[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x-java11 #24
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/24/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] Add 'https://' protocol support for default Data Store Panel URL Model
[...truncated 1.53 MB...]
[ERROR] symbol: class ExcludeFilter
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[124,25\] cannot find symbol
[ERROR] symbol: class IncludeFilter
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[130,25\] cannot find symbol
[ERROR] symbol: class And
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[139,25\] cannot find symbol
[ERROR] symbol: class Id
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[148,25\] cannot find symbol
[ERROR] symbol: class Not
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[153,25\] cannot find symbol
[ERROR] symbol: class Or
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[162,25\] cannot find symbol
[ERROR] symbol: class PropertyIsBetween
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[169,36\] cannot find symbol
[ERROR] symbol: class Expression
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[183,25\] cannot find symbol
[ERROR] symbol: class PropertyIsEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[189,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNotEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[195,25\] cannot find symbol
[ERROR] symbol: class PropertyIsGreaterThan
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[203,25\] cannot find symbol
[ERROR] symbol: class PropertyIsGreaterThanOrEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[211,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThan
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[219,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLessThanOrEqualTo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[227,25\] cannot find symbol
[ERROR] symbol: class PropertyIsLike
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[238,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNull
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[244,25\] cannot find symbol
[ERROR] symbol: class PropertyIsNil
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[250,25\] cannot find symbol
[ERROR] symbol: class BBOX
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[255,25\] cannot find symbol
[ERROR] symbol: class Beyond
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[260,25\] cannot find symbol
[ERROR] symbol: class Contains
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[265,25\] cannot find symbol
[ERROR] symbol: class Crosses
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[270,25\] cannot find symbol
[ERROR] symbol: class Disjoint
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[275,25\] cannot find symbol
[ERROR] symbol: class DWithin
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[280,25\] cannot find symbol
[ERROR] symbol: class Equals
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[285,25\] cannot find symbol
[ERROR] symbol: class Intersects
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[290,25\] cannot find symbol
[ERROR] symbol: class Overlaps
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[295,25\] cannot find symbol
[ERROR] symbol: class Touches
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[300,25\] cannot find symbol
[ERROR] symbol: class Within
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[305,25\] cannot find symbol
[ERROR] symbol: class After
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[313,25\] cannot find symbol
[ERROR] symbol: class AnyInteracts
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[318,25\] cannot find symbol
[ERROR] symbol: class Before
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[326,25\] cannot find symbol
[ERROR] symbol: class Begins
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[331,25\] cannot find symbol
[ERROR] symbol: class BegunBy
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[336,25\] cannot find symbol
[ERROR] symbol: class During
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[341,25\] cannot find symbol
[ERROR] symbol: class EndedBy
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[346,25\] cannot find symbol
[ERROR] symbol: class Ends
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[351,25\] cannot find symbol
[ERROR] symbol: class Meets
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[356,25\] cannot find symbol
[ERROR] symbol: class MetBy
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[361,25\] cannot find symbol
[ERROR] symbol: class OverlappedBy
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[366,25\] cannot find symbol
[ERROR] symbol: class TContains
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[371,25\] cannot find symbol
[ERROR] symbol: class TEquals
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[377,25\] cannot find symbol
[ERROR] symbol: class TOverlaps
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[78,35\] cannot find symbol
[ERROR] symbol: class BinaryComparisonOperator
[ERROR] location: class org.geoserver.wps.hz.FilterToCriteria.PropertyComparable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;:\[95,35\] cannot find symbol
[ERROR] symbol: class BinaryTemporalOperator
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesAutoCompleteBehavior.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAccessRulePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ExecuteRequest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessSelectionPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessFactoryInfoProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ReferenceConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSExecuteTransformer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessLimitsPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/FilteredProcessesProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilderPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RasterLayerConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/VectorLayerConfiguration.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ProcessStatusProvider.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-web-app: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/TestHomePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/TestHomePage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/TestHomePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/IComponentFactory.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/web/WebXmlTest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/web/WebXmlTest.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/web/WebXmlTest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/wicket/test/WicketTestApplication.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/filters/GZIPResponseStreamTest.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/filters/GZIPResponseStreamTest.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/filters/GZIPResponseStreamTest.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/src/test/java/org/geoserver/web/Start.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-rest: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-bdb: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/BDBImportStore.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/XStreamInfoSerialBinding.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/CatalogObjectConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/src/main/java/org/geoserver/importer/bdb/SerialVersionSafeSerialBinding.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-web: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportDataPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataStoreEditPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskAdvancedPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/MosaicPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/OraclePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueueTable.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/CoverageStoreEditPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTasksDetachableModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportSourcePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImporterWebUtils.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/LayerPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JobQueuePanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadioPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/BasicDbmsParamPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskTable.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/EnabledStoresModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AbstractDbPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportTaskProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/DataIcon.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SpatialFilePanel.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/src/main/java/org/geoserver/security/web/cas/CasAuthFilterPanelInfo.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-app-schema-test: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-geofence-server
Not sending mail to unregistered user nuno.oliveira@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/25/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] [GEOS-9158] Simplify JSON encoding of 'xml attribute' values
[Andrea Aime] [GEOS-9161] Complex attributes with date simple content are not encoded
[Andrea Aime] [GEOS-9145] GetLegendGraphic in JPEG will fail if libjpeg-turbo is
[...truncated 1.80 MB...]
