[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x-java11 #31
See <https://build.geoserver.org/job/geoserver-2.15.x-java11/31/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Upgrading to the latest jai-ext
[...truncated 2.20 MB...]
[INFO] GeoFence security integration ...................... SUCCESS [ 20.030 s]
[INFO] GeoFence Server .................................... SUCCESS [ 29.932 s]
[INFO] BUILD FAILURE
[INFO] Total time: 19:36 min (Wall Clock)
[INFO] Finished at: 2019-04-23T11:42:38+00:00
[INFO] Final Memory: 616M/1374M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-wps: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/web-wps/target/maven-status/maven-compiler-plugin/compile/default-compile/createdFiles.lst&gt; (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-wps-cluster-hazelcast: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/src/test/java/org/geoserver/wps/hz/MultinodeHazelcastStatusStoreTest.java&gt;:\[20,8\] error while writing org.geoserver.wps.hz.MultinodeHazelcastStatusStoreTest: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/wps/wps-cluster-hazelcast/target/test-classes/org/geoserver/wps/hz/MultinodeHazelcastStatusStoreTest.class&gt;: Too many open files
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:testCompile (default-testCompile) on project gs-web-app: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/web/app/target/maven-status/maven-compiler-plugin/testCompile/default-testCompile/createdFiles.lst&gt; (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-dxf-wps: Compilation failure
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/src/main/java/org/geoserver/wps/ppio/DXFPPIO.java&gt;:\[25,8\] error while writing org.geoserver.wps.ppio.DXFPPIO: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/dxf/wps/target/classes/org/geoserver/wps/ppio/DXFPPIO.class&gt;: Too many open files
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-bdb: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/bdb/target/maven-status/maven-compiler-plugin/compile/default-compile/createdFiles.lst&gt; (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-rest: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportWrapper.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTransformJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportWrapperMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportDataJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextHTMLMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONWriter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportDataController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTransformController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportLayer.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportBaseController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/TransformChainJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportJSONReader.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/ImportTaskController.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportTaskJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportLayerJSONMessageConverter.java&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java&gt;: error reading <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java;&gt; <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/src/main/java/org/geoserver/importer/rest/converters/ImportContextJSONMessageConverter.java&gt;: Too many open files
[ERROR] -> [Help 2]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-web-sec-cas: Error while storing the mojo status: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/security/web/web-cas/target/maven-status/maven-compiler-plugin/compile/default-compile/createdFiles.lst&gt; (Too many open files) -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.8.0:compile (default-compile) on project gs-importer-web: Compilation failure: Compilation failure:
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/PostGISPanel.java&gt;:\[6,1\] cannot access org.geoserver.importer.web
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/freemarker/freemarker/2.3.18/freemarker-2.3.18.jar&gt;: Too many open files
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[19,1\] cannot access java.lang
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[19,33\] cannot find symbol
[ERROR] symbol: class Panel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[18,2\] cannot find symbol
[ERROR] symbol: class SuppressWarnings
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[21,5\] cannot find symbol
[ERROR] symbol: class String
[ERROR] location: class org.geoserver.importer.web.NewWorkspacePanel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[23,30\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[36,60\] cannot find symbol
[ERROR] symbol: class IValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[36,71\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[39,30\] cannot find symbol
[ERROR] symbol: class IValidatable
[ERROR] location: class org.geoserver.importer.web.NewWorkspacePanel.WorkspaceDoesNotExistValidator
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/NewWorkspacePanel.java&gt;:\[39,43\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[19,8\] cannot access org.geoserver.importer
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[19,41\] cannot find symbol
[ERROR] symbol: class GeoServerTablePanel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[19,61\] cannot find symbol
[ERROR] symbol: class ImportContext
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[21,12\] cannot find symbol
[ERROR] symbol: class PrettyTime
[ERROR] location: class org.geoserver.importer.web.ImportContextTable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[15,8\] cannot access org.geoserver
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[15,44\] cannot find symbol
[ERROR] symbol: class GeoServerDataProvider
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[15,66\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[32,60\] cannot find symbol
[ERROR] symbol: class IModel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[32,78\] cannot find symbol
[ERROR] symbol: class Property
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextTable.java&gt;:\[32,15\] cannot find symbol
[ERROR] symbol: class Component
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[16,19\] cannot find symbol
[ERROR] location: class org.geoserver.importer.web.ImportContextProvider
