[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x #83
See <https://build.geoserver.org/job/geoserver-2.15.x/83/display/redirect?page=changes&gt;
Changes:
[Jody Garnett] fix relative java.io.tmpdir reference
[Jody Garnett] Update based on windows installer wrapper.conf
[...truncated 1.31 MB...]
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.173 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-app ---
[warn] Source directory '<https://build.geoserver.org/job/geoserver-2.15.x/ws/src/web/app/src/main/java’> does not exist, ignoring.
[debug] Using AOSP style
[INFO] Processed 6 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/web/app/target/geoserver.war&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/web/app/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/web/app/target/gs-web-app-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT-test-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/web/app/target/geoserver.war&gt; to /var/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.15-SNAPSHOT/gs-web-app-2.15-SNAPSHOT.war
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.455 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src&gt;
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.361 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.568 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.005 s]
[INFO] Main Module ........................................ SUCCESS [ 56.063 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.065 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:02 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 29.100 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.294 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.844 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.401 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.679 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 35.194 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:16 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:44 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 18.511 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.192 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:25 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:03 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.674 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.564 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 8.891 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.073 s]
[INFO] Core UI Module ..................................... SUCCESS [01:00 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 25.423 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 39.321 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 8.067 s]
[INFO] Demos Module ....................................... SUCCESS [ 11.819 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.149 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.052 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:15 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 55.971 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 7.378 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.264 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.053 s]
[INFO] Printing Module .................................... SUCCESS [ 8.135 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 4.967 s]
[INFO] Community Space .................................... SUCCESS [ 0.032 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.033 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:10 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.609 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.629 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.476 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.753 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.553 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.219 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.227 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 3.456 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.661 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.265 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.045 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.499 s]
[INFO] OGR WFS ............................................ FAILURE [ 9.656 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.034 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.600 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.774 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.490 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.774 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.427 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.146 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.098 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.420 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.072 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.606 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.070 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 20.300 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.105 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.540 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 14.046 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 24.085 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.578 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.031 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.436 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.345 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 25.631 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.613 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.037 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.403 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.753 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.036 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.949 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 7.896 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 5.958 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.040 s]
[INFO] Importer Core Module ............................... SUCCESS [ 39.927 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 33.622 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 10.314 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.044 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.862 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.299 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 24.333 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.545 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.726 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.281 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.618 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 16.791 s]
[INFO] GeoFence Server .................................... SUCCESS [ 25.250 s]
[INFO] BUILD FAILURE
[INFO] Total time: 14:14 min (Wall Clock)
[INFO] Finished at: 2019-04-29T04:07:23+00:00
[INFO] Final Memory: 361M/1546M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-ogr-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/ogr/ogr-wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ogr-wfs
See <https://build.geoserver.org/job/geoserver-2.15.x/84/display/redirect&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Apr 29, 2019 7:10:26 AM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
  at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
  at org.geoserver.importer.Importer.addTasks(Importer.java:472)
  at org.geoserver.importer.Importer.init(Importer.java:440)
  at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:221)
  at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:72)
  at sun.reflect.GeneratedMethodAccessor297.invoke(Unknown Source)
  at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
  at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
  at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
  at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
  at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
  at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:901)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
  at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
  at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:166)
  at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:133)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
  at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.083 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.509 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.452 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.870 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.129 s]
[INFO] Main Module ........................................ SUCCESS [ 55.677 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.123 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 32.612 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.275 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.845 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.467 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.969 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 36.186 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:17 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:43 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 19.497 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.163 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 56.066 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:04 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.989 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.597 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 8.998 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.084 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.649 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 34.397 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.977 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.638 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.346 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.065 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:14 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 55.093 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 7.477 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.537 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.066 s]
