See <https://build.geoserver.org/job/geoserver-2.15.x/56/display/redirect>
[...truncated 1.14 MB...]
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/surefire-reports>
T E S T S
Running org.geoserver.importer.web.AbstractDBPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.614 sec
Running org.geoserver.importer.web.ImportTaskTableTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.617 sec
Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.527 sec
Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.693 sec
Results :
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-bdb ---
[debug] Using AOSP style
[INFO] Processed 8 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src>
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.784 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[INFO] Processed 35 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/pom.xml> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar> to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.316 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.857 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.873 s]
[INFO] Main Module ........................................ SUCCESS [01:31 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.130 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:28 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 43.533 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 4.676 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.645 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.956 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 23.589 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [01:00 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:57 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:54 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.425 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.725 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:34 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:52 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 22.716 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 26.217 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 15.980 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.136 s]
[INFO] Core UI Module ..................................... SUCCESS [01:26 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 48.125 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 59.391 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.109 s]
[INFO] Demos Module ....................................... SUCCESS [ 24.475 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.148 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.084 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:13 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:38 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 13.590 s]
[INFO] REST UI Module ..................................... SUCCESS [ 15.978 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.071 s]
[INFO] Printing Module .................................... SUCCESS [ 12.020 s]
[INFO] Community Space .................................... SUCCESS [ 0.032 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.047 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:30 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 14.104 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.415 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 15.005 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.826 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.614 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.227 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.246 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.554 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.166 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.512 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.086 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.853 s]
[INFO] OGR WFS ............................................ SUCCESS [ 7.596 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.052 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 14.368 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.564 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.304 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.545 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 14.685 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.619 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.778 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.169 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 27.061 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.054 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.820 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.107 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.714 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 23.608 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 21.314 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.154 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.748 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 8.872 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 47.986 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.616 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.061 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.350 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.044 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.637 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.132 s]
[INFO] Importer Core Module ............................... SUCCESS [01:03 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [01:00 min]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 20.388 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.248 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.820 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 28.555 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 20.936 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.271 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.601 s]
[INFO] REST SLD service ................................... SUCCESS [ 30.824 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 31.845 s]
[INFO] GeoFence Server .................................... SUCCESS [ 57.753 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:52 min (Wall Clock)
[INFO] Finished at: 2019-03-16T14:36:37+00:00
[INFO] Final Memory: 327M/1365M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/wcs2_0/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
