Run.updateSymlinks(Run.java:1937)
Building remotely on i-0ac7db84a05b1f210 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-2.14.x-nightly/ws/>
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <http://build.geoserver.org/job/geoserver-2.14.x-nightly/ws/> # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
ERROR: Error cloning remote repo 'origin'
hudson.plugins.git.GitException: Command "git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: remote: Enumerating objects: 128, done.
remote: Counting objects: 0% (1/128) remote: Counting objects: 1% (2/128) remote: Counting objects: 2% (3/128) remote: Counting objects: 3% (4/128) remote: Counting objects: 4% (6/128) remote: Counting objects: 5% (7/128) remote: Counting objects: 6% (8/128) remote: Counting objects: 7% (9/128) remote: Counting objects: 8% (11/128) remote: Counting objects: 9% (12/128) remote: Counting objects: 10% (13/128) remote: Counting objects: 11% (15/128) remote: Counting objects: 12% (16/128) remote: Counting objects: 13% (17/128) remote: Counting objects: 14% (18/128) remote: Counting objects: 15% (20/128) remote: Counting objects: 16% (21/128) remote: Counting objects: 17% (22/128) remote: Counting objects: 18% (24/128) remote: Counting objects: 19% (25/128) remote: Counting objects: 20% (26/128) remote: Counting objects: 21% (27/128) remote: Counting objects: 22% (29/128) remote: Counting objects: 23% (30/128) remote: Counting objects: 24% (31/128) remote: Counting objects: 25% (32/128) remote: Counting objects: 26% (34/128) remote: Counting objects: 27% (35/128) remote: Counting objects: 28% (36/128) remote: Counting objects: 29% (38/128) remote: Counting objects: 30% (39/128) remote: Counting objects: 31% (40/128) remote: Counting objects: 32% (41/128) remote: Counting objects: 33% (43/128) remote: Counting objects: 34% (44/128) remote: Counting objects: 35% (45/128) remote: Counting objects: 36% (47/128) remote: Counting objects: 37% (48/128) remote: Counting objects: 38% (49/128) remote: Counting objects: 39% (50/128) remote: Counting objects: 40% (52/128) remote: Counting objects: 41% (53/128) remote: Counting objects: 42% (54/128) remote: Counting objects: 43% (56/128) remote: Counting objects: 44% (57/128) remote: Counting objects: 45% (58/128) remote: Counting objects: 46% (59/128) remote: Counting objects: 47% (61/128) remote: Counting objects: 48% (62/128) remote: Counting objects: 49% (63/128) remote: Counting objects: 50% (64/128) remote: Counting objects: 51% (66/128) remote: Counting objects: 52% (67/128) remote: Counting objects: 53% (68/128) remote: Counting objects: 54% (70/128) remote: Counting objects: 55% (71/128) remote: Counting objects: 56% (72/128) remote: Counting objects: 57% (73/128) remote: Counting objects: 58% (75/128) remote: Counting objects: 59% (76/128) remote: Counting objects: 60% (77/128) remote: Counting objects: 61% (79/128) remote: Counting objects: 62% (80/128) remote: Counting objects: 63% (81/128) remote: Counting objects: 64% (82/128) remote: Counting objects: 65% (84/128) remote: Counting objects: 66% (85/128) remote: Counting objects: 67% (86/128) remote: Counting objects: 68% (88/128) remote: Counting objects: 69% (89/128) remote: Counting objects: 70% (90/128) remote: Counting objects: 71% (91/128) remote: Counting objects: 72% (93/128) remote: Counting objects: 73% (94/128) remote: Counting objects: 74% (95/128) remote: Counting objects: 75% (96/128) remote: Counting objects: 76% (98/128) remote: Counting objects: 77% (99/128) remote: Counting objects: 78% (100/128) remote: Counting objects: 79% (102/128) remote: Counting objects: 80% (103/128) remote: Counting objects: 81% (104/128) remote: Counting objects: 82% (105/128) remote: Counting objects: 83% (107/128) remote: Counting objects: 84% (108/128) remote: Counting objects: 85% (109/128) remote: Counting objects: 86% (111/128) remote: Counting objects: 87% (112/128) remote: Counting objects: 88% (113/128) remote: Counting objects: 89% (114/128) remote: Counting objects: 90% (116/128) remote: Counting objects: 91% (117/128) remote: Counting objects: 92% (118/128) remote: Counting objects: 93% (120/128) remote: Counting objects: 94% (121/128) remote: Counting objects: 95% (122/128) remote: Counting objects: 96% (123/128) remote: Counting objects: 97% (125/128) remote: Counting objects: 98% (126/128) remote: Counting objects: 99% (127/128) remote: Counting objects: 100% (128/128) remote: Counting objects: 100% (128/128), done.
