[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x-live-docs #442
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/442/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] GWC Azure blob community module
[Andrea Aime] Updating gwc-azure module version numbers
Started by an SCM change
Building remotely on FleetCloud i-0a998146de608786e (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/&gt;
No credentials specified
Cloning the remote Git repository
Cloning repository git://github.com/geoserver/geoserver.git
> git init <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/&gt; # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/2.15.x^{commit} # timeout=10
Checking out Revision 638c333130ff8df0bc961d139c9c68445c416908 (origin/2.15.x)
> git config core.sparsecheckout # timeout=10
> git checkout -f 638c333130ff8df0bc961d139c9c68445c416908
Commit message: "Merge pull request #3652 from aaime/gwc_azure_215x"
> git rev-list --no-walk 4243ad287f621b3683a52e2bc1b102607ba1b0c1 # timeout=10
[geoserver-2.15.x-live-docs] $ mvn -f doc/en/pom.xml compile
[e[1;34mINFOe[m] Scanning for projects...
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m----------------------< e[0;36morg.geoserver.en:gs-docse[0;1m >----------------------e[m
[e[1;34mINFOe[m] e[1mBuilding GeoServer English Documentation 2.15-SNAPSHOTe[m
[e[1;34mINFOe[m] e[1m--------------------------------[ pom ]---------------------------------e[m
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/coverages.yaml&gt;
[e[1;33mWARNINGe[m] Directory does not exist, or is inaccessible. No file will be evaluated.
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coverages/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverageStores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coveragestores/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coveragestores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(datastores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/datastores.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/datastores/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/datastores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(featureTypes)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml&gt;
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureType_0`
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/featuretypes/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/featuretypes/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(fonts)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/fonts/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layergroups/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/manifests/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/namespaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/owsservices/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/reload/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/security/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/settings/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/structuredcoverages/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/styles/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/templates/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtslayers/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtsstores/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/workspaces/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/monitoring/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importer/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTransforms/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTasks/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerData/.swagger-codegen-ignore&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en&gt;
     [echo] Build directory is <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target&gt; and project version is 2.15-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.15-SNAPSHOT -W -b html -d "<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.15-SNAPSHOT -W -b html -d "<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/user/source/community/gwc-azure-blob/index.rst&gt;::image file not readable: community/gwc-azure-blob/img/azureblobstore.png
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 53.438 s
[e[1;34mINFOe[m] Finished at: 2019-07-09T10:04:45Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/443/display/redirect?page=changes&gt;
Changes:
[Andrea Aime] Adding missing image file for the azure gwc docs
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
Checking out Revision 9e2b417b537ad08d3c10be1391f7854492e7c433 (origin/2.15.x)
> git checkout -f 9e2b417b537ad08d3c10be1391f7854492e7c433
Commit message: "Adding missing image file for the azure gwc docs"
> git rev-list --no-walk 638c333130ff8df0bc961d139c9c68445c416908 # timeout=10
Unrecognized option: --batch-mode
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/444/display/redirect?page=changes&gt;
