See <https://build.geoserver.org/job/geoserver-2.15.x-java11/33/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-8450] DescribeCoverage should not fail on secured datasets with
[Andrea Aime] [GEOS-9153] WCS 2.0 scaling policies do not account for scaling factor
[Andrea Aime] [GEOS-9192] GeoServer UI let's you save duplicate grids names
[...truncated 1.57 MB...]
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
Apr 30, 2019 9:42:07 AM org.geoserver.importer.Importer init
SEVERE: Failed to init the context
java.lang.NullPointerException
at org.geoserver.importer.SpatialFile.prepare(SpatialFile.java:103)
at org.geoserver.importer.Importer.addTasks(Importer.java:472)
at org.geoserver.importer.Importer.init(Importer.java:440)
at org.geoserver.importer.rest.ImportController.createImport(ImportController.java:221)
at org.geoserver.importer.rest.ImportController.postImports(ImportController.java:72)
at jdk.internal.reflect.GeneratedMethodAccessor293.invoke(Unknown Source)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:207)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:102)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:895)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:800)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1038)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:942)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:998)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:901)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:875)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1636)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:166)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:133)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1665)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1576)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1564)
at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1212)
at org.geoserver.importer.rest.ImporterIntegrationTest.testDirectWrongDir(ImporterIntegrationTest.java:206)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.941 sec
Running org.geoserver.importer.rest.PostScriptTransformTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.importer.rest.converters.ImportJSONIOTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.497 sec
Results :
Tests run: 76, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- fmt-maven-plugin:2.4.0:check (default) @ gs-importer-rest ---
[debug] Using AOSP style
[INFO] Processed 31 files (0 non-complying).
[INFO]
[INFO] >>> maven-pmd-plugin:3.11.0:check (default) > :pmd @ gs-importer-rest >>>
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:pmd (pmd) @ gs-importer-rest ---
[WARNING] File encoding has not been set, using platform encoding UTF-8, i.e. build is platform dependent!
[INFO]
[INFO] <<< maven-pmd-plugin:3.11.0:check (default) < :pmd @ gs-importer-rest <<<
[INFO]
[INFO] --- maven-pmd-plugin:3.11.0:check (default) @ gs-importer-rest ---
[INFO]
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT.jar> to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/pom.xml> to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT.pom>
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-tests.jar> to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-tests.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-sources.jar> to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-sources.jar>
[INFO] Installing <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/importer/rest/target/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar> to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/m2/org/geoserver/importer/gs-importer-rest/2.15-SNAPSHOT/gs-importer-rest-2.15-SNAPSHOT-test-sources.jar>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.578 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.896 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.956 s]
[INFO] Main Module ........................................ SUCCESS [01:41 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.145 s]
[INFO] GeoServer Security Tests Module .................... SUCCESS [01:37 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 44.200 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 5.479 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.230 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 18.018 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 18.941 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [04:28 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:50 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:21 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 25.845 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.001 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:08 min]
[INFO] gs-restconfig ...................................... SUCCESS [01:16 min]
[INFO] gs-restconfig-wcs .................................. SUCCESS [ 16.024 s]
[INFO] gs-restconfig-wfs .................................. SUCCESS [ 16.717 s]
[INFO] gs-restconfig-wms .................................. SUCCESS [ 12.570 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.173 s]
[INFO] Core UI Module ..................................... SUCCESS [01:15 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.776 s]
[INFO] GWC UI Module ...................................... SUCCESS [01:02 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.744 s]
[INFO] Demos Module ....................................... SUCCESS [ 17.343 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 12.361 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.091 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:14 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:01 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 10.746 s]
[INFO] REST UI Module ..................................... SUCCESS [ 8.994 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.085 s]
[INFO] Printing Module .................................... SUCCESS [ 9.605 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.252 s]
[INFO] Community Space .................................... SUCCESS [ 0.049 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.042 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:28 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.538 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.120 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.693 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.359 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.046 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.992 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.877 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.095 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.776 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.937 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.059 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.362 s]
[INFO] OGR WFS ............................................ FAILURE [ 10.606 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.070 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:15 min]
[INFO] Excel Output Format ................................ SUCCESS [ 11.292 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.990 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.455 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.180 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 18.562 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 10.803 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 24.184 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 12.783 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.711 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.100 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 27.962 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.089 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 5.791 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.083 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 1.604 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 15.925 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.699 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 13.286 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.098 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 8.714 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 7.837 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 33.288 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 8.541 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.059 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 11.846 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 7.892 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.056 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 13.927 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 10.009 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.422 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.150 s]
[INFO] Importer Core Module ............................... SUCCESS [ 37.934 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 37.968 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 13.025 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 12.117 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.509 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 17.980 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 30.762 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 15.487 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 14.600 s]
[INFO] MongoDB Data Store ................................. SUCCESS [ 2.276 s]
[INFO] REST SLD service ................................... SUCCESS [ 18.921 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 20.210 s]
[INFO] GeoFence Server .................................... SUCCESS [ 30.122 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:36 min (Wall Clock)
[INFO] Finished at: 2019-04-30T09:42:09+00:00
[INFO] Final Memory: 528M/1340M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-ogr-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <https://build.geoserver.org/job/geoserver-2.15.x-java11/ws/src/extension/ogr/ogr-wfs/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ogr-wfs
