[Geoserver-devel] Build failed in Jenkins: geoserver-2.15.x-live-docs #451
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/451/display/redirect?page=changes&gt;
Changes:
[maurobartolomeoli] [GEOS-9199] Hierarchical LDAP Groups Support - 2.15.x backport (#3506)
Started by an SCM change
Building remotely on FleetCloud i-0be1c32ccb986eb6b (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/&gt;
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/2.15.x^{commit} # timeout=10
Checking out Revision 13c347cafc0a9cbfb7a6ab21c222e4d8da1a65dc (origin/2.15.x)
> git config core.sparsecheckout # timeout=10
> git checkout -f 13c347cafc0a9cbfb7a6ab21c222e4d8da1a65dc
Commit message: "[GEOS-9199] Hierarchical LDAP Groups Support - 2.15.x backport (#3506)"
> git rev-list --no-walk 0101feff29d7bb750719325eb81c5d953227ed2e # timeout=10
[geoserver-2.15.x-live-docs] $ mvn -f doc/en/pom.xml compile
[e[1;34mINFOe[m] Scanning for projects...
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m----------------------< e[0;36morg.geoserver.en:gs-docse[0;1m >----------------------e[m
[e[1;34mINFOe[m] e[1mBuilding GeoServer English Documentation 2.15-SNAPSHOTe[m
[e[1;34mINFOe[m] e[1m--------------------------------[ pom ]---------------------------------e[m
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/coverages.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coverages/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(coverageStores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coveragestores/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(datastores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/datastores.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/datastores/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(featureTypes)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml&gt;
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureTypes_0`
[e[1;33mWARNINGe[m] generated unique operationId `getFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `putFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `postFeatureType_0`
[e[1;33mWARNINGe[m] generated unique operationId `deleteFeatureType_0`
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/featuretypes/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(fonts)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/fonts.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/fonts/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layergroups)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layergroups/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(layers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/layers.yaml&gt;
[e[1;33mWARNINGe[m] Type is NULL for Serializable Parameter: workspaceName
[e[1;33mWARNINGe[m] warning! Property type "null" not found for parameter "workspaceName", using String
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layers/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(manifests)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/manifests.yaml&gt;
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/version. Renamed to auto-generated operationId: aboutVersionGet
[e[1;33mWARNINGe[m] Empty operationId found for path: get /about/status. Renamed to auto-generated operationId: aboutStatusGet
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/manifests/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(namespaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/namespaces/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(owsServices)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/owsservices/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(reload)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/reload.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/reload/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(security)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/security.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/security/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(settings)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/settings.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/settings/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(structuredCoverages)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/structuredcoverages/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(styles)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/styles.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/styles/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(template)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/templates.yaml&gt;
[e[1;33mWARNINGe[m] default example value not implemented for io.swagger.models.properties.ObjectProperty@anonymised.com
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/templates/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmslayers/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmsstores/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtslayers)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtslayers/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(wmtsstores)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtsstores/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(workspaces)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/workspaces/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(monitoring)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/monitoring/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importer.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importer/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-transforms)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTransforms/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-tasks)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTasks/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mswagger-codegen-maven-plugin:2.2.2:generatee[m e[1m(importer-data)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] reading from <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerData.yaml&gt;
[e[1;34mINFOe[m] writing file <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerData/index.html&gt;
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] e[1m--- e[0;32mmaven-antrun-plugin:1.3:rune[m e[1m(compile)e[m @ e[36mgs-docse[0;1m ---e[m
[e[1;34mINFOe[m] Executing tasks
init:
     [echo] Base directory is <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en&gt;
     [echo] Build directory is <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target&gt; and project version is 2.15-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.15-SNAPSHOT -W -b html -d "<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/docguide/doctrees&quot;&gt; . "<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/docguide/html&quot;&gt;
user:
sphinx:
     [echo] Running sphinx-build -D release=2.15-SNAPSHOT -W -b html -d "<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/user/doctrees&quot;&gt; . "<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/user/html&quot;&gt;
     [exec] Warning, treated as error:
     [exec] <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;:137:Inline literal start-string without end-string.
[e[1;34mINFOe[m] e[1m------------------------------------------------------------------------e[m
[e[1;34mINFOe[m] e[1;31mBUILD FAILUREe[m
[e[1;34mINFOe[m] Total time: 5.517 s
[e[1;34mINFOe[m] Finished at: 2019-07-25T07:33:19Z
[e[1;31mERRORe[m] Failed to execute goal e[32morg.apache.maven.plugins:maven-antrun-plugin:1.3:rune[m e[1m(compile)e[m on project e[36mgs-docse[m: e[1;31mAn Ant BuildException has occured: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/build.xml&gt;:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/build.xml&gt;:101: exec returned: 2e[m
[e[1;31mERRORe[m] -> e[1m[Help 1]e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] To see the full stack trace of the errors, re-run Maven with the e[1m-ee[m switch.