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[16,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[17,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[17,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[18,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[18,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[19,19\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[19,28\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[32,15\] cannot find symbol
[ERROR] symbol: class List
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[32,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[32,29\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[37,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[37,20\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[42,46\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[42,15\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ImportContextProvider.java&gt;:\[42,22\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java&gt;:\[16,1\] cannot access org
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/ConnectionPoolParamPanel.java&gt;:\[16,40\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[8,11\] cannot access org.apache
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[8,18\] cannot access org.apache.wicket
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[8,42\] import requires canonical name for <any>.markup.html.form.TextField
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[9,25\] cannot access org.apache.wicket.markup
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[9,32\] cannot access org.apache.wicket.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[9,43\] import requires canonical name for <any>.panel.Panel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[10,25\] cannot access org.apache.wicket.model
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[10,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/JNDIDbParamPanel.java&gt;:\[18,32\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[8,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[9,25\] cannot access org.apache.wicket.ajax
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[9,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[10,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[11,37\] cannot access org.apache.wicket.markup.html.form
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[11,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[12,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[13,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[15,44\] cannot find symbol
[ERROR] symbol: class Radio
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[19,38\] cannot find symbol
[ERROR] symbol: class AjaxRequestTarget
[ERROR] location: class org.geoserver.importer.web.AjaxRadio<T>
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[21,33\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AjaxRadio.java&gt;:\[40,13\] cannot find symbol
[ERROR] symbol: class RadioGroup
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[8,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[9,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[10,30\] package org.apache.wicket.ajax does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[11,30\] cannot access org.apache.wicket.ajax.markup
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[11,37\] cannot access org.apache.wicket.ajax.markup.html
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[11,42\] import requires canonical name for <any>.AjaxLink
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[12,37\] package org.apache.wicket.markup.html does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[13,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[14,42\] package org.apache.wicket.markup.html.form does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[15,37\] cannot access org.apache.wicket.markup.html.panel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[15,43\] package org.apache.wicket.markup.html.panel does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[16,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[17,31\] package org.apache.wicket.model does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[25,36\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[29,5\] cannot find symbol
[ERROR] symbol: class WebMarkupContainer
[ERROR] location: class org.geoserver.importer.web.AdvancedDbParamPanel
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[30,13\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/AdvancedDbParamPanel.java&gt;:\[69,5\] cannot find symbol
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[8,18\] cannot access org.geotools
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[8,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[8,32\] import requires canonical name for <any>.jdbc.JDBCDataStoreFactory
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[9,27\] cannot access org.geotools.jdbc
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[9,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[9,32\] import requires canonical name for <any>.JDBCDataStoreFactory
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[10,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[10,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[11,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[11,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[12,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[12,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[13,32\] package org.geotools.jdbc does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[13,1\] static import only from classes and interfaces
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[15,8\] cannot access java
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[15,12\] cannot access java.io
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[15,15\] import requires canonical name for <any>.Serializable
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[16,12\] cannot access java.util
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[18,25\] package org.apache.wicket does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[19,20\] cannot access org.geotools.data
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[19,25\] package org.geotools.data does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[20,25\] cannot access org.geotools.data.sqlserver
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[20,35\] package org.geotools.data.sqlserver does not exist
[ERROR] <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/web/src/main/java/org/geoserver/importer/web/SQLServerPanel.java&gt;:\[21,35\] package org.geotools.data.sqlserver does not exist
[ERROR] -> [Help 2]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-wps