[INFO] Printing Module .................................... SUCCESS [ 8.441 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.369 s]
[INFO] Community Space .................................... SUCCESS [ 0.034 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.035 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:12 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.546 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.523 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.571 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.783 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.572 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.222 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.223 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.368 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.766 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.255 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.040 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.472 s]
[INFO] OGR WFS ............................................ FAILURE [ 9.515 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.039 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.299 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.483 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.456 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.725 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.477 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.059 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.653 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 23.735 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.251 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.778 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.058 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 18.719 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.034 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.493 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.095 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.416 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 14.239 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 24.354 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.310 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.050 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.387 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.720 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 26.650 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 6.617 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.027 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.483 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.128 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.029 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.962 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 9.490 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.781 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.112 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.437 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 34.479 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 11.671 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.631 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.856 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.982 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 31.187 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.074 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 10.024 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.306 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.610 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 16.420 s]
[INFO] GeoFence Server .................................... SUCCESS [ 29.097 s]
[INFO] Total time: 14:12 min (Wall Clock)
[INFO] Finished at: 2019-04-29T07:10:27+00:00
[INFO] Final Memory: 347M/1686M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x/85/display/redirect&gt;
Apr 29, 2019 8:35:37 AM org.geoserver.importer.Importer init
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.921 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.525 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.591 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.935 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.936 s]
[INFO] Main Module ........................................ SUCCESS [01:00 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.069 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 29.131 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.991 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.869 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.571 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.706 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 36.142 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 19.561 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.054 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 55.717 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.921 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.491 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.183 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.089 s]
[INFO] Core UI Module ..................................... SUCCESS [01:01 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.256 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 34.258 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.810 s]
[INFO] Demos Module ....................................... SUCCESS [ 15.062 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.222 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.078 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 55.221 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 7.476 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.346 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.041 s]
[INFO] Printing Module .................................... SUCCESS [ 8.206 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.592 s]
[INFO] Community Space .................................... SUCCESS [ 0.033 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.034 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:11 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.479 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.314 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.581 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.754 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.578 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.218 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.269 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.417 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.669 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.258 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.044 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.573 s]
[INFO] OGR WFS ............................................ FAILURE [ 9.195 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.059 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 57.731 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.350 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.457 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.653 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.438 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.177 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.559 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 22.450 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.933 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.551 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.062 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.414 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.254 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.619 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.709 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 23.941 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.051 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.056 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.304 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.530 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 26.660 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.156 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.288 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.529 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.028 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.090 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.860 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.678 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.066 s]
[INFO] Importer Core Module ............................... SUCCESS [ 33.146 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 32.620 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 11.428 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.917 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 12.019 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.891 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 33.190 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.273 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.887 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.314 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.354 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 16.753 s]
[INFO] GeoFence Server .................................... SUCCESS [ 31.246 s]
[INFO] Total time: 14:13 min (Wall Clock)
[INFO] Finished at: 2019-04-29T08:35:38+00:00
[INFO] Final Memory: 340M/1692M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x/86/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-8450] DescribeCoverage should not fail on secured datasets with
[...truncated 1.32 MB...]