[e[1;31mERRORe[m] Re-run Maven using the e[1m-Xe[m switch to enable full debug logging.
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] For more information about the errors and possible solutions, please read the following articles:
[e[1;31mERRORe[m] e[1m[Help 1]e[m http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
Not sending mail to unregistered user maurobartolomeoli@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/452/display/redirect?page=changes&gt;
Changes:
[noreply] Updated Use Headers for Proxy URL (#3675) (#3678)
Checking out Revision 39c8a86fcbb8c9d09ec3db63b60ca62c903886f3 (origin/2.15.x)
> git checkout -f 39c8a86fcbb8c9d09ec3db63b60ca62c903886f3
Commit message: "Updated Use Headers for Proxy URL (#3675) (#3678)"
> git rev-list --no-walk 13c347cafc0a9cbfb7a6ab21c222e4d8da1a65dc # timeout=10
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 45.568 s
[e[1;34mINFOe[m] Finished at: 2019-07-25T09:13:53Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
Not sending mail to unregistered user noreply@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/453/display/redirect&gt;
Started by user Torben Barsballe
> git rev-list --no-walk 39c8a86fcbb8c9d09ec3db63b60ca62c903886f3 # timeout=10
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 53.913 s
[e[1;34mINFOe[m] Finished at: 2019-07-29T22:14:39Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/454/display/redirect?page=changes&gt;
Changes:
[noreply] GEOS-9239: optional flag(s) to remove root layer from WMS capabilities
Checking out Revision c528931f37195999ab493cefce65b443b0f1a652 (origin/2.15.x)
> git checkout -f c528931f37195999ab493cefce65b443b0f1a652
Commit message: "GEOS-9239: optional flag(s) to remove root layer from WMS capabilities document when possible (backport to 2.15.x) (#3681)"
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 48.830 s
[e[1;34mINFOe[m] Finished at: 2019-07-30T10:24:01Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/455/display/redirect?page=changes&gt;
Changes:
[daniele.romagnoli] Documenting ImageMosaic-Indexer's WrapStore parameter
Checking out Revision 7632b7b7a49c5dd36cb5f10f2685b0bd4ea707d5 (origin/2.15.x)
> git checkout -f 7632b7b7a49c5dd36cb5f10f2685b0bd4ea707d5
Commit message: "Merge pull request #3687 from dromagnoli/wrapstore-doc-2.15.x"
> git rev-list --no-walk c528931f37195999ab493cefce65b443b0f1a652 # timeout=10
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 47.970 s
[e[1;34mINFOe[m] Finished at: 2019-07-30T10:48:55Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
Not sending mail to unregistered user daniele.romagnoli@anonymised.com
This PR should fix the build failure:
https://github.com/geoserver/geoserver/pull/3682
My apologies for the delay.
On Tue, 2019-07-30 at 10:48 +0000, Jenkins wrote:
See <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/455/display/redirect?page=changes](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/455/display/redirect?page=changes)>
Changes:
Building remotely on FleetCloud i-0be1c32ccb986eb6b (linux-fleet) in workspace <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/coverages.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/coverages.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coverages/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coverages/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/coveragestores.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coveragestores/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/coveragestores/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/datastores.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/datastores.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/datastores/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/datastores/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/featuretypes.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/featuretypes/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/featuretypes/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/fonts.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/fonts.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/fonts/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/fonts/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/layergroups.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layergroups/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layergroups/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/layers.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/layers.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layers/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/layers/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/manifests.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/manifests.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/manifests/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/manifests/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/namespaces.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/namespaces/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/namespaces/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/owsservices.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/owsservices/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/owsservices/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/reload.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/reload.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/reload/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/reload/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/security.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/security.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/security/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/security/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/settings.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/settings.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/settings/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/settings/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/structuredcoverages.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/structuredcoverages/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/structuredcoverages/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/styles.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/styles.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/styles/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/styles/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/templates.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/templates.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/templates/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/templates/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmslayers.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmslayers/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmslayers/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmsstores.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmsstores/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmsstores/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmtslayers.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtslayers/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtslayers/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/wmtsstores.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtsstores/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/wmtsstores/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/workspaces.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/workspaces/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/workspaces/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/monitoring.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/monitoring/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/monitoring/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importer.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importer.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importer/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importer/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerTransforms.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTransforms/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTransforms/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerTasks.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTasks/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerTasks/index.html)>
[e[1;34mINFOe[m]
[e[1;34mINFOe[m] reading from <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerData.yaml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/api/1.0.0/importerData.yaml)>
[e[1;34mINFOe[m] writing file <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerData/index.html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/api/importerData/index.html)>
[e[1;34mINFOe[m]
init:
     [echo] Base directory is <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en)>
     [echo] Build directory is <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target)> and project version is 2.15-SNAPSHOT
docguide:
sphinx:
     [echo] Running sphinx-build -D release=2.15-SNAPSHOT -W -b html -d "<[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/docguide/doctrees](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/docguide/doctrees)"> . "<[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/docguide/html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/docguide/html)">
user:
sphinx:
     [echo] Running sphinx-build -D release=2.15-SNAPSHOT -W -b html -d "<[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/user/doctrees](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/user/doctrees)"> . "<[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/user/html](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/target/user/html)">
     [exec] <[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst)>:137:Inline literal start-string without end-string.
[e[1;31mERRORe[m] e[1;31m<[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/build.xml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/build.xml)>:48: The following error occurred while executing this line:e[m
[e[1;31mERRORe[m] e[1;31m<[https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/build.xml](https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/build.xml)>:101: exec returned: 2e[m
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
[e[1;31mERRORe[m] e[1m[Help 1]e[m [http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException](http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException)
Not sending mail to unregistered user [noreply@anonymised.com](mailto:noreply@anonymised.com)
Not sending mail to unregistered user [maurobartolomeoli@anonymised.com](mailto:maurobartolomeoli@anonymised.com)
Not sending mail to unregistered user [daniele.romagnoli@anonymised.com](mailto:daniele.romagnoli@anonymised.com)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the
experts!
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:      +39 0584 1660272
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/456/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] Security LDAP docs fix (#3682)
Checking out Revision 8259627136969c65eeac4ddb974c5f3b5db22024 (origin/2.15.x)
> git checkout -f 8259627136969c65eeac4ddb974c5f3b5db22024
Commit message: "Security LDAP docs fix (#3682)"
> git rev-list --no-walk 7632b7b7a49c5dd36cb5f10f2685b0bd4ea707d5 # timeout=10
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
     [exec] <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/user/source/security/tutorials/ldap/index.rst&gt;::image file not readable: security/tutorials/ldap/images/ldap15.jpg
[e[1;34mINFOe[m] Total time: 47.677 s
[e[1;34mINFOe[m] Finished at: 2019-07-30T12:18:57Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
Not sending mail to unregistered user nuno.oliveira@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/457/display/redirect?page=changes&gt;
Changes:
[fernandomino7] [GEOS-9258] Promote status-monitoring module from Community to Extension
[fernandomino7] [GEOS-9258] Review fixes
Checking out Revision bc882eb8395e0da102cc6bad49fe16f277c0b8c9 (origin/2.15.x)
> git checkout -f bc882eb8395e0da102cc6bad49fe16f277c0b8c9
Commit message: "Merge pull request #3688 from fernandor777/status-monitoring-promotion-2.15.x"
> git rev-list --no-walk 8259627136969c65eeac4ddb974c5f3b5db22024 # timeout=10
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
[e[1;34mINFOe[m] Total time: 50.752 s
[e[1;34mINFOe[m] Finished at: 2019-08-07T16:18:59Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
Not sending mail to unregistered user fernandomino7@anonymised.com
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/458/display/redirect?page=changes&gt;
Changes:
[nuno.oliveira] Fix image name on LDAP docs (#3700)
[nuno.oliveira] Fix status-monitoring reference on community pom.xml (#3699)
Checking out Revision 57f3e64179fedb86659583563573d239c3106008 (origin/2.15.x)
> git checkout -f 57f3e64179fedb86659583563573d239c3106008
Commit message: "Fix status-monitoring reference on community pom.xml (#3699)"
> git rev-list --no-walk bc882eb8395e0da102cc6bad49fe16f277c0b8c9 # timeout=10
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
[e[1;34mINFOe[m]
init:
docguide:
sphinx:
user:
sphinx:
     [exec] <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/ws/doc/en/user/source/security/webadmin/auth.rst&gt;:242:Bullet list ends without a blank line; unexpected unindent.
[e[1;34mINFOe[m] Total time: 50.342 s
[e[1;34mINFOe[m] Finished at: 2019-08-08T13:49:01Z
[e[1;31mERRORe[m]
[e[1;31mERRORe[m]
See <https://build.geoserver.org/job/geoserver-2.15.x-live-docs/459/display/redirect?page=changes&gt;
