[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x #477
See <https://build.geoserver.org/job/geoserver-2.15.x/477/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Adding missing image file for the azure gwc docs
Started by an SCM change
Building remotely on FleetCloud i-0a998146de608786e (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-2.15.x/ws/&gt;
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/2.15.x^{commit} # timeout=10
Checking out Revision 9e2b417b537ad08d3c10be1391f7854492e7c433 (origin/2.15.x)
> git config core.sparsecheckout # timeout=10
> git checkout -f 9e2b417b537ad08d3c10be1391f7854492e7c433
Commit message: "Adding missing image file for the azure gwc docs"
> git rev-list --no-walk 638c333130ff8df0bc961d139c9c68445c416908 # timeout=10
provisioning config files...
copy managed file [MavenSettings] to <https://build.geoserver.org/job/geoserver-2.15.x/ws/settings.xml&gt;
[geoserver-2.15.x] $ mvn -f src/pom.xml -B -U -P allExtensions,printing,secJdbcJndiTest clean install -DconfigDirectory=../../../data -T2 -fae -Dfmt.action=check
Unrecognized option: --batch-mode
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
See <https://build.geoserver.org/job/geoserver-2.15.x/478/display/redirect?page=changes&gt;