Apr 30, 2019 8:51:52 AM org.geoserver.importer.Importer init
  at sun.reflect.GeneratedMethodAccessor295.invoke(Unknown Source)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.442 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.514 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.639 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.718 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.273 s]
[INFO] Main Module ........................................ SUCCESS [ 57.813 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.081 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 47.662 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.260 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.785 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.740 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.962 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 38.020 s]
[INFO] Web Map Service Module ............................. SUCCESS [01:45 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.342 s]
[INFO] gs-rest ............................................ SUCCESS [ 8.911 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 26.543 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 27.353 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 11.704 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.090 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 44.266 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:11 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.896 s]
[INFO] Demos Module ....................................... SUCCESS [ 39.526 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 19.746 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.056 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:32 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [02:03 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.204 s]
[INFO] REST UI Module ..................................... SUCCESS [ 14.189 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.065 s]
[INFO] Printing Module .................................... SUCCESS [ 8.625 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.637 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.030 s]
[INFO] Application Schema Integration Test ................ SUCCESS [03:58 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.496 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.287 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.234 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.746 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.586 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.225 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.249 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.453 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.738 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.294 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.058 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.537 s]
[INFO] OGR WFS ............................................ FAILURE [ 9.216 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.057 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:12 min]
[INFO] Excel Output Format ................................ SUCCESS [ 9.538 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.481 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.581 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.457 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.122 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 16.429 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 47.189 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.062 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.545 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.039 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 32.628 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.136 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 3.908 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.106 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.543 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 29.150 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 49.769 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 24.045 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.037 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.381 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 14.599 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 49.435 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.532 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.065 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.298 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 13.204 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 27.076 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 22.150 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 18.426 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.147 s]
[INFO] Importer Core Module ............................... SUCCESS [01:04 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 35.553 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 11.490 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 10.382 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.609 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 37.490 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [01:00 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 26.058 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 18.273 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.380 s]
[INFO] REST SLD service ................................... SUCCESS [ 36.038 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 38.651 s]
[INFO] GeoFence Server .................................... SUCCESS [ 57.911 s]
[INFO] Total time: 21:39 min (Wall Clock)
[INFO] Finished at: 2019-04-30T08:51:53+00:00
[INFO] Final Memory: 341M/1534M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x/87/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-9153] WCS 2.0 scaling policies do not account for scaling factor
[Andrea Aime] [GEOS-9192] GeoServer UI let's you save duplicate grids names
[Andrea Aime] Fix for Solr circular Spring Bean reference exception
Apr 30, 2019 10:38:17 AM org.geoserver.importer.Importer init
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.236 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.546 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.736 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.771 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.089 s]
[INFO] Main Module ........................................ SUCCESS [ 54.773 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.076 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 29.720 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.189 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.329 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.085 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 37.960 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 19.461 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.017 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 56.241 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:05 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 11.646 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.860 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.106 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.079 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.336 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 34.977 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.854 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.770 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.328 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.055 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 55.001 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 7.605 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.402 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.058 s]
[INFO] Printing Module .................................... SUCCESS [ 8.187 s]
[INFO] Community Space .................................... SUCCESS [ 0.036 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.363 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.528 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.474 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.741 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.566 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.209 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.243 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.200 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.873 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.314 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.028 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.606 s]
[INFO] OGR WFS ............................................ FAILURE [ 9.337 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.033 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 57.776 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.422 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.450 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.748 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.432 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.175 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 10.358 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 22.428 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.195 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.509 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.052 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.410 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.269 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.472 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.415 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 23.837 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.551 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.350 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.328 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 27.297 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 7.669 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.035 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.294 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.489 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.031 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.844 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 11.704 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.495 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.075 s]
[INFO] Importer Core Module ............................... SUCCESS [ 32.681 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 33.104 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 11.327 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 10.107 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.661 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 16.425 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 34.892 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.690 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.571 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.463 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 17.112 s]
[INFO] GeoFence Server .................................... SUCCESS [ 32.062 s]
[INFO] Finished at: 2019-04-30T10:38:18+00:00
[INFO] Final Memory: 346M/1649M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
2.15.x has been failing for a number of builds, starting on a seemingly unrelated change:
Checking the failure, it seems like a system installation problem on the server, see this:
Tests run: 10, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 1.934 sec <<< FAILURE!
testSimpleCSV(org.geoserver.wfs.response.Ogr2OgrFormatTest)  Time elapsed: 978 sec  <<< ERROR!
org.geoserver.platform.ServiceException: Exception occurred during output generation
	at org.geoserver.wfs.response.Ogr2OgrOutputFormat.write(Ogr2OgrOutputFormat.java:307)
	at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:200)
	at org.geoserver.wfs.response.Ogr2OgrFormatTest.testSimpleCSV(Ogr2OgrFormatTest.java:196)
<b>Caused by: java.io.IOException: ogr2ogr did not terminate successfully, exit code 1. Was trying to run: [ogr2ogr, -f, CSV, -a_srs, /tmp/ogrtmpin0.367406913451224/srs8240695920266311468wkt, /tmp/ogrtmpout0.18567878589886866/Buildings.csv, /tmp/ogrtmpin0.367406913451224/Buildings.gml]
Resulted in:
ERROR 1: Unable to create Xerces C++ or Expat based GML reader, Xerces or Expat support
not configured into GDAL/OGR.
