[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x-java11 #179
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/179/display/redirect?page=changes&gt;
Changes:
[fernandomino7] [GEOS-9271] NullPointerException on WFS ComplexGeoJsonWriter Link check
[...truncated 1.22 MB...]
Members {size:2, ver:2} [
  Member [127.0.0.1]:5701 - f794b45f-24cd-46ef-8816-350fb03cce4d this
  Member [127.0.0.1]:5702 - 79330d1a-21ae-4f87-ac32-bceb7c5d1239
Jul 04, 2019 9:19:03 AM com.hazelcast.internal.cluster.ClusterService
INFO: [127.0.0.1]:5702 [dev] [3.11.1]
  Member [127.0.0.1]:5702 - 79330d1a-21ae-4f87-ac32-bceb7c5d1239 this
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.982 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-dxf-wps ---
[debug] Using AOSP style
[INFO] Processed 2 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/extension/gs-dxf-wps/2.15-SNAPSHOT/gs-dxf-wps-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/extension/gs-dxf-wps/2.15-SNAPSHOT/gs-dxf-wps-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/extension/gs-dxf-wps/2.15-SNAPSHOT/gs-dxf-wps-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/extension/gs-dxf-wps/2.15-SNAPSHOT/gs-dxf-wps-2.15-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.15-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/extension/gs-dxf-wps/2.15-SNAPSHOT/gs-dxf-wps-2.15-SNAPSHOT-test-sources.jar&gt;
Jul 04, 2019 9:19:03 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is STARTED
Jul 04, 2019 9:19:03 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Jul 04, 2019 9:19:03 AM com.hazelcast.internal.partition.impl.PartitionStateManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Initializing cluster partition table arrangement...
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTTING_DOWN
Jul 04, 2019 9:19:03 AM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5702 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Re-partitioning cluster data... Migration queue size: 136
Jul 04, 2019 9:19:04 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down connection manager...
Jul 04, 2019 9:19:04 AM com.hazelcast.test.mocknetwork.MockConnectionManager
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5701, connection: MockConnection{localEndpoint=[127.0.0.1]:5702, remoteEndpoint=[127.0.0.1]:5701}
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removed connection to endpoint: [127.0.0.1]:5702, connection: MockConnection{localEndpoint=[127.0.0.1]:5701, remoteEndpoint=[127.0.0.1]:5702}
Jul 04, 2019 9:19:04 AM com.hazelcast.internal.cluster.impl.MembershipManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Removing Member [127.0.0.1]:5702 - 79330d1a-21ae-4f87-ac32-bceb7c5d1239
Jul 04, 2019 9:19:04 AM com.hazelcast.internal.cluster.ClusterService
Members {size:1, ver:3} [
Jul 04, 2019 9:19:04 AM com.hazelcast.transaction.TransactionManagerService
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Committing/rolling-back live transactions of [127.0.0.1]:5702, UUID: 79330d1a-21ae-4f87-ac32-bceb7c5d1239
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Shutting down node engine...
Jul 04, 2019 9:19:04 AM com.hazelcast.internal.partition.impl.MigrationManager
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Partition balance is ok, no need to re-partition cluster data...
Jul 04, 2019 9:19:04 AM com.hazelcast.instance.NodeExtension
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5702 [dev] [3.11.1] Hazelcast Shutdown is completed in 150 ms.
Jul 04, 2019 9:19:04 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5702 [dev] [3.11.1] [127.0.0.1]:5702 is SHUTDOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTTING_DOWN
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutdown request of [127.0.0.1]:5701 is handled
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down connection manager...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Shutting down node engine...
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Destroying node NodeExtension.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] Hazelcast Shutdown is completed in 6 ms.
