[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x-java11 #184
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/184/display/redirect&gt;
[...truncated 2.25 MB...]
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFUnitsConfigurator.java&gt;:\[108,9\] cannot find symbol
[ERROR] symbol: class Resource
[ERROR] location: class org.geoserver.netcdf.NetCDFUnitsConfigurator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFUnitsConfigurator.java&gt;:\[112,17\] cannot find symbol
[ERROR] symbol: class FileSystemResourceStore
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFUnitsConfigurator.java&gt;:\[113,29\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/crs/netcdf/NetCDFCRSOverridingAuthorityFactory.java&gt;:\[44,13\] cannot find symbol
[ERROR] symbol: class GeoServerResourceLoader
[ERROR] location: class org.geoserver.crs.netcdf.NetCDFCRSOverridingAuthorityFactory
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/crs/netcdf/NetCDFCRSOverridingAuthorityFactory.java&gt;:\[45,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/crs/netcdf/NetCDFCRSOverridingAuthorityFactory.java&gt;:\[45,21\] cannot find symbol
[ERROR] symbol: variable GeoServerExtensions
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/crs/netcdf/NetCDFCRSOverridingAuthorityFactory.java&gt;:\[47,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/crs/netcdf/NetCDFCRSOverridingAuthorityFactory.java&gt;:\[48,46\] cannot find symbol
[ERROR] symbol: variable Type
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFStatus.java&gt;:\[17,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFStatus.java&gt;:\[22,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFStatus.java&gt;:\[27,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFStatus.java&gt;:\[32,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFStatus.java&gt;:\[41,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFStatus.java&gt;:\[46,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFStatus.java&gt;:\[51,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf/src/main/java/org/geoserver/netcdf/NetCDFStatus.java&gt;:\[58,5\] method does not override or implement a method from a supertype
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-vectortiles: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/vectortiles/src/main/java/org/geoserver/wms/vector/VectorTileMapOutputFormat.java&gt;:\[18,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/vectortiles/src/main/java/org/geoserver/wms/vector/VectorTileMapOutputFormat.java&gt;:\[86,69\] cannot find symbol
[ERROR] symbol: class ServiceException
[ERROR] location: class org.geoserver.wms.vector.VectorTileMapOutputFormat
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/vectortiles/src/main/java/org/geotools/renderer/lite/VectorMapRenderUtils.java&gt;:\[438,79\] cannot find symbol
[ERROR] symbol: method matches(org.opengis.feature.type.FeatureType,org.opengis.feature.type.Name)
[ERROR] location: class org.geotools.feature.FeatureTypes
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/vectortiles/src/main/java/org/geoserver/wms/vector/VectorTileMapOutputFormat.java&gt;:\[43,8\] cannot access org.geoserver.platform.ServiceException
[ERROR] class file for org.geoserver.platform.ServiceException not found
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-core: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/VectorFormat.java&gt;:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/VectorFormat.java&gt;:\[11,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[17,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[18,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[19,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[21,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[22,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[23,39\] package org.geoserver.platform.resource does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[31,31\] package org.vfny.geoserver.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[8,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[9,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[11,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[12,34\] package org.geoserver.catalog.impl does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[13,30\] package org.geoserver.ows.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[18,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[19,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[20,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[21,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[22,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[23,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[24,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[57,5\] cannot find symbol
[ERROR] symbol: class StoreInfo
[ERROR] location: class org.geoserver.importer.ImportTask
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[75,5\] cannot find symbol
[ERROR] symbol: class LayerInfo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[127,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[131,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[151,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[155,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[237,26\] cannot find symbol
[ERROR] symbol: class Catalog
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportTask.java&gt;:\[241,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[72,5\] cannot find symbol
[ERROR] symbol: class WorkspaceInfo
[ERROR] location: class org.geoserver.importer.ImportContext
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[75,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[149,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[153,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[157,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[161,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/Directory.java&gt;:\[34,26\] package org.geoserver.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[406,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImportContext.java&gt;:\[410,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/SpatialFile.java&gt;:\[19,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/SpatialFile.java&gt;:\[20,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/SpatialFile.java&gt;:\[22,26\] package org.geoserver.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[22,34\] cannot find symbol
[ERROR] location: class org.geoserver.importer.ImporterUtils
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[22,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[22,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[40,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[40,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[40,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[61,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[61,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/ImporterUtils.java&gt;:\[61,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/VectorFormat.java&gt;:\[45,58\] cannot find symbol
[ERROR] symbol: class FeatureTypeInfo
[ERROR] location: class org.geoserver.importer.VectorFormat
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[112,54\] cannot find symbol
[ERROR] location: class org.geoserver.importer.DataFormat
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[126,60\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[126,85\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[126,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataFormat.java&gt;:\[129,60\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[17,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[18,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[19,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[20,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[21,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[22,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[23,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[24,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[25,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[82,55\] cannot find symbol
[ERROR] location: class org.geoserver.importer.DataStoreFormat
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[82,80\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[82,12\] cannot find symbol
[ERROR] symbol: class DataStoreInfo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[102,51\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/DataStoreFormat.java&gt;:\[218,82\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/transform/ReprojectTransform.java&gt;:\[8,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/Database.java&gt;:\[20,31\] package org.vfny.geoserver.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/job/JobQueue.java&gt;:\[27,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/job/JobQueue.java&gt;:\[28,26\] package org.geoserver.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[21,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[22,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[23,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[24,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[25,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[26,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[27,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[28,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[29,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[30,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[127,51\] cannot find symbol
[ERROR] location: class org.geoserver.importer.format.KMLFileFormat
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[127,76\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[127,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/format/KMLFileFormat.java&gt;:\[227,51\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[12,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[13,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[14,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[15,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[16,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[17,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[18,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[60,59\] cannot find symbol
[ERROR] location: class org.geoserver.importer.GridFormat
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[60,84\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[60,12\] cannot find symbol
[ERROR] symbol: class CoverageStoreInfo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/core/src/main/java/org/geoserver/importer/GridFormat.java&gt;:\[78,51\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-sec-core
Checking the logs of this one, it kind of seems a corrupted jar got into the classpath, as the classes being
mentioned as missing are definitely there…
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/185/display/redirect?page=changes&gt;
