See <https://build.geoserver.org/job/geoserver-2.15.x-java11/213/display/redirect>
[...truncated 2.56 MB...]
[ERROR] location: class org.geoserver.test.RestconfigWfsTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/RestconfigWfsTest.java>:\[211,9\] cannot find symbol
[ERROR] symbol: class FeatureTypeInfo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/RestconfigWfsTest.java>:\[230,9\] cannot find symbol
[ERROR] symbol: variable IOUtils
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/RestconfigWfsTest.java>:\[259,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ReprojectionAxisFlipTest.java>:\[103,9\] cannot find symbol
[ERROR] location: class org.geoserver.test.ReprojectionAxisFlipTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[1964,9\] cannot find symbol
[ERROR] location: class org.geoserver.test.FeatureChainingWfsTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[2058,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingWfsTest.java>:\[2202,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedIdSupportTest.java>:\[107,9\] cannot find symbol
[ERROR] location: class org.geoserver.test.NestedIdSupportTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingSharedConnectionTest.java>:\[84,9\] cannot find symbol
[ERROR] location: class org.geoserver.test.FeatureChainingSharedConnectionTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/FeatureChainingSharedConnectionTest.java>:\[86,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NestedGeometryFilterEncodingTest.java>:\[201,9\] cannot find symbol
[ERROR] location: class org.geoserver.test.NestedGeometryFilterEncodingTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/LayersNamesAliasingTests.java>:\[89,9\] cannot find symbol
[ERROR] symbol: class Catalog
[ERROR] location: class org.geoserver.test.LayersNamesAliasingTests
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/LayersNamesAliasingTests.java>:\[91,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SRSReprojectionTest.java>:\[224,9\] cannot find symbol
[ERROR] location: class org.geoserver.test.SRSReprojectionTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[404,9\] cannot find symbol
[ERROR] location: class org.geoserver.test.SimpleAttributeFeatureChainWfsTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[576,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/SimpleAttributeFeatureChainWfsTest.java>:\[600,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/CoordinatesFormattingTest.java>:\[120,9\] cannot find symbol
[ERROR] location: class org.geoserver.test.CoordinatesFormattingTest
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/CoordinatesFormattingTest.java>:\[121,70\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/CoordinatesFormattingTest.java>:\[129,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/CoordinatesFormattingTest.java>:\[130,70\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/NormalizedMultiValuesTest.java>:\[413,9\] cannot find symbol
[ERROR] location: class org.geoserver.test.NormalizedMultiValuesTest
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[19,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[20,30\] cannot find symbol
[ERROR] symbol: class LogoutFilterChain
[ERROR] location: package org.geoserver.security
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[21,37\] package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[22,37\] package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[23,37\] package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[49,55\] cannot find symbol
[ERROR] symbol: class GeoServerPreAuthenticatedUserNameFilter
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[65,38\] cannot find symbol
[ERROR] symbol: class SecurityNamedServiceConfig
[ERROR] location: class org.geoserver.security.cas.GeoServerCasAuthenticationFilter
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[9,41\] package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java>:\[16,47\] cannot find symbol
[ERROR] symbol: class FilterConfigException
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>:\[8,37\] package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>:\[15,52\] cannot find symbol
[ERROR] symbol: class PreAuthenticatedUserNameFilterConfig
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[10,33\] package org.geoserver.config.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[11,30\] cannot find symbol
[ERROR] symbol: class ConstantFilterChain
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[12,30\] cannot find symbol
[ERROR] symbol: class GeoServerSecurityFilterChain
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[13,30\] cannot find symbol
[ERROR] symbol: class GeoServerSecurityManager
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[14,30\] cannot find symbol
[ERROR] symbol: class RequestFilterChain
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[15,37\] package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[16,37\] package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[17,37\] package org.geoserver.security.filter does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[18,41\] package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[27,57\] cannot find symbol
[ERROR] symbol: class AbstractFilterProvider
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[46,27\] cannot find symbol
[ERROR] symbol: class XStreamPersister
[ERROR] location: class org.geoserver.security.cas.GeoServerCasAuthenticationProvider
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[52,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[57,49\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[57,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[63,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[62,12\] cannot find symbol
[ERROR] symbol: class SecurityConfigValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[68,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[11,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[12,37\] package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[13,37\] package org.geoserver.security.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[14,41\] package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[15,41\] package org.geoserver.security.validation does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[23,47\] cannot find symbol
[ERROR] symbol: class FilterConfigValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[25,37\] cannot find symbol
[ERROR] location: class org.geoserver.security.cas.CasFilterConfigValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[30,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[31,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[41,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[64,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[66,9\] cannot find symbol
[ERROR] symbol: variable super
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[100,9\] cannot find symbol
[ERROR] symbol: variable aep
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[116,13\] cannot find symbol
[ERROR] symbol: variable LOGGER
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[124,31\] cannot find symbol
[ERROR] symbol: variable GeoServerExtensions
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[154,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[154,44\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[160,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[179,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[191,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[199,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[210,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[211,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[212,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[213,33\] cannot find symbol
[ERROR] symbol: method getSecurityManager()
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[217,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[217,78\] cannot find symbol
[ERROR] symbol: method getName()
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[219,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[223,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[233,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[234,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java>:\[259,30\] cannot find symbol
[ERROR] symbol: variable GeoServerLogoutFilter
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java>:\[74,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[45,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[47,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[51,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[56,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[61,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[67,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[72,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java>:\[73,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[29,5\] method does not override or implement a method from a supertype
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[36,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[47,17\] incompatible types: org.geoserver.security.cas.CasFilterConfigException cannot be converted to java.lang.Throwable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[51,37\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[51,9\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[54,13\] incompatible types: org.geoserver.security.cas.CasFilterConfigException cannot be converted to java.lang.Throwable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[59,13\] incompatible types: org.geoserver.security.cas.CasFilterConfigException cannot be converted to java.lang.Throwable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[67,17\] incompatible types: org.geoserver.security.cas.CasFilterConfigException cannot be converted to java.lang.Throwable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java>:\[70,17\] incompatible types: org.geoserver.security.cas.CasFilterConfigException cannot be converted to java.lang.Throwable
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf
