See <https://build.geoserver.org/job/geoserver-2.15.x-java11/18/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-9140] Import Data unable to connect to and create PostGIS
[...truncated 1.60 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/converters/ImportJSONIOTest.java>:\[6,1\] cannot access org.geoserver.importer.rest.converters
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geotools/ogc/net.opengis.wfs/21-SNAPSHOT/net.opengis.wfs-21-SNAPSHOT.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[20,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[20,47\] cannot find symbol
[ERROR] symbol: class ImporterTestSupport
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[22,38\] cannot find symbol
[ERROR] symbol: class Exception
[ERROR] location: class org.geoserver.importer.rest.ImportDataControllerTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[29,34\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[36,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[42,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/ImportDataControllerTest.java>:\[51,37\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/DateFormatTransformTest.java>:\[19,8\] cannot access org.geoserver.importer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/TransformTestSupport.java>:\[30,17\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/TransformTestSupport.java>:\[30,52\] cannot find symbol
[ERROR] symbol: class DataTestCase
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/DateFormatTransformTest.java>:\[49,47\] cannot find symbol
[ERROR] symbol: class ParseException
[ERROR] location: class org.geoserver.importer.rest.DateFormatTransformTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/DateFormatTransformTest.java>:\[80,59\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/TransformTestSupport.java>:\[36,28\] cannot find symbol
[ERROR] symbol: class ImportTransform
[ERROR] location: class org.geoserver.importer.rest.TransformTestSupport
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-web: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java>:\[6,1\] cannot access org.geoserver.importer.web
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/it/geosolutions/jaiext/warp/jt-warp/1.1.7/jt-warp-1.1.7.jar>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>:\[19,1\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>:\[19,33\] cannot find symbol
[ERROR] symbol: class Panel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>:\[18,2\] cannot find symbol
[ERROR] symbol: class SuppressWarnings
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>:\[21,5\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: class org.geoserver.importer.web.NewWorkspacePanel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>:\[23,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>:\[36,60\] cannot find symbol
[ERROR] symbol: class IValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>:\[36,71\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>:\[39,30\] cannot find symbol
[ERROR] symbol: class IValidatable
[ERROR] location: class org.geoserver.importer.web.NewWorkspacePanel.WorkspaceDoesNotExistValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java>:\[39,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>:\[19,8\] cannot access org.geoserver.importer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>:\[19,41\] cannot find symbol
[ERROR] symbol: class GeoServerTablePanel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>:\[19,61\] cannot find symbol
[ERROR] symbol: class ImportContext
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>:\[21,12\] cannot find symbol
[ERROR] symbol: class PrettyTime
[ERROR] location: class org.geoserver.importer.web.ImportContextTable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[15,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[15,44\] cannot find symbol
[ERROR] symbol: class GeoServerDataProvider
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[15,66\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>:\[32,60\] cannot find symbol
[ERROR] symbol: class IModel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>:\[32,78\] cannot find symbol
[ERROR] symbol: class Property
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java>:\[32,15\] cannot find symbol
[ERROR] symbol: class Component
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[16,19\] cannot find symbol
[ERROR] location: class org.geoserver.importer.web.ImportContextProvider
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[16,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[17,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[17,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[18,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[18,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[19,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[19,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[32,15\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[32,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[32,29\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[37,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[37,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[42,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[42,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java>:\[42,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java>:\[16,1\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java>:\[16,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>:\[8,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>:\[8,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>:\[8,42\] import requires canonical name for <any>.markup.html.form.TextField
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>:\[9,25\] cannot access org.apache.wicket.markup
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>:\[9,32\] cannot access org.apache.wicket.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>:\[9,43\] import requires canonical name for <any>.panel.Panel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>:\[10,25\] cannot access org.apache.wicket.model
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>:\[10,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java>:\[18,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[8,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[9,25\] cannot access org.apache.wicket.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[9,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[10,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[11,37\] cannot access org.apache.wicket.markup.html.form
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[11,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[12,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[13,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[15,44\] cannot find symbol
[ERROR] symbol: class Radio
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[19,38\] cannot find symbol
[ERROR] symbol: class AjaxRequestTarget
[ERROR] location: class org.geoserver.importer.web.AjaxRadio<T>
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[21,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java>:\[40,13\] cannot find symbol
[ERROR] symbol: class RadioGroup
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[8,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[9,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[10,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[11,30\] cannot access org.apache.wicket.ajax.markup
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[11,37\] cannot access org.apache.wicket.ajax.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[11,42\] import requires canonical name for <any>.AjaxLink
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[12,37\] package org.apache.wicket.markup.html does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[13,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[14,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[15,37\] cannot access org.apache.wicket.markup.html.panel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[15,43\] package org.apache.wicket.markup.html.panel does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[16,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[17,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[25,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[29,5\] cannot find symbol
[ERROR] symbol: class WebMarkupContainer
[ERROR] location: class org.geoserver.importer.web.AdvancedDbParamPanel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[30,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java>:\[69,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[8,18\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[8,32\] import requires canonical name for <any>.jdbc.JDBCDataStoreFactory
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[9,27\] cannot access org.geotools.jdbc
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[9,32\] import requires canonical name for <any>.JDBCDataStoreFactory
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[10,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[10,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[11,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[11,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[12,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[12,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[13,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[13,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[15,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[15,12\] cannot access java.io
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[15,15\] import requires canonical name for <any>.Serializable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[16,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[18,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[19,20\] cannot access org.geotools.data
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[19,25\] package org.geotools.data does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[20,25\] cannot access org.geotools.data.sqlserver
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[20,35\] package org.geotools.data.sqlserver does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java>:\[21,35\] package org.geotools.data.sqlserver does not exist
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java>: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java;> <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java>: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java>: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java;> <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java>: Too many open files
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-importer-rest
