See <https://build.geoserver.org/job/geoserver-2.15.x/455/display/redirect?page=changes>
Changes:
[maurobartolomeoli] [GEOS-9256]: fixed conflict between params-extractor and monitor
[...truncated 1.46 MB...]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-web ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/surefire-reports>
T E S T S
Running org.geoserver.importer.web.AbstractDBPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.026 sec
Running org.geoserver.importer.web.ImportTaskTableTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.959 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[debug] Using AOSP style
[INFO] Processed 35 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT [94/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src>
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 218.687 sec
Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.5 sec
Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.08 sec
Results :
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-bdb ---
[INFO] Processed 8 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.15-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.884 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.161 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 8.622 s]
[INFO] Main Module ........................................ SUCCESS [01:11 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.042 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:31 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 41.328 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 18.485 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.438 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.692 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.913 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:04 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:11 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:14 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 18.351 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.070 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:08 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:30 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.961 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 14.062 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [04:08 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.071 s]
[INFO] Core UI Module ..................................... SUCCESS [ 53.591 s]
[INFO] WMS UI Module ...................................... SUCCESS [06:27 min]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 7.424 s]
[INFO] Demos Module ....................................... SUCCESS [02:24 min]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.935 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.040 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:11 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [03:44 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 10.248 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.709 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.059 s]
[INFO] Printing Module .................................... SUCCESS [ 7.409 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.068 s]
[INFO] Application Schema Integration Test ................ SUCCESS [11:37 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.261 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.691 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.022 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.908 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.508 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.216 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.166 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.310 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.288 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.236 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.264 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.131 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.028 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:00 min]
[INFO] OGR WPS ............................................ SUCCESS [ 6.238 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.719 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.475 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.558 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.478 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.592 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 26.585 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 26.685 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.392 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.426 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.035 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.051 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.583 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.289 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.261 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.354 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.052 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.354 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.535 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [05:49 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.056 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.028 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.521 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.747 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.029 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.947 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 46.703 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.925 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.069 s]
[INFO] Importer Core Module ............................... SUCCESS [ 38.424 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 41.574 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [03:43 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 10.519 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 20.763 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [04:36 min]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 41.778 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.798 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.987 s]
[INFO] REST SLD service ................................... SUCCESS [03:45 min]
[INFO] GeoFence security integration ...................... SUCCESS [09:51 min]
[INFO] GeoFence Server .................................... SUCCESS [06:23 min]
[INFO] BUILD FAILURE
[INFO] Total time: 44:32 min (Wall Clock)
[INFO] Finished at: 2019-06-21T14:38:50Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
Not sending mail to unregistered user maurobartolomeoli@anonymised.com