ERROR 1: File /tmp/ogrtmpin0.367406913451224/Buildings.gml appears to be GML but the GML reader can't
be instantiated, likely because Xerces or Expat support wasn't
configured in.
FAILURE:</b>
Maybe some updates occurred April 29th that broke the ogr2ogr installation?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
See <https://build.geoserver.org/job/geoserver-2.15.x/88/display/redirect&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.818 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/src/test/java/org/geoserver/importer/web/ImportTaskTableTest.java&gt;: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/src/test/java/org/geoserver/importer/web/ImportTaskTableTest.java&gt; uses or overrides a deprecated API.
[INFO] <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/src/test/java/org/geoserver/importer/web/ImportTaskTableTest.java&gt;: Recompile with -Xlint:deprecation for details.
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-importer-web ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/surefire-reports&gt;
T E S T S
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Running org.geoserver.importer.web.AbstractDBPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.864 sec
Running org.geoserver.importer.web.ImportTaskTableTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.924 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[INFO] Processed 35 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.722 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.834 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.492 s]
[INFO] Main Module ........................................ SUCCESS [ 56.468 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.071 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:01 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 28.585 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.363 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.807 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.324 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.692 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:09 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:41 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 19.557 s]
[INFO] gs-rest ............................................ SUCCESS [ 8.997 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 55.936 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.350 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.855 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.167 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.105 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.598 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 33.674 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.793 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.124 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.027 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:18 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 56.808 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 7.919 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.559 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.047 s]
[INFO] Printing Module .................................... SUCCESS [ 8.408 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.017 s]
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.024 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:16 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.486 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.457 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.572 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.749 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.576 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.213 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.222 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.209 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.851 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.266 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.047 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.514 s]
[INFO] OGR WFS ............................................ FAILURE [ 9.244 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.035 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.691 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.515 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.448 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.584 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.500 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.839 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.762 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 23.614 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.000 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.584 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.054 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.477 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.048 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.210 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.025 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.399 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.973 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 25.490 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.582 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.034 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.256 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.495 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 25.562 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 7.576 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.463 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.223 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.061 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.807 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 9.976 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.399 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.058 s]
[INFO] Importer Core Module ............................... SUCCESS [ 43.192 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 34.378 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 10.251 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.003 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.909 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.318 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 32.621 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.884 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.618 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.354 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.184 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 16.858 s]
[INFO] GeoFence Server .................................... SUCCESS [ 27.829 s]
[INFO] Total time: 14:28 min (Wall Clock)
[INFO] Finished at: 2019-04-30T12:52:46+00:00
[INFO] Final Memory: 350M/1712M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x/89/display/redirect&gt;
[...truncated 1.31 MB...]
