[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x-java11 #177
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/177/display/redirect?page=changes&gt;
Changes:
[milkymike45] GEOS-9236 --GeoTIFF sources configured with GeoServer 2.14.x might not
[r.nijssen] SLD abstracts that fit the according style
[...truncated 2.34 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[213,33\] cannot find symbol
[ERROR] symbol: method getSecurityManager()
[ERROR] location: class org.geoserver.security.cas.GeoServerCasAuthenticationFilter
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[217,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[217,78\] cannot find symbol
[ERROR] symbol: method getName()
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[219,20\] cannot find symbol
[ERROR] symbol: variable LOGGER
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[223,9\] cannot find symbol
[ERROR] symbol: variable super
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[233,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[234,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;:\[259,30\] cannot find symbol
[ERROR] symbol: variable GeoServerLogoutFilter
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;:\[29,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;:\[36,13\] cannot find symbol
[ERROR] location: class org.geoserver.security.cas.CasFilterConfigValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;:\[47,17\] incompatible types: org.geoserver.security.cas.CasFilterConfigException cannot be converted to java.lang.Throwable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;:\[51,37\] cannot find symbol
[ERROR] symbol: class PreAuthenticatedUserNameFilterConfig
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;:\[51,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;:\[54,13\] incompatible types: org.geoserver.security.cas.CasFilterConfigException cannot be converted to java.lang.Throwable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;:\[59,13\] incompatible types: org.geoserver.security.cas.CasFilterConfigException cannot be converted to java.lang.Throwable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;:\[67,17\] incompatible types: org.geoserver.security.cas.CasFilterConfigException cannot be converted to java.lang.Throwable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;:\[70,17\] incompatible types: org.geoserver.security.cas.CasFilterConfigException cannot be converted to java.lang.Throwable
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-netcdf-out: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;:\[63,13\] cannot find symbol
[ERROR] symbol: class MetadataMap
[ERROR] location: class org.geoserver.web.netcdf.NetCDFSettingsContainer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;:\[142,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[11,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[12,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[13,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[14,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[21,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[22,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[23,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[24,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[25,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[14,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[15,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[16,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[17,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[33,19\] cannot find symbol
[ERROR] symbol: class Resource
[ERROR] location: class org.geoserver.web.netcdf.layer.NetCDFParserBean
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java&gt;:\[9,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java&gt;:\[10,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java&gt;:\[13,61\] cannot find symbol
[ERROR] symbol: class XStreamPersisterInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java&gt;:\[16,22\] cannot find symbol
[ERROR] location: class org.geoserver.web.netcdf.VariableAttributeXStreamInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java&gt;:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java&gt;:\[11,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java&gt;:\[18,53\] cannot find symbol
[ERROR] symbol: class SettingsInfo
[ERROR] location: class org.geoserver.web.netcdf.NetCDFOutSettingsPanel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[9,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[10,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[13,57\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[16,22\] cannot find symbol
[ERROR] location: class org.geoserver.web.netcdf.ExtraVariableXStreamInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[27,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[28,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[29,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[66,20\] cannot find symbol
[ERROR] symbol: class CoverageInfo
[ERROR] location: class org.geoserver.web.netcdf.layer.NetCDFOutSettingsEditor
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java&gt;:\[10,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java&gt;:\[16,41\] cannot find symbol
[ERROR] symbol: class ModuleStatus
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java&gt;:\[8,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java&gt;:\[9,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java&gt;:\[12,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/GlobalAttributeXStreamInitializer.java&gt;:\[15,22\] cannot find symbol
[ERROR] location: class org.geoserver.web.netcdf.GlobalAttributeXStreamInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java&gt;:\[7,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java&gt;:\[8,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java&gt;:\[9,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java&gt;:\[10,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java&gt;:\[13,46\] cannot find symbol
[ERROR] symbol: class GeoServerInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFOutInitializer.java&gt;:\[16,28\] cannot find symbol
[ERROR] location: class org.geoserver.wcs.responses.NetCDFOutInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java&gt;:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java&gt;:\[18,62\] cannot find symbol
[ERROR] symbol: class LayerInfo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java&gt;:\[24,31\] cannot find symbol
[ERROR] location: class org.geoserver.web.netcdf.layer.NetCDFOutTabPanel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutTabPanel.java&gt;:\[24,56\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java&gt;:\[10,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/DefaultNetCDFEncoderFactory.java&gt;:\[14,75\] cannot find symbol
[ERROR] symbol: class ExtensionPriority
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[20,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[21,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[44,43\] cannot find symbol
[ERROR] location: class org.geoserver.wcs.responses.NetCDFCoverageResponseDelegate
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[78,20\] cannot find symbol
[ERROR] symbol: class ServiceException
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java&gt;:\[9,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java&gt;:\[12,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java&gt;:\[14,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java&gt;:\[24,29\] cannot find symbol
[ERROR] symbol: class PublishedInfo
[ERROR] location: class org.geoserver.web.netcdf.layer.NetCDFOutEditTabPanelInfo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java&gt;:\[30,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutEditTabPanelInfo.java&gt;:\[29,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;:\[8,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;:\[9,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;:\[12,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFContainerXStreamInitializer.java&gt;:\[15,22\] cannot find symbol
[ERROR] location: class org.geoserver.web.netcdf.NetCDFContainerXStreamInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;:\[63,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFSettingsContainer.java&gt;:\[144,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[65,9\] cannot find symbol
[ERROR] location: interface org.geoserver.wcs.responses.NetCDFEncoder
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[65,56\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[65,31\] cannot find symbol
[ERROR] symbol: variable GeoServerExtensions
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[66,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[68,13\] cannot find symbol
[ERROR] symbol: class Catalog
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[69,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[100,52\] cannot find symbol
[ERROR] location: class org.geoserver.wcs.responses.AbstractNetCDFEncoder
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[335,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[335,64\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[335,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[336,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[338,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/AbstractNetCDFEncoder.java&gt;:\[339,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[44,30\] cannot find symbol
[ERROR] symbol: variable Files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[50,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[66,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[72,13\] cannot find symbol
[ERROR] symbol: class GeoServerDataDirectory
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[72,71\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[72,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFParserBean.java&gt;:\[82,77\] package Resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/VariableAttributeXStreamInitializer.java&gt;:\[15,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java&gt;:\[21,29\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/NetCDFOutSettingsPanel.java&gt;:\[22,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/ExtraVariableXStreamInitializer.java&gt;:\[15,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[103,18\] cannot find symbol
[ERROR] symbol: class CoverageDimensionInfo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[105,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[114,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[136,37\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java&gt;:\[18,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java&gt;:\[23,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java&gt;:\[28,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java&gt;:\[33,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/netcdfout/NetCDFOutStatus.java&gt;:\[42,5\] method does not override or implement a method from a supertype
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence
Not sending mail to unregistered user milkymike45@anonymised.com
Not sending mail to unregistered user r.nijssen@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/178/display/redirect?page=changes&gt;
