See <https://build.geoserver.org/job/geoserver-2.15.x-nightly/163/display/redirect>
Started by user Andrea Aime
Building remotely on FleetCloud i-0a998146de608786e (linux-fleet) in workspace <https://build.geoserver.org/job/geoserver-2.15.x-nightly/ws/>
No credentials specified
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from git://github.com/geoserver/geoserver.git
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:894)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1161)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1192)
at hudson.scm.SCM.checkout(SCM.java:504)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1816)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
Caused by: hudson.plugins.git.GitException: Command "git fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*" returned status code 1:
stdout:
stderr: remote: Enumerating objects: 14, done.
remote: Counting objects: 7% (1/14) remote: Counting objects: 14% (2/14) remote: Counting objects: 21% (3/14) remote: Counting objects: 28% (4/14) remote: Counting objects: 35% (5/14) remote: Counting objects: 42% (6/14) remote: Counting objects: 50% (7/14) remote: Counting objects: 57% (8/14) remote: Counting objects: 64% (9/14) remote: Counting objects: 71% (10/14) remote: Counting objects: 78% (11/14) remote: Counting objects: 85% (12/14) remote: Counting objects: 92% (13/14) remote: Counting objects: 100% (14/14) remote: Counting objects: 100% (14/14), done.
remote: Compressing objects: 16% (1/6) remote: Compressing objects: 33% (2/6) remote: Compressing objects: 50% (3/6) remote: Compressing objects: 66% (4/6) remote: Compressing objects: 83% (5/6) remote: Compressing objects: 100% (6/6) remote: Compressing objects: 100% (6/6), done.
remote: Total 29 (delta 8), reused 8 (delta 8), pack-reused 15
error: cannot lock ref 'refs/remotes/origin/master': is at ceee86015e6b5e4baccb8c68429a6d1c30879274 but expected 7d1d26e460e96bf2feb5e1442e36dd692e81a0a8
From git://github.com/geoserver/geoserver
! 7d1d26e460..ceee86015e master -> origin/master (unable to update local ref)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2042)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1761)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$400(CliGitAPIImpl.java:72)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:442)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.lang.Thread.run(Thread.java:834)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to i-0a998146de608786e
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:957)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
at sun.reflect.GeneratedMethodAccessor651.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
at com.sun.proxy.$Proxy89.execute(Unknown Source)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:892)
Skipped archiving because build is not successful