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.39 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.959 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.621 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src&gt;
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt; to /var/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.248 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.533 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.178 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.318 s]
[INFO] Main Module ........................................ SUCCESS [ 54.932 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.060 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:02 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 28.064 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.433 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.723 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.285 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.801 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 19.697 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.083 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 55.132 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.196 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.503 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.153 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.074 s]
[INFO] Core UI Module ..................................... SUCCESS [01:00 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.615 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 35.211 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 8.211 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.540 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.118 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.061 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 56.060 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 8.097 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.569 s]
[INFO] Printing Module .................................... SUCCESS [ 8.431 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.117 s]
[INFO] Community Space .................................... SUCCESS [ 0.037 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:10 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.568 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.432 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.936 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.750 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.585 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.205 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.220 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.267 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.757 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.263 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.048 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.513 s]
[INFO] OGR WFS ............................................ FAILURE [ 9.465 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.061 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.421 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.468 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.422 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.861 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.497 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.983 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.373 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 25.087 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.102 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.514 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.047 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.113 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.050 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.298 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.052 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.463 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 12.969 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 25.843 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.463 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.035 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.495 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.178 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 25.757 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.017 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.030 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.221 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.639 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.033 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.945 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 9.700 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.645 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.061 s]
[INFO] Importer Core Module ............................... SUCCESS [ 43.067 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 34.058 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 10.642 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.369 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.504 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.856 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 29.213 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.166 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.626 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.328 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.188 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 17.119 s]
[INFO] GeoFence Server .................................... SUCCESS [ 27.217 s]
[INFO] BUILD FAILURE
[INFO] Total time: 14:24 min (Wall Clock)
[INFO] Finished at: 2019-04-30T13:30:57+00:00
[INFO] Final Memory: 334M/1721M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-ogr-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x/ws/src/extension/ogr/ogr-wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ogr-wfs
See <https://build.geoserver.org/job/geoserver-2.15.x/90/display/redirect&gt;
  at java.lang.reflect.Method.invoke(Method.java:498)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.372 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.657 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.633 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.627 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.047 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.528 s]
[INFO] Main Module ........................................ SUCCESS [01:27 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.070 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 29.392 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.218 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.768 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.407 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.718 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:17 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 18.843 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.047 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 55.433 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:04 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.233 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.495 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.160 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.108 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.377 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 34.224 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.908 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.516 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 9.293 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.057 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 56.503 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 7.761 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.408 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.053 s]
[INFO] Printing Module .................................... SUCCESS [ 7.966 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.449 s]
[INFO] Community Space .................................... SUCCESS [ 0.034 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.033 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:13 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.436 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.472 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.526 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.010 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.614 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.159 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.237 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.241 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.787 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.261 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.065 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.530 s]
[INFO] OGR WFS ............................................ FAILURE [ 9.218 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.036 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 59.034 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.693 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.413 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.794 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.410 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.248 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.916 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 23.951 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 11.031 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.546 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.057 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.404 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.046 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.226 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.056 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.456 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.069 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 26.488 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.429 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.045 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 4.953 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.393 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 25.588 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.176 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.047 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.296 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 6.901 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.038 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 11.987 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.011 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.605 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.068 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.090 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 34.517 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 10.204 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.482 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.518 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.414 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 29.945 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.336 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.861 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.461 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.120 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 16.918 s]
[INFO] GeoFence Server .................................... SUCCESS [ 28.277 s]
[INFO] Total time: 14:58 min (Wall Clock)
[INFO] Finished at: 2019-04-30T14:39:36+00:00
[INFO] Final Memory: 340M/1667M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x/91/display/redirect&gt;
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.96 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.881 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.879 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Processed 34 files (0 non-complying).
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.358 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.026 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.160 s]
