[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x #509
See <https://build.geoserver.org/job/geoserver-2.15.x/509/display/redirect?page=changes&gt;
Changes:
[daniele.romagnoli] Follow up on scale/offset imageio-ext and gt support
[...truncated 1004.08 KB...]
Aug 26, 2019 12:18:52 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is STARTED
Aug 26, 2019 12:18:52 PM com.hazelcast.system
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast 3.11.1 (20181218 - d294f31) starting at [127.0.0.1]:5702
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Copyright (c) 2008-2018, Hazelcast, Inc. All Rights Reserved.
Aug 26, 2019 12:18:52 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] A non-empty group password is configured for the Hazelcast member. Starting with Hazelcast version 3.8.2, members with the same group name, but with different group passwords (that do not use authentication) form a cluster. The group password configuration will be removed completely in a future release.
Aug 26, 2019 12:18:52 PM com.hazelcast.spi.impl.operationservice.impl.BackpressureRegulator
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Backpressure is disabled
Aug 26, 2019 12:18:52 PM com.hazelcast.spi.impl.operationexecutor.impl.OperationExecutorImpl
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Starting 8 partition threads and 5 generic threads (1 dedicated for priority tasks)
Aug 26, 2019 12:18:52 PM com.hazelcast.internal.diagnostics.Diagnostics
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Diagnostics disabled. To enable add -Dhazelcast.diagnostics.enabled=true to the JVM arguments.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTING
Aug 26, 2019 12:18:52 PM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Created connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Aug 26, 2019 12:18:52 PM com.hazelcast.internal.cluster.ClusterService
Members {size:2, ver:2} [
  Member [127.0.0.1]:5701 - bc3675fb-d34b-4f7a-9e1f-4f10152eb158 this
  Member [127.0.0.1]:5702 - bef9bbc7-56ab-44bf-b8d3-49225c4bd918
  Member [127.0.0.1]:5702 - bef9bbc7-56ab-44bf-b8d3-49225c4bd918 this
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTED
Aug 26, 2019 12:18:52 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Aug 26, 2019 12:18:52 PM com.hazelcast.internal.partition.impl.PartitionStateManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Initializing cluster partition table arrangement...
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTTING_DOWN
Aug 26, 2019 12:18:52 PM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5702 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Re-partitioning cluster data... Migration queue size: 135
Aug 26, 2019 12:18:53 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down connection manager...
Aug 26, 2019 12:18:53 PM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Aug 26, 2019 12:18:53 PM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - bef9bbc7-56ab-44bf-b8d3-49225c4bd918
Aug 26, 2019 12:18:53 PM com.hazelcast.internal.cluster.ClusterService
Members {size:1, ver:3} [
Aug 26, 2019 12:18:53 PM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: bef9bbc7-56ab-44bf-b8d3-49225c4bd918
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down node engine...
Aug 26, 2019 12:18:53 PM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Partition balance is ok, no need to re-partition cluster data...
Aug 26, 2019 12:18:53 PM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 127 ms.
Aug 26, 2019 12:18:53 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTDOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTTING_DOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5701 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down connection manager...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down node engine...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 7 ms.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.672 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-wps-cluster-hazelcast ---
[debug] Using AOSP style
[INFO] Processed 5 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-tests.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-test-sources.jar&gt; to /home/ubuntu/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary for GeoServer 2.15-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.649 s]
[INFO] Core Platform Module ............................... SUCCESS [ 10.792 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.568 s]
[INFO] Main Module ........................................ SUCCESS [ 49.418 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.049 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:18 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 35.920 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 17.550 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.437 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 10.270 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 11.532 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:03 min]
[INFO] Web Feature Service Module ......................... SUCCESS [ 56.075 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:33 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 14.734 s]
[INFO] gs-rest ............................................ SUCCESS [ 6.026 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 51.974 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:15 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 9.127 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 10.886 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 8.148 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.108 s]
[INFO] Core UI Module ..................................... FAILURE [ 2.987 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.029 s]
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.023 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 6.194 s]
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.775 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.637 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.242 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.226 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.425 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.725 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.274 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.016 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.278 s]
[INFO] OGR WFS ............................................ SUCCESS [ 3.990 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.018 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 45.876 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.467 s]
[INFO] Excel Output Format ................................ SUCCESS [ 6.907 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.499 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.433 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.454 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.359 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 11.764 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 8.452 s]
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SUCCESS [ 10.864 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.027 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.004 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.248 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 20.144 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.018 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 6.337 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 4.271 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.014 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 8.991 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 4.998 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.039 s]
[INFO] Importer Core Module ............................... SUCCESS [ 22.848 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 25.679 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 8.536 s]
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SUCCESS [ 8.426 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.267 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.653 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] System Status Extension ............................ SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 07:46 min (Wall Clock)
[INFO] Finished at: 2019-08-26T12:18:53Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-web-core: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/web/core/src/test/java/org/geoserver/web/data/resource/ResourceConfigurationPageTest.java&gt;:\[12,1\] cannot find symbol
[ERROR] symbol: static RESCALE_PIXELS
[ERROR] location: class
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/web/core/src/test/java/org/geoserver/web/data/resource/ResourceConfigurationPageTest.java&gt;:\[203,32\] cannot find symbol
[ERROR] symbol: variable RESCALE_PIXELS
[ERROR] location: class org.geoserver.web.data.resource.ResourceConfigurationPageTest
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
Not sending mail to unregistered user daniele.romagnoli@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.15.x/510/display/redirect&gt;