[ERROR] -> [Help 1]
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RangePanel.java&gt;:\[5,1\] cannot access org.geoserver.wps.web
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/it/geosolutions/jaiext/errordiffusion/jt-errordiffusion/1.1.7/jt-errordiffusion-1.1.7.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[12,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[12,36\] cannot find symbol
[ERROR] symbol: class AbstractAutoCompleteRenderer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[12,65\] cannot find symbol
[ERROR] symbol: class String
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[15,13\] cannot find symbol
[ERROR] symbol: class StringBuilder
[ERROR] location: class org.geoserver.wps.web.RolesRenderer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[17,26\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[22,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[22,48\] cannot find symbol
[ERROR] symbol: class Response
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[22,67\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[27,35\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/RolesRenderer.java&gt;:\[27,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[26,8\] cannot access org.geoserver.wps
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[26,35\] cannot find symbol
[ERROR] symbol: class BaseServiceAdminPage
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[26,56\] cannot find symbol
[ERROR] symbol: class WPSInfo
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[32,25\] cannot find symbol
[ERROR] location: class org.geoserver.wps.web.WPSAdminPage
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[36,25\] cannot find symbol
[ERROR] symbol: class PageParameters
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[40,15\] cannot find symbol
[ERROR] symbol: class Class
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[40,21\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[49,26\] cannot find symbol
[ERROR] symbol: class IModel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[49,45\] cannot find symbol
[ERROR] symbol: class Form
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[105,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[110,38\] cannot find symbol
[ERROR] symbol: class AbstractFormValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[114,17\] cannot find symbol
[ERROR] symbol: class FormComponent
[ERROR] location: class org.geoserver.wps.web.WPSAdminPage.TotalTimeValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[115,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[118,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[118,51\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[124,16\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSAdminPage.java&gt;:\[129,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[33,1\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[33,39\] cannot find symbol
[ERROR] symbol: class Serializable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[43,5\] cannot find symbol
[ERROR] symbol: class Name
[ERROR] location: class org.geoserver.wps.web.InputParameterValues
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[47,5\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[139,44\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[49,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[34,12\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[71,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[98,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[126,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[126,10\] cannot find symbol
[ERROR] symbol: class ProcessParameterIO
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[130,5\] cannot find symbol
[ERROR] symbol: class ProcessFactory
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[134,5\] cannot find symbol
[ERROR] symbol: class Parameter
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[144,9\] cannot find symbol
[ERROR] location: class org.geoserver.wps.web.InputParameterValues.ParameterValue
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[146,64\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[168,16\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/InputParameterValues.java&gt;:\[172,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[8,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[11,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[11,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[11,30\] import requires canonical name for <any>.ajax.AjaxRequestTarget
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[12,25\] cannot access org.apache.wicket.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[12,30\] cannot access org.apache.wicket.ajax.form
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[12,35\] import requires canonical name for <any>.AjaxFormComponentUpdatingBehavior
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[13,25\] cannot access org.apache.wicket.markup
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[13,32\] cannot access org.apache.wicket.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[13,42\] import requires canonical name for <any>.form.DropDownChoice
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[14,37\] cannot access org.apache.wicket.markup.html.form
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[14,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[15,37\] cannot access org.apache.wicket.markup.html.panel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[15,43\] package org.apache.wicket.markup.html.panel does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[16,43\] package org.apache.wicket.markup.html.panel does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[17,25\] cannot access org.apache.wicket.model
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[17,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[18,21\] cannot access org.geoserver.catalog
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[18,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[19,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[20,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[21,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[22,21\] cannot access org.geoserver.web
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[22,25\] package org.geoserver.web does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[24,11\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[24,20\] cannot access org.geotools.geometry
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[24,33\] import requires canonical name for <any>.jts.ReferencedEnvelope
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[32,44\] cannot find symbol
[ERROR] symbol: class Panel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[34,13\] cannot find symbol
[ERROR] symbol: class DropDownChoice
[ERROR] location: class org.geoserver.wps.web.BoundingBoxInputPanel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/BoundingBoxInputPanel.java&gt;:\[36,5\] cannot find symbol