[INFO] Main Module ........................................ SUCCESS [ 57.108 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.065 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 28.608 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.571 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.755 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 13.547 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.867 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:10 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 18.746 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.181 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 56.695 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.505 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.279 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.169 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.081 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.527 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 33.695 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 8.356 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.497 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.058 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 57.208 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 8.217 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.649 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.048 s]
[INFO] Printing Module .................................... SUCCESS [ 8.410 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.123 s]
[INFO] Community Space .................................... SUCCESS [ 0.035 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.031 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:12 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.434 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.550 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.380 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.733 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.556 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.202 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.260 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.168 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.950 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.287 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.072 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.569 s]
[INFO] OGR WFS ............................................ FAILURE [ 9.117 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.043 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:00 min]
[INFO] Excel Output Format ................................ SUCCESS [ 9.465 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.454 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.751 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.426 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.191 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 8.691 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 23.259 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.922 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.596 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.045 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.455 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.262 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.028 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.488 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.024 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 25.141 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.801 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.053 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.420 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.971 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 25.814 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 7.839 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.027 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.569 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.499 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.027 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 13.551 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 9.964 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.782 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.065 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.296 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 33.964 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 10.164 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.072 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.664 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.525 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 30.234 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.244 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.656 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.547 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.453 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 16.645 s]
[INFO] GeoFence Server .................................... SUCCESS [ 27.808 s]
[INFO] Total time: 14:30 min (Wall Clock)
[INFO] Finished at: 2019-04-30T15:35:08+00:00
[INFO] Final Memory: 343M/1699M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x/92/display/redirect&gt;
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.757 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.666 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.612 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 5.787 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.730 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 7.289 s]
[INFO] Main Module ........................................ SUCCESS [ 55.406 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.085 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:08 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 29.711 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 3.945 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 18.880 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.553 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:13 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 19.310 s]
[INFO] gs-rest ............................................ SUCCESS [ 9.163 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 56.272 s]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 12.151 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.668 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 9.048 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 27.190 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 34.471 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.771 s]
[INFO] Demos Module ....................................... SUCCESS [ 14.085 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.992 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.051 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:19 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 56.147 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 8.160 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.582 s]
[INFO] Printing Module .................................... SUCCESS [ 8.137 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.428 s]
[INFO] Community Space .................................... SUCCESS [ 0.038 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.030 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 8.687 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 7.364 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.433 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.587 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.219 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.227 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.135 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.780 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.310 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.044 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.605 s]
[INFO] OGR WFS ............................................ FAILURE [ 9.344 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.027 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 58.951 s]
[INFO] Excel Output Format ................................ SUCCESS [ 9.643 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.462 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.672 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.444 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 11.152 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 9.149 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 23.775 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 10.831 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.661 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.059 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.100 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.047 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.280 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.040 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.667 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.117 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 25.266 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.313 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.052 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.361 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.261 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 25.599 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 7.616 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.040 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.295 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.210 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 12.087 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 9.800 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.352 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.052 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.604 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 34.294 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 10.318 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 9.492 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 11.665 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.686 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 30.206 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.496 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 9.510 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.353 s]
[INFO] REST SLD service ................................... SUCCESS [ 16.822 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 17.284 s]
[INFO] GeoFence Server .................................... SUCCESS [ 27.900 s]
[INFO] Total time: 14:32 min (Wall Clock)
[INFO] Finished at: 2019-04-30T15:54:52+00:00
[INFO] Final Memory: 340M/1697M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
That looks like it was caused by me moving over the PostGIS config to build-slave-01 (see earlier emails on the failing app-schema-online tests)
As far as I could tell, prior to that there wasn’t any version of GDAL installed (so I don’t think any of the GDAL/OGR tests were even running), and I think the PostGIS install pulled in a fairly old version, so that could explain the failure.
I can take a look at getting a working version of GDAL installed on the server.
Torben
On Tue, Apr 30, 2019 at 3:54 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
https://build.geoserver.org/job/geoserver-2.15.x/83/
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
	at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
Resulted in:
configured in.
FAILURE:</b>
See <https://build.geoserver.org/job/geoserver-2.15.x/93/display/redirect&gt;
Okay, I think I’ve got this working now - tests are passing again for master and 2.15 (2.14 appears to have an unrelated failure in GWC).
Torben
On Tue, Apr 30, 2019 at 9:13 AM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Resulted in:
configured in.
FAILURE:</b>
Hi Torben,
great stuff, thanks for fixing it!
Checking the buid server, the java 11 geoserver builds are stil plagued by the too many open files issues (although they are intermittent now).
I googled around once more, found a few issues related to QA tools but all seem fixed in the versions we’re using:
https://github.com/google/error-prone/issues/737
https://github.com/spotbugs/spotbugs/pull/591
and also one related to mvn assembly:
http://ksoong.org/troubleshooting/descriptor/mvn-too-many-file-open.html
Also, intermittent is probably not the right word, as failures and successes are clustered, as if there was some sort of global leak accumulating. Wondering if the bunch of green builds are associated with a node restart or something similar.
