See <https://build.geoserver.org/job/geoserver-2.15.x/468/display/redirect?page=changes>
Changes:
[fernandomino7] [GEOS-9271] NullPointerException on WFS ComplexGeoJsonWriter Link check
[...truncated 1019.04 KB...]
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/target/surefire-reports>
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.823 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[debug] Using AOSP style
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT [72/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src>
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.76 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-wcs2_0-eo ---
[INFO] Processed 4 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.15-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.15-SNAPSHOT/gs-web-wcs2_0-eo-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wcs2_0-eo/web/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.15-SNAPSHOT/gs-web-wcs2_0-eo-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.15-SNAPSHOT/gs-web-wcs2_0-eo-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.15-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.15-SNAPSHOT/gs-web-wcs2_0-eo-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.15-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.15-SNAPSHOT/gs-web-wcs2_0-eo-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.15-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.377 s]
[INFO] Core Platform Module ............................... SUCCESS [ 9.492 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.206 s]
[INFO] Main Module ........................................ SUCCESS [ 47.872 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.049 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:28 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [07:48 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.753 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.500 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.684 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 11.871 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 52.047 s]
[INFO] Web Feature Service Module ......................... SUCCESS [06:06 min]
[INFO] Web Map Service Module ............................. FAILURE [01:35 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 6.465 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:16 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [03:24 min]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.038 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.046 s]
[INFO] Core UI Module ..................................... SUCCESS [06:01 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 5.570 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.029 s]
[INFO] Security UI Core Module ............................ SUCCESS [03:50 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [03:44 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 5.544 s]
[INFO] REST UI Module ..................................... SUCCESS [ 5.539 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.029 s]
[INFO] Printing Module .................................... SUCCESS [ 6.209 s]
[INFO] Community Space .................................... SUCCESS [ 0.021 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.021 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.316 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.176 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.295 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.723 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.658 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.201 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.225 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.170 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.219 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.268 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.117 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.019 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 45.671 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.497 s]
[INFO] Excel Output Format ................................ SUCCESS [ 7.191 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.394 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.412 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.375 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.387 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 11.967 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.130 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.411 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.029 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.027 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 1.573 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.237 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.474 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.064 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 3.960 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [03:57 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 4.608 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.016 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.409 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.372 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.016 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.824 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.953 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.673 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.330 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 23:15 min (Wall Clock)
[INFO] Finished at: 2019-07-04T10:01:15Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Not sending mail to unregistered user fernandomino7@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.15.x/469/display/redirect>
[...truncated 1019.34 KB...]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/target/gs-web-sec-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/src/main/java’> does not exist, ignoring.
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/src/test/java’> does not exist, ignoring.
[INFO] Processed 0 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-web-sec/2.15-SNAPSHOT/gs-web-sec-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/target/gs-web-sec-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-web-sec/2.15-SNAPSHOT/gs-web-sec-2.15-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoFence Server
[INFO]
[INFO] Skipping Importer REST Api Module-ng
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO]
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO] Skipping GeoServer Web Application
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.247 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-sec-cas ---
[INFO] Processed 13 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/cas/pom.xml> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-tests.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/cas/target/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar> to /home/ubuntu/.m2/repository/org/geoserver/security/gs-sec-cas/2.15-SNAPSHOT/gs-sec-cas-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 4.329 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.022 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.380 s]
[INFO] Main Module ........................................ SUCCESS [ 53.186 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.050 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [03:19 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 40.159 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.177 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.446 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.406 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.619 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 56.933 s]
[INFO] Web Feature Service Module ......................... SUCCESS [03:56 min]
[INFO] Web Map Service Module ............................. FAILURE [01:56 min]
[INFO] gs-rest ............................................ SUCCESS [ 6.631 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:42 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.473 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.991 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.049 s]
[INFO] Core UI Module ..................................... SUCCESS [ 49.294 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.966 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.049 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:06 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:28 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 6.441 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.453 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.030 s]
[INFO] Printing Module .................................... SUCCESS [ 7.633 s]
[INFO] Community Space .................................... SUCCESS [ 0.024 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.300 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 8.306 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.562 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.802 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.565 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.203 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.229 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.226 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.214 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.278 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.834 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.475 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.016 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.466 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.393 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.409 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.574 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.406 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 6.988 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.879 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.498 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.041 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 1.945 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.273 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.930 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.058 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 7.281 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.879 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 45.891 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.711 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.153 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.179 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.020 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.720 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [01:02 min]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 13.245 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.152 s]
[INFO] Total time: 12:30 min (Wall Clock)
[INFO] Finished at: 2019-07-04T11:54:28Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x/470/display/redirect>
[...truncated 1.10 MB...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.571 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.209 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Processed 14 files (0 non-complying).
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.300 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.011 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.907 s]
[INFO] Main Module ........................................ SUCCESS [ 57.911 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.053 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:26 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 38.668 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.517 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.418 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.620 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.266 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 54.765 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:05 min]
[INFO] Web Map Service Module ............................. FAILURE [01:41 min]
[INFO] gs-rest ............................................ SUCCESS [ 6.379 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:25 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.830 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 11.442 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.124 s]
[INFO] Core UI Module ..................................... SUCCESS [ 46.620 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 6.448 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.046 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:01 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 54.335 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 6.533 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.412 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 7.294 s]
[INFO] Community Space .................................... SUCCESS [ 0.023 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.864 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.414 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 6.945 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.795 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.708 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.267 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.337 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.220 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.283 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.017 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.348 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.291 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 48.846 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.679 s]
[INFO] Excel Output Format ................................ SUCCESS [ 7.497 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.484 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.457 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.554 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.814 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 6.449 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.503 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.725 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.026 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 1.730 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.239 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.644 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.061 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.897 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.256 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 21.773 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.008 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.811 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.613 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.056 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.266 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 44.679 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.980 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.353 s]
[INFO] Total time: 09:12 min (Wall Clock)
[INFO] Finished at: 2019-07-04T13:16:57Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