[ERROR] symbol: class PropertyModel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[10,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[11,43\] package org.apache.wicket.markup.html.panel does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[12,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[19,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[21,33\] cannot find symbol
[ERROR] location: class org.geoserver.wps.web.EnumPanel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/EnumPanel.java&gt;:\[21,58\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[11,25\] package org.geoserver.web does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[12,25\] cannot access org.geoserver.wps.ppio
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[12,30\] package org.geoserver.wps.ppio does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[13,30\] package org.geoserver.wps.ppio does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[14,25\] cannot access org.geoserver.wps.process
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[14,33\] package org.geoserver.wps.process does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[15,20\] cannot access org.geotools.data
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[15,25\] package org.geotools.data does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[16,20\] cannot access org.geotools.process
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[16,28\] package org.geotools.process does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[17,11\] cannot access org.opengis
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[17,19\] cannot access org.opengis.feature
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[17,32\] import requires canonical name for <any>.type.Name
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[26,5\] cannot find symbol
[ERROR] location: class org.geoserver.wps.web.OutputParameter
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[34,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[62,10\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[67,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/OutputParameter.java&gt;:\[71,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;:\[12,17\] cannot access java.util.logging
[ERROR] -> [Help 1]
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-inspire: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 2]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-wcs
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/26/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Fixing formatting
[...truncated 1.70 MB...]
[ERROR] symbol: class XStreamPersister
[ERROR] location: class org.geoserver.web.netcdf.NetCDFContainerXStreamInitializer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[36,8\] cannot access org.geoserver.wcs
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/javax/media/jai_imageio/1.1/jai_imageio-1.1.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[36,53\] cannot find symbol
[ERROR] symbol: class BaseCoverageResponseDelegate
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[37,20\] cannot find symbol
[ERROR] symbol: class CoverageResponseDelegate
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[37,46\] cannot find symbol
[ERROR] symbol: class ApplicationContextAware
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[39,25\] cannot find symbol
[ERROR] symbol: class Logger
[ERROR] location: class org.geoserver.wcs.responses.NetCDFCoverageResponseDelegate
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[41,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[11,21\] cannot access org.geoserver.wcs2_0
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[11,28\] cannot access org.geoserver.wcs2_0.response
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[11,37\] import requires canonical name for <any>.GranuleStack
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[12,11\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[12,20\] cannot access org.geotools.coverage
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[12,34\] import requires canonical name for <any>.grid.GridCoverage2D
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[44,43\] cannot find symbol
[ERROR] symbol: class GeoServer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[74,13\] cannot find symbol
[ERROR] symbol: class GridCoverage2D
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[76,13\] cannot find symbol
[ERROR] symbol: class Map
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[77,13\] cannot find symbol
[ERROR] symbol: class OutputStream
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[78,20\] cannot find symbol
[ERROR] symbol: class ServiceException
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[78,38\] cannot find symbol
[ERROR] symbol: class IOException
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[107,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[107,12\] cannot find symbol
[ERROR] symbol: class GranuleStack
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[128,35\] cannot find symbol
[ERROR] symbol: class File
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[128,52\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[128,80\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[147,39\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[147,85\] cannot find symbol
[ERROR] symbol: class BeansException
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFCoverageResponseDelegate.java&gt;:\[152,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[30,13\] cannot find symbol
[ERROR] location: interface org.geoserver.wcs.responses.NetCDFEncoderFactory
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[10,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[11,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[12,29\] package org.geoserver.catalog does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[13,28\] package org.geoserver.config does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[14,21\] cannot access org.geoserver.platform
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[14,30\] package org.geoserver.platform does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[15,37\] package org.geoserver.wcs2_0.response does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[16,28\] cannot access org.geoserver.wcs2_0.util
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[16,33\] package org.geoserver.wcs2_0.util does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[19,8\] cannot access ucar
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[19,12\] cannot access ucar.ma2
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[19,16\] import requires canonical name for <any>.InvalidRangeException
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoderFactory.java&gt;:\[43,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/wcs/responses/NetCDFEncoder.java&gt;:\[33,38\] cannot find symbol
[ERROR] symbol: class InvalidRangeException
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[13,8\] cannot access javax
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[13,13\] cannot access javax.measure
