See <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/37/display/redirect?page=changes>
Changes:
[Andrea Aime] [GEOS-9221] Upgrade spring security to 5.1.5
[Andrea Aime] [Closes JIRA GEOS-9220] Upgrade spring-security-oauth2 version from
[Andrea Aime] [Fixes JIRA GEOS-9015] - WPS GetExecutions Operation Impl - Improve the
[Andrea Aime] Extracted utility method as per @aaime review
[Andrea Aime] [GEOS-9218] Parameter Extractor plugin prevents the Monitor plugin to
[Andrea Aime] [GEOS-9217] No feature type for workspace with multiple datastore
[Andrea Aime] GEOS-9215 Restrict usage of WFS StoredQuery creation/update/removal to
[...truncated 1.45 KB...]
at hudson.Util.createSymlink(Util.java:1193)
at hudson.model.Run.createSymlink(Run.java:1955)
at hudson.model.Run.updateSymlinks(Run.java:1937)
at hudson.model.Run.execute(Run.java:1814)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
Building remotely on i-0e90ba3557d168074 (linux-fleet) in workspace <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/>
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/> # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/2.15.x^{commit} # timeout=10
Checking out Revision 0e43be691d5653dac217f0485c4932ee1e273de5 (origin/2.15.x)
> git config core.sparsecheckout # timeout=10
> git checkout -f 0e43be691d5653dac217f0485c4932ee1e273de5
Commit message: "GEOS-9215 Restrict usage of WFS StoredQuery creation/update/removal to admin users by default (#3520)"
> git rev-list --no-walk ee03e3e43cfbc87f0cbe308e7f751a4398ed3891 # timeout=10
[geoserver-2.15.x-live-docs] $ mvn -f doc/en/pom.xml compile
[e[1;34mINFOe[m] Scanning for projects...
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m----------------------< e[0;36morg.geoserver.en:gs-docse[0;1m >----------------------e[m
[e[1;34mINFOe[m] e[1mBuilding GeoServer English Documentation 2.15-SNAPSHOTe[m
[e[1;34mINFOe[m] e[1m--------------------------------[ pom ]---------------------------------e[m
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/coverages.yaml>
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coverages/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coverages/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverageStores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coveragestores/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coveragestores/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(datastores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/datastores.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/datastores/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/datastores/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(featureTypes)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml>
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureType_0`
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/featuretypes/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/featuretypes/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(fonts)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/fonts.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/fonts/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layergroups/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/layers.yaml>
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layers/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/manifests.yaml>
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/manifests/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/namespaces/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/owsservices/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/reload.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/reload/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/security.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/security/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/settings.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/settings/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/structuredcoverages/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/styles.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/styles/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/templates.yaml>
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/templates/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmslayers/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmsstores/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtslayers/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtsstores/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/workspaces/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/monitoring/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importer.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importer/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTransforms/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTasks/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerData.yaml>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerData/index.html>
[e[1;34mINFOe[m] writing file <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] Executing tasks
init:
[echo] Base directory is <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en>
[echo] Build directory is <http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target> and project version is 2.15-SNAPSHOT
docguide:
sphinx:
[echo] Running sphinx-build -D release=2.15-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/docguide/doctrees"> . "<http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/docguide/html">
user:
sphinx:
[echo] Running sphinx-build -D release=2.15-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/user/doctrees"> . "<http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/user/html">
developer:
sphinx:
[echo] Running sphinx-build -D release=2.15-SNAPSHOT -W -b html -d "<http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/developer/doctrees"> . "<http://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/developer/html">
full:
[e[1;34mINFOe[m] Executed tasks
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;32mBUILD SUCCESSe[m
[e[1;34mINFOe[m] Total time: 01:05 min
[e[1;34mINFOe[m] Finished at: 2019-05-27T21:34:45Z
[geoserver-2.15.x-live-docs] $ /bin/sh -xe /tmp/jenkins17522017531542264476.sh
+ VER=origin/2.15.x
+ VER=2.15.x
+ BASE=/var/www/html/geoserver/2.15.x/doc/en
+ STAGE=target/2.15.x/en
+ REMOTE=s3://docs.geoserver.org
+ [ -e /var/www/html/geoserver/2.15.x/doc/en ]
+ mkdir -p /var/www/html/geoserver/2.15.x/doc/en
mkdir: cannot create directory ‘/var/www’: Permission denied
Build step 'Execute shell' marked build as failure