INFO: [127.0.0.1]:5701 [dev] [3.11.1] [127.0.0.1]:5701 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.149 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-wps-cluster-hazelcast ---
[INFO] Processed 5 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/extension/gs-wps-cluster-hazelcast/2.15-SNAPSHOT/gs-wps-cluster-hazelcast-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO] Reactor Summary for GeoServer 2.15-SNAPSHOT:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.258 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.419 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 8.176 s]
[INFO] Main Module ........................................ SUCCESS [ 58.819 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.048 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:29 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 54.906 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 17.563 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.554 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 12.641 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 13.146 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [03:20 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:12 min]
[INFO] Web Map Service Module ............................. FAILURE [01:34 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 7.344 s]
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-restconfig ...................................... SUCCESS [01:14 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.520 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.831 s]
[INFO] gs-restconfig-wms .................................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.078 s]
[INFO] Core UI Module ..................................... SUCCESS [ 46.764 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 6.607 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.034 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:23 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [07:11 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 6.509 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.521 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.038 s]
[INFO] Printing Module .................................... SUCCESS [ 6.776 s]
[INFO] Community Space .................................... SUCCESS [ 0.021 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.034 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.619 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.444 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.470 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.850 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 2.388 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.244 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.244 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 2.383 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.284 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.025 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.414 s]
[INFO] OGR WFS ............................................ SUCCESS [ 4.690 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 50.256 s]
[INFO] OGR WPS ............................................ SUCCESS [ 4.858 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.079 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.458 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.603 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.445 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.897 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.019 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.515 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.591 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.032 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.029 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.309 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.034 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.366 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.745 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.032 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 5.384 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 4.731 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [06:49 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.540 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.403 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.097 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.019 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 10.140 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 32.264 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 10.002 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] MongoDB Data Store ................................. SUCCESS [ 1.486 s]
[INFO] REST SLD service ................................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 17:04 min (Wall Clock)
[INFO] Finished at: 2019-07-04T09:19:04Z
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
Not sending mail to unregistered user fernandomino7@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/180/display/redirect&gt;
[...truncated 1.06 MB...]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-sec-cas ---
[warn] Test source directory '<https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/test/java’> does not exist, ignoring.
[INFO]
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/security/gs-web-sec-cas/2.15-SNAPSHOT/gs-web-sec-cas-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --------------------< org.geoserver.csw:gs-web-csw >--------------------
[INFO] Building CSW UI Module 2.15-SNAPSHOT [72/99]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-csw ---
[INFO] Deleting <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target&gt;
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-csw ---
[INFO]
[INFO] --- directory-maven-plugin:0.3.1:highest-basedir (directories) @ gs-web-csw ---
[INFO] Highest basedir set to: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-csw ---
[INFO] Copying 4 resources
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:compile (default-compile) @ gs-web-csw ---
[INFO] Changes detected - recompiling the module!
[INFO] Compiling 2 source files to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/classes&gt;
Running org.geoserver.wps.ppio.DXFPPIOTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-csw ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:3.8.0:testCompile (default-testCompile) @ gs-web-csw ---
[INFO] Compiling 1 source file to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-csw ---
[INFO] Surefire report directory: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.web.CSWAdminPageTest
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.934 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.249 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-web-csw ---
[INFO] Processed 3 files (0 non-complying).
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/pom.xml&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT.pom&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-tests.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-tests.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-sources.jar&gt;
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/target/gs-web-csw-2.15-SNAPSHOT-test-sources.jar&gt; to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/csw/gs-web-csw/2.15-SNAPSHOT/gs-web-csw-2.15-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 3.299 s]
[INFO] Core Platform Module ............................... SUCCESS [ 11.319 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.927 s]
[INFO] Main Module ........................................ SUCCESS [ 57.169 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.067 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:27 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 39.107 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 2.217 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.655 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 14.052 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 15.299 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:10 min]
[INFO] Web Map Service Module ............................. FAILURE [01:39 min]
[INFO] gs-rest ............................................ SUCCESS [ 7.403 s]
[INFO] gs-restconfig ...................................... SUCCESS [01:19 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 10.309 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 12.206 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.058 s]
[INFO] Core UI Module ..................................... SUCCESS [ 49.635 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 7.308 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.055 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:00 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 44.663 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 6.439 s]
[INFO] REST UI Module ..................................... SUCCESS [ 6.486 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.032 s]
[INFO] Printing Module .................................... SUCCESS [ 7.049 s]
[INFO] Community Space .................................... SUCCESS [ 0.024 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.023 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 7.849 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 6.174 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.042 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.061 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.055 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.042 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.036 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 1.024 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.057 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.027 s]
[INFO] OGR CORE ........................................... SUCCESS [ 0.366 s]
[INFO] OGR WFS ............................................ SUCCESS [ 5.419 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 50.447 s]
[INFO] OGR WPS ............................................ SUCCESS [ 5.304 s]
[INFO] Excel Output Format ................................ SUCCESS [ 8.740 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.120 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 0.369 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.063 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.834 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 7.683 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 9.856 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 0.480 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.031 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 2.136 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 0.404 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 11.982 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.060 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 6.107 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 5.052 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 23.194 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 5.666 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 7.704 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 5.240 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 9.948 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 31.691 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 9.705 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 0.072 s]
[INFO] Total time: 10:09 min (Wall Clock)
[INFO] Finished at: 2019-07-04T11:41:54Z
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/181/display/redirect?page=changes&gt;