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[13,21\] import requires canonical name for <any>.Unit
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[14,21\] cannot access javax.measure.format
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[14,28\] package javax.measure.format does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[15,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[15,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[15,25\] import requires canonical name for <any>.Component
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[16,25\] cannot access org.apache.wicket.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[16,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[17,30\] cannot access org.apache.wicket.ajax.form
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[17,35\] package org.apache.wicket.ajax.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[18,25\] cannot access org.apache.wicket.extensions
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[18,36\] cannot access org.apache.wicket.extensions.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[18,66\] import requires canonical name for <any>.markup.html.autocomplete.AutoCompleteTextField
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[19,25\] cannot access org.apache.wicket.markup
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[19,32\] cannot access org.apache.wicket.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[19,43\] import requires canonical name for <any>.basic.Label
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[20,37\] cannot access org.apache.wicket.markup.html.form
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[20,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/netcdf-out/src/main/java/org/geoserver/web/netcdf/layer/NetCDFOutSettingsEditor.java&gt;:\[21,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-sec-cas: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationProvider.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigException.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationFilterConfig.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasAuthenticationHelper.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/ProxyGrantingTicketCallbackFilter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationFilter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/CasFilterConfigValidator.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasAuthenticationEntryPoint.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasConstants.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/cas/src/main/java/org/geoserver/security/cas/SingleSignOutHttpSessionListener.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-geofence-server: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/RulesRestController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulesModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerAdminPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceServerPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceRulePage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/AdminRulesRestController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/GeofenceAdminRulesModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/server/rest/GeofenceSecurityInterceptor.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/web/LayerAttributeModel.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/geofence-server/src/main/java/org/geoserver/geofence/internal/InternalUserResolver.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-csw: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWAdminPage.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/csw/web-csw/src/main/java/org/geoserver/csw/web/CSWLayerConfig.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wcs2_0-eo: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOLayerConfig.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wcs2_0-eo/web/src/main/java/org/geoserver/wcs2_0/eo/web/WCSEOAdminPanel.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-ogr-wps: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrCDataPPIO.java&gt;:\[6,1\] cannot access org.geoserver.wps.ogr
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/jasypt/jasypt-springsecurity3/1.9.2/jasypt-springsecurity3-1.9.2.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java&gt;:\[22,8\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java&gt;:\[22,44\] cannot find symbol
[ERROR] symbol: class PPIOFactory
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java&gt;:\[24,13\] cannot find symbol
[ERROR] symbol: class Ogr2OgrOutputFormat
[ERROR] location: class org.geoserver.wps.ogr.Ogr2OgrPPIOFactory
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java&gt;:\[26,31\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java&gt;:\[37,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/Ogr2OgrPPIOFactory.java&gt;:\[37,17\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;:\[25,8\] cannot access org.geoserver.wps
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;:\[25,33\] cannot find symbol
[ERROR] symbol: class XMLPPIO
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;:\[27,13\] cannot find symbol
[ERROR] location: class org.geoserver.wps.ogr.OgrXMLPPIO
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;:\[29,13\] cannot find symbol
[ERROR] symbol: class Operation
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;:\[36,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;:\[37,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;:\[49,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;:\[57,12\] cannot find symbol
[ERROR] symbol: class PPIODirection
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;:\[67,38\] cannot find symbol
[ERROR] symbol: class ContentHandler
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrXMLPPIO.java&gt;:\[81,26\] cannot find symbol
[ERROR] symbol: class InputStream
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;:\[18,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;:\[18,36\] cannot find symbol
[ERROR] symbol: class BinaryPPIO
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;:\[20,13\] cannot find symbol
[ERROR] location: class org.geoserver.wps.ogr.OgrBinaryPPIO
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;:\[22,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;:\[29,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;:\[30,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;:\[38,38\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;:\[51,12\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wps/src/main/java/org/geoserver/wps/ogr/OgrBinaryPPIO.java&gt;:\[56,26\] cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-wps-cluster-hazelcast: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastStatusStore.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/HazelcastLoader.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/main/java/org/geoserver/wps/hz/FilterToCriteria.java&gt;: Too many open files
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-gwc
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/27/display/redirect?page=changes&gt;
