[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x-java11 #162
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/162/display/redirect?page=changes&gt;
Changes:
[gabriel.roldan] Fix data/minimal/styles/generic.xml pointing at generic.sld instead of
[...truncated 1.55 MB...]
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/target/surefire-reports&gt;
T E S T S
Running org.geoserver.importer.web.AbstractDBPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.864 sec
Running org.geoserver.importer.web.ImportTaskTableTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.854 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-web ---
[debug] Using AOSP style
[INFO] Processed 35 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/target/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-web/2.15-SNAPSHOT/gs-importer-web-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] ---------------< org.geoserver.security:gs-web-sec-cas >----------------
[INFO] Building GeoServer CAS Security Web Module 2.15-SNAPSHOT [94/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-sec-cas ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src&gt;
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-sec-cas ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-sec-cas ---
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 390.217 sec
Running org.geoserver.importer.bdb.SerialVersionSafeSerialBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.32 sec
Running org.geoserver.importer.bdb.XStreamInfoSerialBindingTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.111 sec
Results :
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-bdb ---
[INFO] Processed 8 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-bdb/2.15-SNAPSHOT/gs-importer-bdb-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer 2.15-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.504 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.076 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.269 s]
[INFO] Main Module ........................................ SUCCESS [01:02 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.051 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:24 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [03:53 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 19.799 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.577 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 11.966 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 14.526 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:32 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:37 min]
[INFO] Web Map Service Module ............................. SUCCESS [01:39 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 19.441 s]
[INFO] gs-rest ............................................ SUCCESS [ 7.617 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:30 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:18 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [03:37 min]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 13.876 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [03:20 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.080 s]
[INFO] Core UI Module ..................................... SUCCESS [ 46.074 s]
[INFO] WMS UI Module ...................................... SUCCESS [07:34 min]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 6.534 s]
[INFO] Demos Module ....................................... SUCCESS [04:19 min]
[INFO] WCS UI Module ...................................... SUCCESS [ 8.186 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.047 s]
[INFO] Security UI Core Module ............................ SUCCESS [06:19 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [03:33 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 6.942 s]
[INFO] REST UI Module ..................................... SUCCESS [ 7.910 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.046 s]
[INFO] Printing Module .................................... SUCCESS [ 7.189 s]
[INFO] Community Space .................................... SUCCESS [ 0.023 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [05:34 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.871 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.586 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.334 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.834 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.650 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.248 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.241 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 4.446 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.409 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.269 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.018 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.393 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.752 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.018 s]
[INFO] Web Processing Service Module ...................... SUCCESS [11:55 min]
[INFO] OGR WPS ............................................ SUCCESS [ 5.551 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.490 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.446 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.577 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.440 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.744 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.543 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 17.448 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.902 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.589 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.044 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.151 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.030 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.418 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 13.699 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.594 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.046 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.061 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.027 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [04:01 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.778 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.022 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 8.097 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.459 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.940 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 37.551 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 6.190 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.050 s]
[INFO] Importer Core Module ............................... SUCCESS [ 28.461 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 32.615 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [06:34 min]
[INFO] Importer Web UI Module ............................. SUCCESS [ 8.732 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 10.754 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 52.579 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [04:04 min]
[INFO] Vector Tiles ....................................... SUCCESS [ 11.634 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.429 s]
[INFO] REST SLD service ................................... SUCCESS [04:28 min]
[INFO] GeoFence security integration ...................... SUCCESS [01:17 min]
[INFO] GeoFence Server .................................... SUCCESS [06:09 min]
[INFO] BUILD FAILURE
[INFO] Total time: 50:14 min (Wall Clock)
[INFO] Finished at: 2019-06-13T20:58:33Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
Not sending mail to unregistered user gabriel.roldan@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/163/display/redirect?page=changes&gt;