remote: Compressing objects: 1% (1/90) remote: Compressing objects: 2% (2/90) remote: Compressing objects: 3% (3/90) remote: Compressing objects: 4% (4/90) remote: Compressing objects: 5% (5/90) remote: Compressing objects: 6% (6/90) remote: Compressing objects: 7% (7/90) remote: Compressing objects: 8% (8/90) remote: Compressing objects: 10% (9/90) remote: Compressing objects: 11% (10/90) remote: Compressing objects: 12% (11/90) remote: Compressing objects: 13% (12/90) remote: Compressing objects: 14% (13/90) remote: Compressing objects: 15% (14/90) remote: Compressing objects: 16% (15/90) remote: Compressing objects: 17% (16/90) remote: Compressing objects: 18% (17/90) remote: Compressing objects: 20% (18/90) remote: Compressing objects: 21% (19/90) remote: Compressing objects: 22% (20/90) remote: Compressing objects: 23% (21/90) remote: Compressing objects: 24% (22/90) remote: Compressing objects: 25% (23/90) remote: Compressing objects: 26% (24/90) remote: Compressing objects: 27% (25/90) remote: Compressing objects: 28% (26/90) remote: Compressing objects: 30% (27/90) remote: Compressing objects: 31% (28/90) remote: Compressing objects: 32% (29/90) remote: Compressing objects: 33% (30/90) remote: Compressing objects: 34% (31/90) remote: Compressing objects: 35% (32/90) remote: Compressing objects: 36% (33/90) remote: Compressing objects: 37% (34/90) remote: Compressing objects: 38% (35/90) remote: Compressing objects: 40% (36/90) remote: Compressing objects: 41% (37/90) remote: Compressing objects: 42% (38/90) remote: Compressing objects: 43% (39/90) remote: Compressing objects: 44% (40/90) remote: Compressing objects: 45% (41/90) remote: Compressing objects: 46% (42/90) remote: Compressing objects: 47% (43/90) remote: Compressing objects: 48% (44/90) remote: Compressing objects: 50% (45/90) remote: Compressing objects: 51% (46/90) remote: Compressing objects: 52% (47/90) remote: Compressing objects: 53% (48/90) remote: Compressing objects: 54% (49/90) remote: Compressing objects: 55% (50/90) remote: Compressing objects: 56% (51/90) remote: Compressing objects: 57% (52/90) remote: Compressing objects: 58% (53/90) remote: Compressing objects: 60% (54/90) remote: Compressing objects: 61% (55/90) remote: Compressing objects: 62% (56/90) remote: Compressing objects: 63% (57/90) remote: Compressing objects: 64% (58/90) remote: Compressing objects: 65% (59/90) remote: Compressing objects: 66% (60/90) remote: Compressing objects: 67% (61/90) remote: Compressing objects: 68% (62/90) remote: Compressing objects: 70% (63/90) remote: Compressing objects: 71% (64/90) remote: Compressing objects: 72% (65/90) remote: Compressing objects: 73% (66/90) remote: Compressing objects: 74% (67/90) remote: Compressing objects: 75% (68/90) remote: Compressing objects: 76% (69/90) remote: Compressing objects: 77% (70/90) remote: Compressing objects: 78% (71/90) remote: Compressing objects: 80% (72/90) remote: Compressing objects: 81% (73/90) remote: Compressing objects: 82% (74/90) remote: Compressing objects: 83% (75/90) remote: Compressing objects: 84% (76/90) remote: Compressing objects: 85% (77/90) remote: Compressing objects: 86% (78/90) remote: Compressing objects: 87% (79/90) remote: Compressing objects: 88% (80/90) remote: Compressing objects: 90% (81/90) remote: Compressing objects: 91% (82/90) remote: Compressing objects: 92% (83/90) remote: Compressing objects: 93% (84/90) remote: Compressing objects: 94% (85/90) remote: Compressing objects: 95% (86/90) remote: Compressing objects: 96% (87/90) remote: Compressing objects: 97% (88/90) remote: Compressing objects: 98% (89/90) remote: Compressing objects: 100% (90/90) remote: Compressing objects: 100% (90/90), done.
Receiving objects: 0% (1/328978) Receiving objects: 1% (3290/328978) fatal: write error: No space left on device
fatal: index-pack failed
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2042)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1761)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$400(CliGitAPIImpl.java:72)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:442)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:655)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.lang.Thread.run(Thread.java:834)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-0ac7db84a05b1f210
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:957)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
at sun.reflect.GeneratedMethodAccessor476.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
at com.sun.proxy.$Proxy89.execute(Unknown Source)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1152)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1192)
at hudson.scm.SCM.checkout(SCM.java:504)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1816)
Skipped archiving because build is not successful