About the 2.14.x failure, it’s one intermittent failure that we have seen mostly on the windows build server on pull requests, but occasionally pops up
on linux too:
testAutomaticTruncationFeatureChange(org.geoserver.gwc.GWCIntegrationTest)  Time elapsed: 2464 sec  <<< FAILURE!
java.lang.AssertionError:
Expected: equalToIgnoringCase("MISS")
     but: was HIT
	at org.hamcrest.MatcherAssert.assertThat(MatcherAssert.java:20)
	at org.junit.Assert.assertThat(Assert.java:865)
	at org.junit.Assert.assertThat(Assert.java:832)
	at org.geoserver.gwc.GWCIntegrationTest.testAutomaticTruncationFeatureChange(GWCIntegrationTest.java:936)
You’re the author of the test failing, but I don’t recall if the random failure started happening right away (e.g., it came with the test), or later down the road (e.g., it popped up as a result of another change).
As far as I remember, when I looked into it, it seemed to be caused by the seeding tasks being background and thus not reliable to do their job within a given timeframe in a testing environment
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Regarding the “Too many open files” issue -
I took another brief look at that one about a month ago, and couldn’t make any further headway. From the perspective of the OS configuration it should be working fine, so it is almost certainly caused by a leak in GeoServer, Jenkins, or Java.
I did find this, which provides a good reference on how to track down exactly where it is coming from (or at least rule out Jenkins), however debugging it properly is going to require a reasonably large chunk of uninterrupted time (or a bit of luck) in order to catch the server in a state where there are currently too many open files and in a state where there aren’t, and I haven’t really had that time lately.
For the GWC test failure on 2.14 -
I can’t recall whether that issue came up shortly after the change or later on either. It looks like you’ve added an ostensible fix for the seeding issue on 2.14 and newer, although that evidently didn’t quite fix the issue, so I guess there might be something else going on. I’m not really sure what that issue might be, especially since all the other similar tests that one test was based on (e.g. testAutomaticTruncationLayerStyleContentsChange() ) still all seem to be passing. Given that, this may actually represent a bug specific to the WFS TransactionListener and how it interacts with GWC (possibly just an additional delay in handling truncation).
The next build of the 2.14 job passed, so the issue continues to be sporadic, which is going to make tracking down the root cause difficult.
Torben
On Wed, May 1, 2019 at 12:23 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
on linux too:
     but: was HIT
On Tue, Apr 30, 2019 at 11:35 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Torben
2.15.x has been failing for a number of builds, starting on a seemingly unrelated change:
Checking the failure, it seems like a system installation problem on the server, see this:
Tests run: 10, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 1.934 sec <<< FAILURE!
testSimpleCSV(org.geoserver.wfs.response.Ogr2OgrFormatTest)  Time elapsed: 978 sec  <<< ERROR!
org.geoserver.platform.ServiceException: Exception occurred during output generation
	at org.geoserver.wfs.response.Ogr2OgrOutputFormat.write(Ogr2OgrOutputFormat.java:307)
	at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:200)
	at org.geoserver.wfs.response.Ogr2OgrFormatTest.testSimpleCSV(Ogr2OgrFormatTest.java:196)
<b>Caused by: java.io.IOException: ogr2ogr did not terminate successfully, exit code 1. Was trying to run: [ogr2ogr, -f, CSV, -a_srs, /tmp/ogrtmpin0.367406913451224/srs8240695920266311468wkt, /tmp/ogrtmpout0.18567878589886866/Buildings.csv, /tmp/ogrtmpin0.367406913451224/Buildings.gml]
Resulted in:
ERROR 1: Unable to create Xerces C++ or Expat based GML reader, Xerces or Expat support
not configured into GDAL/OGR.
ERROR 1: File /tmp/ogrtmpin0.367406913451224/Buildings.gml appears to be GML but the GML reader can't
be instantiated, likely because Xerces or Expat support wasn't
configured in.
FAILURE:</b>
Maybe some updates occurred April 29th that broke the ogr2ogr installation?
